Old 06-27-2014, 09:15 PM   #4887
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by xjohnx View Post
All I know is that I had been running my stock axleback because of the rasp. Reinstalled my nameless axleback tonight and it sounds so much better now.
Originally Posted by MINOCIN View Post
This. I switched back to the stock muffler for the same reason, but after truly missing my Nameless axleback and then learning to keep my revs under 4K for daily driving I then switched back to the Nameless. I would love to get rid of the rasp at 4K though. I basically drive on a self-imposed limp mode because of it
I honestly thought the rasp was due to my headers in combination with the super charger. As though they were just a bad match and not well suited.
Are you guys running without cats? There's a pretty good amount of rasp from just going catless I've found.
Old 06-27-2014, 09:42 PM   #4888
xjohnx
Grip>Slip
xjohnx's Avatar
I've still got one cat (high flow in my nameless overpipe/downpipe combo), no cat in the nameless header. This rasp was definitely tune related though, and probably 95% gone now.
Old 06-27-2014, 10:15 PM   #4889
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Like @xjohnx I too have only one cat. It's on the Nameless downpipe, my PPE headers include their own overpipe but are catless. I would definitely like to mitigate the rasp as much as possible as it is one of two issues that have kept me from truly loving my super charger upgrade. The other being that the long tubes on the headers rattle. I believe @whataboutbob encountered the same thing as well.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 06-28-2014, 04:28 AM   #4890
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is there any information other than the name? If not, I wonder if it's what people are thinking it is.
The current kit uses a 210 already. So, to me at least, 210+ implies that it uses the same blower. Would Sprintex make a bigger blower and name it the same as a smaller one? I wouldn't believe so..
AFAIK the 210+ is the 210 but with a coating on the screws allowing for more compression per RPM.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Lawnik (06-28-2014)
Old 06-28-2014, 06:32 PM   #4891
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You forgot to take me for a ride after C&C today so I could record a usable video.
I'm not sure we can be friends anymore.
But it does sound good with the axle-back back on there.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 06-28-2014, 06:53 PM   #4892
xjohnx
Grip>Slip
xjohnx's Avatar
DOH! I can come give you one now and pick up my seats while i'm there.
Old 06-28-2014, 07:08 PM   #4893
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Parting out HERE
Old 06-29-2014, 01:40 AM   #4894
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Two data logs, top one is with the Nameless intake pipe, not coated, and the bottom is with the Innovate. Not an apples to apples comparison but still some info none the less. On the day I did the drive with the Nameless intake pipe it was between 70-75 degrees F outside. My average IAT was around 90 degrees F. On the drive I did tonight with the Innovate intake pipe the average IAT was about 95 degrees F but the outside temperature was around 85-88 degrees F. So about 15 degrees hotter outside but intake air temps only went up 5 degrees. I really need to do a run with the Nameless intake when the outside temps are hotter or with the Innovate intake when the temps are cooler to get a better comparison but I think this shows a bit that the Nameless intake, uncoated, does make for hotter intake air temps than the Innovate. Kind of a "well duh" but whatever.
Dustin is offline   Reply With Quote
Old 06-29-2014, 10:49 AM   #4895
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks for that. I'm interested to see how much their thermal coating helps. In the mean time I've wrapped my Innovate pipe with reflect-a-gold. I wish they'd make a heat shield for the header, too. Seems like it would be relatively easy for @Jason@Nameless and his crew to fab up a piece of metal similar to their intake manifold cover, and secure it to one of the holes in the radiator support.
The Following User Says Thank You to xjohnx For This Useful Post:
Dustin (06-29-2014)
Old 06-29-2014, 12:33 PM   #4896
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Is there any way you can place a metal (aluminum) heat shield directly above the headers (not touching)? If you could do this you would reflect a majority of the heat off the headers and away from the intake. Might help quite a bit especially when in power and making heat. Maybe even see if Nameless would make an "upgrade" that would allow people to add in a heat shield.
Cheers,
William Knose
Old 06-29-2014, 01:28 PM   #4897
xjohnx
Grip>Slip
xjohnx's Avatar
Cheers,
William Knose
That's what I'm looking to do. I know @Slip Angle had one made Fortune Auto, but when I inquired about them they said they don't make them.
In the mean time, enjoy some videos from 8.59.
[ame="https://www.youtube.com/watch?v=OGBj--YbaH0"]GOPR0008 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=ZWCDXHe4f1Y"]GOPR0010 - YouTube[/ame]
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
civicdrivr (06-29-2014), mikalem (06-29-2014)
Old 06-29-2014, 03:15 PM   #4898
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Noises. Glorious, glorious noises.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
xjohnx (06-29-2014)
Old 06-29-2014, 05:33 PM   #4899
xjohnx
Grip>Slip
xjohnx's Avatar
Such whine.
Very vroom.
evan (06-29-2014)
Old 06-29-2014, 07:40 PM   #4900
Calum
That Guy
Drives: 2013 asphalt FRS MT
Such whine.
Very vroom.
No man. Just no.
The car sounds great though.
The Following User Says Thank You to Calum For This Useful Post:
xjohnx (06-29-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
