#4999 | |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
The Following User Says Thank You to vfrqqq For This Useful Post: | mrg666 (07-05-2019) |
#5000 | |
pessimistic skeptic
But most of are here for pushing the limits of our cars. So, here is my experience: I started with the softest spring. It was working just like the stock recirculation valve. Tried the hardest spring next and noticed that the throttle response was quicker. However, I was worried that it was opening too late (at higher vacuum) to cause surge on the compressor. The middle strength spring gave still better throttle response but no noticeable surge. You can hear the surge when you quickly release the throttle. Same thing happens with rev limiter. The sound of valve opening and compressor surging are different. Warning again: Don't try too hard though, you can damage the compressor. I wish I had made a video to show the difference. It is like a whoosh sound with valve opening and a fluttering sound with surge. You definitely want to avoid the surge. If my compressor fails, I will not be bothering Jackson Racing with warranty. I know the cost of Rotrex c30 and how easy it is to replace. |
The Following User Says Thank You to mrg666 For This Useful Post: | CSG Mike (07-05-2019) |
#5001 | |
pessimistic skeptic
I started with installing the HKS dual resonator front pipe between the stock header and HKS HiPower Spec L catback. The HKS front pipe is 2 pounds lighter than stock front pipe. It was nice to replace rusty stock pipe with this shiny stainless steel pipe and have HKS all the way after over pipe. Here are the highlights. - After several days (1 tank 91 octane gas emptied and filled), JR factory tune is working; no problems, no CEL - Power increased, engine definitely revs up quicker. Maybe gain is more noticeable when combined with my catback. Short of racing exhausts, this is one of the best flowing catbacks, just like N1. Now, I have all the way straight through from stock header to the end. - Sound changed, not necessarily louder (maaaybe a bit), but much better sound tone. I like it. There are four resonators and two mufflers in this HKS exhaust system (and still ~20lbs lighter than stock) ![]() - MPG increased 10% !!! That was surprising to me but it is true. I have never seen 33 mpg in the city before. When I drive normally, I enjoy gas savings. So, efficiency and power both increased. - I don't notice any exhaust smell without second cat. Next is replacing the header with 2017+ header which I have received already. I am not expecting much/any change with that but I will post another update when I do that ... in a couple of weeks. This will be interesting to know because I have not seen anybody installing the new stock header on a 2014 JRSC/AT before. Let's see how JR factory tune takes it. I think it will just work normally. |
#5002 | |
Most people tend to drive with less throttle when the car is louder! ![]() |
The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (07-07-2019) |
#5003 | |
pessimistic skeptic
BTW, I now have 2017+ header installed as well. Based on one-day testing 20+ miles at a wide range of rpms so far, no CELs with JR factory tune. Sound is almost the same with old header. First 5-10 miles, I noticed ECU was relearning the new header. Apparently there is enough difference to learn. After that, it was very smooth. So, 2017+ header on a 2014 JRSC/AT seems to work great. I will post if I see any problems and or notice any change in performance. |
#5004 | |
Drives: MY20 Hakone Toyota 86
#5005 |
pessimistic skeptic
We have emissions inspection in NY every year that requires CARB certified header. I also wanted to keep the JR CARB tune which will not work with a catless header.
#5006 |
Drives: 2013 FRS
Hey JRSC owners;
I installed the factory tuned C38 kit on my 2013 FRS about 3 weeks ago. I noticed from the get go that when I let off the throttle I hear a fluttering sound. Its more apparent at higher RPM. I took a sound clip and sent it to JR but didn't get feedback so I figured I'd take a video with my gopro mounted front centre of the hood so it would pick up the audio a bit better than in cabin and see what the community feedback might be. At about 3:15 I come to an intersection and once I turn its much easier to hear as I come on/off the throttle around 3:30 - 3:50. The beginning of the video might give some insight as well. I find the general low rpm operating noise to be pretty significant, I guess 'silent operation' means different things to different people? My car has a completely stock exhaust system. Thanks |
#5007 | |
Drives: 2017 BRZ WRB with PP
Sent from my SM-N950U using Tapatalk |
#5008 |
Drives: 2013 FRS
@steved thats loudest of what I’ve heard. It seems each unit may sound somewhat different but that sounded loud to me.
2013 FRS - JRSC CARB
"Use all of the track" they say |
The Following User Says Thank You to milanojess For This Useful Post: | CSG Mike (07-13-2019) |
#5009 | |
Yours seems louder than the norm, but if there's no issues, it may be normal. |
#5010 |
@J1Avs
naturally aspirated dyno of an Ace A350 against another "big peak power" header. The area under the curve is where it really shines; up top, NA, it's choked like any other well flowing header, by the engine itself. The dip on the orange line seems to be an anomaly on this specific graph. ![]() Here's another set of dynos with just Ace header vs stock. ![]() |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | HachiRokuX (07-13-2019), mistople (07-13-2019) |
#5011 |
Drives: '14 BRZ Limited
Finally got my car back, was on the dyno last night.
340 whp, 250 tq @ 10.2 PSI Ambient: 90, 75% humidity C38 + HBP 1,200 cc injectors, E-72 Nameless headerback ![]() |
The Following User Says Thank You to peaches For This Useful Post: | new2subaru (07-13-2019) |
#5012 | |
Drives: 2013 FRS
The only issue I'm concerned about is if the fluttering sound a sign of compressor surge, it's also a bit annoying to hear coming off the throttle every time. |
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
