, dpfarr
Old 10-28-2024, 03:33 AM   #4985
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
For those who have removed or raised the supercharger to work on the engine or transmission, did you have to remove the AC compressor and tilt it out of the way first as with the original install?
Jeff86 is offline   Reply With Quote
Old 10-28-2024, 10:39 AM   #4986
B T
I just lift it straight up with some straps and an engine hoist.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Jeff86 (10-29-2024)
Old 10-29-2024, 10:51 AM   #4987
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Awesome. That is what I’ll do. Thanks!
The Following User Says Thank You to Jeff86 For This Useful Post:
Brewster (10-31-2024)
Old 11-04-2024, 02:52 PM   #4988
B T
Welp, think I may have tapped the piston crowns with my valves the other day. It's currently running fine but I'm tearing it apart anyways as I suspect there has been some valve seat seal issues. It's been a few years since I last rebuilt this engine. Have the following ready, am I forgetting anything?
Cometic .050" head gasket
Timing chains
Chain guides
chain tensioners
3-bond sealant
Killer B Oil pickup
Using ARP head studs so new aren't needed.
I'm not sure cam cover plates really need new seals, opinions?
Taking the heads off for inspection, not planning on opening case halves unless the crank doesn't turn easily. What do you guys think?
Old 11-11-2024, 12:23 AM   #4989
86Andy
Drives: 2013 Hot Lava FR-S
SOS - Need someone smarter than me to take a peek at my data logs, if anyone would be so kind! Zach from CSG is my tuner and I'll send this over to him too, but I'm sure he's a busy guy so I'd really appreciate crowdsourcing some opinions in the meantime, as my FRS is my only car. Logs linked at the bottom.
I've had my edelbrock for 2 years, very minimal issues until now, but it has been finicky with throttle response throughout my ownership and has only gotten 22mpg despite driving pretty conservatively. I run 92 pump gas and am fully catless.
2 days ago, I started getting very jerky throttle response and it was really lugging while getting going in first gear. Fuel trims were consistently in the negative high 20's. I did not think to log since I was a bit panicked, but I managed to get it home to my garage. Engine nearly stalled in neutral while rolling it back into my garage.
I've had MAF issues so I cleaned my MAF, and noticed the O ring was falling apart. I replaced the O ring, emptied my (quite full) PCV catch can, and reset the ECU by leaving my battery unplugged. Went for two short drives yesterday, and I thought the problem was solved. Come today, I went for a drive and immediately STFT was -29. Started logging, and it very slowly improved throughout my 30 min drive.
My first datalog is the first 10-ish minutes of this drive, when I was having issues. My second datalog is from my drive back. During log #2 it feels like it the issue resolved itself, but I expect it to happen again. Funny enough, during my second datalog the car was feeling better than ever, and my mpg was climbing higher than it ever has, though that may be due to resetting the ECU and only doing highway driving today.
The drive I went on today was to retrieve my smoke machine, so I plan on smoke testing for leaks on the intake side, as I've read that leaks can cause wonky fuel trims. Would take any suggestions for smoke testing as I've only done it once several years ago. I'll do the exhaust too, as I've been having some rattling sounds back there and suspect there may be an exhaust leak.
Let me know if i can provide any more helpful information. @CSGMike tagging you because you're the most helpful name on this forum that I can remember off the top of my head.
Datalog #1 - Issues
Datalog #2 - Issues resolved?
86Andy is offline   Reply With Quote
Old 11-12-2024, 04:23 PM   #4990
B T
While I'm doing a quick engine out inspection, decided to do a bit of work on the supercharger. Edelbrock has an issue where over time the bypass valve actuating rod will wear and slip inside of the housing. This will cause the valve itself to become damaged and caught in the open position, severely limiting boost. You can see the damage to the top of the butterfly valve at the top of the actuator rod in image 3 below. I'm sure they would sell you a replacement rod and bypass valve, but I'm going to give you a solution before it ever happens. Buy a 5 pack of these McMaster Carr PEEK Plastic washers and use all 5 to shim out the actuator as seen in picture #4. The first two washers will need to be sanded down on one edge resembling more of a D shape. This will stop the rod from wearing down inside the supercharger. First pic is just because a lot of us haven't seen what it looks like inside the supercharger itself.
