#4957 | |
Drives: 13 BRZ
The pipes are (quoting from JR site) Jackson Racing Mandrel Bent & Powder Coated Aluminum Piping with rubber connection elbows. |
| The Following User Says Thank You to rns294 For This Useful Post: | CSG Mike (06-05-2019) |
#4958 |
Drives: '14 BRZ Limited
Bought a used C38 and installed it myself, currently waiting for it to be tuned. Don't have a power goal so we'll see what I end up with. Not sure if someone else has this combo:
Nameless header back (ceramic coated header, downpipe\overpipe combo w/HFC & Helmholtz, catback) DW 300 pump ID 1,200cc injectors FlexFuel C38 + HBP The wait is killing me... |
| The Following User Says Thank You to peaches For This Useful Post: | CSG Mike (06-05-2019) |
#4959 | |
Drives: 2017 toyota 86
Even better, aluminum pipe really easy to 1/8 npt tap for meth. Either way as long as its not entirely rubber like he originally thought he will be fine. |
#4960 |
Drives: jrsc_brz
#4961 |
Smooth, no issues aside from having to work in a storage unit with limited space. Used a funnel and a paper towel to create a seal on the oil reservoir and just blew on it to prime the line prior to startup, clearances are tight but nothing is rubbing. I did end up with the air filter touching the frame, so I had to trim the coupler a bit to gain clearance.
I also removed the Perrin oil cooler I had and replaced it with the JR radiator\cooler combo, things are very tight with the Nameless header but it works. Drove it to the tuner on the base tune, kept it under 3k RPMs under light load and it drove normally so I guess everything went ok. Question: after I let it idle and checked for leaks, I noticed the SC get pretty hot, is that normal? I've had turbo cars before, this is my first SC. ![]()
#4962 | |
Drives: 2017 BRZ (Sold), 2023 GR86
#4963 | |
Drives: 2016 brz
thx and enjoy your sc.Enviado desde mi SM-A730F mediante Tapatalk |
#4964 | |
| The Following User Says Thank You to peaches For This Useful Post: | kowalski (06-05-2019) |
#4965 |
@kowalski the swings will be slower, but because you're still thermostat and fan regulated, in stop and go traffic, you will see the same *range* of temperatures.
| The Following User Says Thank You to CSG Mike For This Useful Post: | kowalski (06-05-2019) |
#4966 | |
Drives: 2016 brz
thx! I actually have no problem with stock radiator when driving hard, except when really pushing uphill in curvy roads at high rpms (where all the fun is) for say an extended amount of time. Then the oil heats above 120 celsius and I have to let it cool a little. Coolant though stays in the 90 - 94 celsius while moving. However, in stop and go traffic, or even at 60km/h coolant temps reach 101 celsius quite quickly. Fans kick in, but as soon as they vanish, it gets there again. I guess with the dual radiator you can benefit for more abuse on the higher rpms. But I am not so sure if after pushing hard the coolant will be highly affected by having the oil temps next to it in the radiator. This is one of my concerns as, although it is not my daily, more often than not I am stuck in traffic.
#4967 | |
Many modern cars are made to cruise at 105C for efficiency! 120C oil is on the higher side, but still acceptable. Something like the Trackspec hood louvers, or a Varis (not Verus) hood would do wonders for your temps. |
#4968 |
Drives: 2016 White Pearl BRZ Premium
So I am starting to run in TT4 with NASA, and will need more power to get to my 12.0:1 pounds / HP ratio (per NASA's average calculator methodology). The car weighs for arguments sake 2700 lbs on the nose with me, coolshirt cooler, and a 1/4 tank of e85 as it sits now NA.
Questions : What does the JRSC kit weigh roughly? <-- FOUND ANSWER, roughly 55 lbs? For my target of 12:1 pound per HP, I need roughly 235 hp peak WHP. Should the C30 with the standard pulley get me there on e85? Understanding that it's inherently risky boosting a motor with static 12.5:1 compression - with a good tune, are the FA20s surviving at the "lower" whp levels like I'm targeting? This one may be directed more @CSG_Mike, but any track beaten JRSC cars please chime in More referring to lifting rings / heat related issues, and not so much starving the bearings due to g-load on hoosiers :haha:
#4969 | |
You would be well over 235whp with E85. Depending on the car and dyno, probably more in the low to mid 300s. C30s on 92 show a 280whp dynojet reading here at Drift Office. |
| The Following User Says Thank You to mistople For This Useful Post: | new2subaru (06-05-2019) |
#4970 | |
Weight Weenie
Drives: 15 FR-S
You can reach your goal easily by striping weight, adding a header/tune or both. |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
