Old 06-25-2015, 01:37 PM   #491
Sovereign
Legend
Drives: Whiteout FR-S
ok if it only started after header install it does point to gasket leak at engine overpipe connection or at the 02sensors them selves.
new gaskets ?
did you run a thread tap chaser through the header o2 threads, if you had to force o2 sensors in it can damage the threads causing a leak.
check the sensors are pluged in correctly black to black and grey plug to grey socket.
So I just came back to the shop that installed my headers and overpipe he said there are no gasket leaks and the sensors aren't leakin as well. There is also a defouler on the header can that be causing the bad o2 reading?
Sovereign is offline   Reply With Quote
Old 06-25-2015, 06:35 PM   #492
steve99
If the defouler is on the front 02 sensor yes it will cause a problem.
you dont need it as the tune disables the p0420 cel code.
you still dont need it on rear o2 sensor but it should not cause to much issue their.
are you using stock intake ? drop in filter ot intake tube ok but if complete intake changed can cause maf scaling and hence fueling issues without maf rescaling.
Old 06-26-2015, 12:23 PM   #493
bspec
A man
Drives: 14 BRZed
Hi there - can someone tell me if this looks normal/safe?
http://datazap.me/u/bombino/summer-c...log=0&data=1-2
If it looks good, I have MAF scaling for an AEM airbox that I'll post to the MAF thread. I'm on a stg1 91oct tune today, and I'm installing this weekend, along with a few other things, a header + stg2 EL tune; so I won't have much more time to mess with the stg1 tune.
sidebar: if I've MAF scaled for my intake on a stg1 tune, should I be able to plug those values into a stg2 tune and go?
Thanks very much
bspec is offline   Reply With Quote
Old 06-26-2015, 12:44 PM   #494
phrosty
Thanks very much
Wrong link? Not working.
Stage 2's MAF scaling runs slightly richer up top, I guess for safety's sake. I'd re-scale once you run it, but you can probably use yours as a starting point.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-26-2015, 12:47 PM   #495
bspec
A man
Drives: 14 BRZed
Sorry, I thought private=unlisted. It's public now. And thanks for the feedback.
Old 06-26-2015, 01:35 PM   #496
Sovereign
Legend
It's on the front o2 that's the issue. When I take it off I'll be back to update. Thanks! It's a drop in filter by K&N but I doubt that is causing the issues
Old 06-26-2015, 02:00 PM   #497
phrosty
You're running a bit lean when WOT. Give your LTFTs some time to build up.
Old 06-26-2015, 02:05 PM   #498
bspec
A man
Drives: 14 BRZed
phrosty,
I flashed this last tune on Monday of this week. How many miles do you typically put on the car, after a tune, before the fuel trim learning diminishes?
Old 06-26-2015, 02:31 PM   #499
phrosty
phrosty,
If you're driving steadily, it learns fuel trims pretty quick. Have you done any faster driving since Monday?
Old 06-26-2015, 02:34 PM   #500
bspec
A man
Drives: 14 BRZed
I've driven around town a bit, and done maybe 4-6 3rd gear runs to redline. No highway driving though. I'd say I've put maybe 50 miles on.
Old 06-26-2015, 02:34 PM   #501
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
phrosty,
Your trims shouldn't take that long to learn maybe like 20 miles...
You may want to look at maf scaling... See my thread as I was running lean too.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-26-2015, 02:59 PM   #502
phrosty
Fuel trims only learn in closed loop. When you're beyond around 20-30% throttle, it's probably in open loop.
Old 06-26-2015, 03:00 PM   #503
bspec
A man
Drives: 14 BRZed
dammit. I've already got quite a bit of time into MAF scaling, and almost no time to tweak it before going stg2. Doesn't help that the latest OFT firmware corrupts datalogs >20min long.
Guess I'll re-do the MAF scaling w/ the new tune.
Thanks for the feedback.
Old 06-26-2015, 03:01 PM   #504
bspec
A man
Drives: 14 BRZed
really? I see the ECU go into open loop at what feels like 50-60% throttle, if not higher.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