Edelbrock heat exhanger inspection/degreasing
Edelbrock Supercharger with bypass valve
Bypass valve damage
Bypass Valve Solution
The Following 7 Users Say Thank You to B T For This Useful Post:
bigB (11-20-2024), Brewster (11-18-2024), CSG Mike (12-31-2024), dpfarr (11-18-2024), Jeff86 (11-19-2024), mrntd (03-30-2025), Tatsu333 (11-21-2024)
Old 11-30-2024, 11:41 AM   #4991
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Bypass valve damage
Thanks so much for this !
Did the engine check out OK ?
How dirty/oily was the IC ? The rotors and interior housing look clean.
Will you change the SC drive lube while this is apart ?
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 11-30-2024, 07:15 PM   #4992
B T
Heads are in the shop, I noticed some excessive clearance between the cams and rockers, so I believe there may be bent valves. The piston crowns showed no signs of impact however. The rotors were actually in really good shape but i hit them with WD-40 and wiped them down as best as I could. I did also change the oil in the supercharger, took just over 4 oz of fluid per the eaton charts. That fluid smelled worse than diff fluid BUT looked pretty clean! The intercooler definitely benefited from a degreasing to increase the thermal conductivity. Highly recommend a catch can on the CCV lines.
Brewster (12-01-2024)
Old 12-01-2024, 02:19 AM   #4993
Brewster
Brewster's Avatar
[QUOTE=B T;3610665]Heads are in the shop, I noticed some excessive clearance between the cams and rockers, so I believe there may be bent valves. The piston crowns showed no signs of impact however. The rotors were actually in really good shape but i hit them with WD-40 and wiped them down as best as I could. I did also change the oil in the supercharger, took just over 4 oz of fluid per the eaton charts. That fluid smelled worse than diff fluid BUT looked pretty clean! The intercooler definitely benefited from a degreasing to increase the thermal conductivity. Highly recommend a catch can on the CCV lines.[/QUOT
Degreasing the IC...... Hmmm
Possibly another reason to consider installing a water/methanol injection system. Besides lowering IAT's it'd help keep the IC cleaner
Old 12-16-2024, 11:55 AM   #4994
B T
Word from the shop, valve guides were worn out, rockers were out of spec, too much clearance between rollers and cam. I wasn't aware that bronze guides would wear out that fast, going back to steel guides. Back side of the valves were carboned up even with a catch can. I imagine oil was seeping by the valve seals. Last dyno shortly before tear down netted about 379 whp, hope to gain another 40 or so after all this work. Also, apparently I slapped the wrong gasket on the engine and was running stock compression this entire time, bumping it down with a .050" gasket to 11.7.
Old 12-17-2024, 12:20 PM   #4995
Brewster
Brewster's Avatar
Interesting. How many miles on those parts ?
Old 12-17-2024, 12:37 PM   #4996
B T
about 40k
Brewster (12-17-2024)
Old 12-27-2024, 05:21 PM   #4997
B T
Upon cleaning up the pistons, I found a small indentation on each one in the same position. No damage to the valves, just the piston dome. No play in bearings, waiting on the heads to come back from the shop for reinstall!
The Following 4 Users Say Thank You to B T For This Useful Post:
Brewster (01-04-2025)
Old 03-27-2025, 07:54 PM   #4998
B T
Well, I've shredded two belts this week. Both on the same stretch of road doing the same max rpm tuning run. They were two different types of belts. Attributed the first one to just being time and the second one was completely unexpected. I don't see any misalignment. Both belts lost the rib closest to the engine on the pulleys, no fraying towards the front. Anyone had similar issues?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
