View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-02-2016, 10:43 PM   #4901
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I had a crickets a few weeks ago with Wawa gas.... no crickets until this past week when I filled up at an off brand station (I needed gas badly and it was right next to the on ramp for the highway) and they are back, but they sound a little different than before. Must be a different species of cricket?
Old 07-21-2016, 03:59 PM   #4902
Wesley
Chen
Wesley's Avatar
Drives: RockyMountain bicycle bi-turbo '08
Finally heard some chirping after 52,000 kms! I've tried many different gas stations from Ultramar (shhh) to Shell. Never tried fuel below 91, often filled with Esso 93, more so than before i've been going to the same Petro for 94, AND after regularly filling there i've gotten a chirp! However I would like to add that depending on the position of my clutch the sound cuts. Most prominently noticed during idle of course
Wesley is offline   Reply With Quote
Old 07-21-2016, 09:47 PM   #4903
ArthurDent
Drives: 2014 Scion FR-S
My fuel pump makes so much noise it sounds like hammering inside. The dealer said that they know it is bad but they won't replace it because it costs too much. Doesn't matter to them that I only have 12,000 miles and less than two years.
I called Scion and they referred me to Toyota, no luck there. They said the same thing. We know it is bad but refuse to fix it. They told me to trade the car in and get a new one. I might do that but it sure won't be a Toyota
ArthurDent is offline   Reply With Quote
Old 07-22-2016, 10:27 AM   #4904
HunterGreene
Hail Magnet
HunterGreene's Avatar
Have you taken it to another dealership? That's BS that it "costs too much," because corporate pays them for warranty work. They're just lazy, and I would tell them as much.
It has priests in it?
Old 07-22-2016, 08:38 PM   #4905
GT86Asia
Drives: 2016 BRZ
Guys, you all know that it's the Gas pump that is making the chirping noise right?, it's like you are asking a tire that you just bought to not be so noisy when you drive on the street.
No dealer is factory is going to change it unless it represents a safety hazard.
Road noisy tires, aren't a hazard, they are just noisy because of a design flaw.
This is EXACTLY, the same issue with our stock gas pumps. They are fundamentally flawed in design so that they chirp when they are going at a specific flow rate when our cars are on.
So, the only way to get rid of it....is???
wink:wink:, if you don't want noisy tires.......YOU CHANGE THEM FOR DIFFERENT TIRES
hint:hint:, if you don't want a noisy gas pump....YOU CHANGE IT TOO, FOR A DIFFERENT BRAND MODEL PUMP!!
I had chirping for the first 900 miles of my car's life, and now I don't have any chirping in my car, and I never will again. You know why?, CUZ I CHANGED MY GAS PUMP, for an Ethanol compatible one.
Did I just make this 300+ pages thread irrelevant or what? :-P
GT86Asia is offline   Reply With Quote
Old 07-22-2016, 10:28 PM   #4906
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Not really. I don't want to spend money to replace something for such a dumb reason. It won't improve fuel pump performance or last any longer than the stock pump will, it'll just get rid of a small noise that I can only hear when I'm sitting in idle (so not very often).
Spending my money for their defect makes no sense.
Silver Cervy is offline   Reply With Quote
Old 07-22-2016, 10:31 PM   #4907
Make, model and supplier of the FUEL pump may make the tread irrelevant. Otherwise this is just another "I fixed it" post of the several thousand that already exist.
Old 07-22-2016, 11:34 PM   #4908
strat61caster
strat61caster's Avatar
Link to this pump? Seriously, you'd be the first to link a replacement high pressure fuel pump to my knowledge.
You likely replaced the fuel pump in the gas tank, not the high pressure fuel pump in the engine bay that makes the noise.
People running E85 typically report reduced noise anyway. I believe you made two changes and attributed the result to the wrong change.
ineedyourdiddly
Old 07-23-2016, 07:09 AM   #4909
Cole
Not a troll
Cole's Avatar
I'm really sick of this chirping. How can I get rid of?
Old 07-23-2016, 09:30 AM   #4910
Old 07-23-2016, 08:25 PM   #4911
steve99
fuel formulation
we get very little problems with chirping here as almost all of our premium fuel (98ron) is ethanol free.
We used to have 100 ron which was 98 ron with 10% ethanol and yep car chirped.
back to 98 ethanol free no chirps, but it does take a tank or two to go away completely.
very occasionally on really hot days you will get the odd squeak.
strangely on E85, no chirps after a tank or two.
maybe is some additive in your fuel for cold climates or their sneaking in 5-10% ethanol in fuels supposed to be ethanol free
Old 07-23-2016, 10:22 PM   #4912
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Cute.
Attached is a picture of your setup.
fortunately, the E-Force supercharger removes the pesky covers on the left and right.
Oh NO! What's that there on the right?
Yes, that thing, hiding under the A/C hose!
Surely not the OEM Denso High pressure GDI pump?
Oh... Damn... It is.
Always wondered if any of the old Bosch single piston demand controlled units would fit... Or the MM units that the Ecoboost fellas use... I thought, for a second, someone might have tried it. Then I realized.
Silly rabbit.
Your electric in-tank low pressure pump and the engine-driven HPFP are different things, grasshopper.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 07-23-2016, 11:25 PM   #4913
fuel formulation
LOL Cole did not use the proper sarcasm font. He is well aware that it is the ethanol content that feeds the crickets. We have several ethanol free fuels here at different octane and I can pretty much makes the chirp come or go at will just by filling up at certain stations during hot weather.
Old 07-26-2016, 12:21 PM   #4914
kch
Senior Misanthrope
kch's Avatar
Like others have already mentioned--you know there are two fuel pumps, right? The noisy one is the HPFP in the engine bay. You changed the in-tank fuel pump. Your lack of crickets is unrelated to your new in-tank fuel pump.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
