Old 03-25-2013, 02:51 AM   #4943
JiB
JiB's Avatar
Drives: GT86
Noticed something wierd the other day when i dyno'd my car, John.
(Stage 1 Pump gas Perrin CAI tune)
Dyno'd the car on all 4 maps, map 1 and 2 were making much higher power than stock while map 3 and 4 "could barely spin the dyno" is what the dude said. No power there at all. went back to map 1, and bam, full power again.
I know u cant do anything until i lodge a ticket with some logs.
But thought i should let you know and if this has happened before.
Cheers
JiB is offline
Old 03-25-2013, 07:45 AM   #4944
M1K3
M1K3's Avatar
Drives: vrooom...
Cheers
Maps 3 and 4 are the maps with John's traction control, so it makes sense that the ECU is limiting the power to the vehicle, since it thinks it is losing traction while on the dyno with the rear wheels moving and the fronts not.
M1K3 is offline
Old 03-25-2013, 08:04 AM   #4945
JiB
JiB's Avatar
Drives: GT86
I thought the aggressive racerom traction only started working when traction was turned off
JiB is offline
Old 03-25-2013, 08:24 AM   #4946
M1K3
M1K3's Avatar
Drives: vrooom...
I honestly don't know for sure if that is the case, but I don't ever remember reading that RR TC was only active when normal TC was turned off. What I do know is that John said it was a FAIL to have normal TC on when using the RR TC.
M1K3 is offline
Old 03-25-2013, 08:27 AM   #4947
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Don't quote me, but I think JiB is right. RR TC only works with OEM traction turned off.
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
JiB (03-25-2013)
Old 03-25-2013, 09:23 AM   #4948
Visconti
Drives: 05 STi
Cheers
Hey
Glad you made power!
Map 3 and 4 has the traction control so it makes sense for the car not to produce power on the Dyno while on those maps
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
JiB (03-25-2013), tripjammer (03-28-2013)
Old 03-25-2013, 10:42 AM   #4949
DJCarbine
Thupercharged
DJCarbine's Avatar
John/Rich,
When I get my Borla UEL header installed, do I need to send in a datalog and get a new tune, or will my current tune for the AFE intake work fine?
Thanks!
DJCarbine is offline
Old 03-25-2013, 10:43 AM   #4950
Visconti
Drives: 05 STi
Originally Posted by DJCarbine View Post
John/Rich,
Thanks!
I would like to see a datalog
Visconti is offline
Old 03-25-2013, 12:46 PM   #4951
Visconti
Drives: 05 STi
Now supporting AMR's Cold Air Intakes
-John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
brichard0625 (03-25-2013)
Old 03-26-2013, 05:16 PM   #4952
Visconti
Drives: 05 STi
Just wanted to let everyone know that all tune requests and datalog reviews have been completed.
Enjoy!
Visconti is offline
The Following 6 Users Say Thank You to Visconti For This Useful Post:
cuddefred (03-26-2013), Foobar (03-26-2013), LeavingNormal (03-27-2013), Lee358 (03-26-2013), tripjammer (03-28-2013), UncleFester (03-26-2013)
Old 03-27-2013, 03:40 PM   #4953
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
It's been a bit since i've heard anything regarding the Flex Fuel kits. Just wondering where we are with those.
LeavingNormal is offline
Old 03-27-2013, 10:49 PM   #4954
Carwhisperer
Drives: A lot of supercars.
Really wish I had my camera tonight. Filled up on a whole new tank of e85 from being just about completely out in my tank and all I can say is Wow. The hp noticeably higher, but the torque is incredible with the 38F temperature out. I went with a wider wheel 8' with PSS tires and the car will Chirp going into 2nd really hard, 3rd like how 2nd used to be and still pulls harder in 3rd and 4th more than usual. I am really impressed on the e85 tune. I Feel just about 0 torque dip. Hardly noticeable.
Carwhisperer is offline
Old 03-28-2013, 05:06 AM   #4955
cuddefred
Drives: Black 86 GT
Really wish there was a dyno for the latest version of E85. I had to cancel my order a while ago cos I thought I was going to have to sell me car but I am now keeping it and seriously thinking of placing my order again - figures will push me over the edge
QUOTE=Carwhisperer;823511]Really wish I had my camera tonight. Filled up on a whole new tank of e85 from being just about completely out in my tank and all I can say is Wow. The hp noticeably higher, but the torque is incredible with the 38F temperature out. I went with a wider wheel 8' with PSS tires and the car will Chirp going into 2nd really hard, 3rd like how 2nd used to be and still pulls harder in 3rd and 4th more than usual. I am really impressed on the e85 tune. I Feel just about 0 torque dip. Hardly noticeable.[/QUOTE]
cuddefred is offline
Old 03-28-2013, 06:46 AM   #4956
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
[/QUOTE]
ill be doing a dyno in a week or so of the e85 tune to see what i put i down.. just found an e85 station right by my job so im super excited that i have so many options for e85
brichard0625 is offline
The Following 2 Users Say Thank You to brichard0625 For This Useful Post:
civicdrivr (03-28-2013), cuddefred (03-28-2013)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 01:42 PM
