Old 09-18-2016, 12:41 AM   #477
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's not normal but if you're just cruising along, it won't suddenly grenade. It may take many tens of thousands of miles to get worse.
Its been about 10,000 miles since it started, lol. Car just had the whole clutch assembly replaced and I guess they didn't notice it even though it's pretty noticeable.
Stang70Fastback is offline   Reply With Quote
Old 09-18-2016, 12:51 AM   #478
Ultramaroon
not playing cards
Ultramaroon's Avatar
I didn't catch your quotes earlier. Yeah, it's *cough* "normal."
Old 09-18-2016, 09:57 AM   #479
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
That's the TOB seizing up. If it takes as long as 2 minutes to let go it has probably already damaged the PP fingers.
Do you know why the noise goes away after the car starts moving? I'm hoping I can get a few more thousand out of it while I look for a shop.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-18-2016, 02:35 PM   #480
Ultramaroon
not playing cards
Let me backpedal a bit. As you know, it can be a challenge to form a mental image of an abstract scenario given a short written description. An audio/video clip would help immensely here. Barring that, am I correct that you have observed the following?
1. As of yet there is absolutely no abnormal noise at any time unless your clutch is depressed.
2. When cold, there is an abnormal sound which corresponds to engine speed when you press your clutch pedal.
3. The sound goes away and everything sounds/feels normal after a couple minutes.
There are a couple different abnormal sounds that can come from down there. One comes from within the worn bearing itself as it rotates. Another more critical one happens when the bearing quits rotating and simply rubs against the pressure plate fingers.
The goal is to decide what kind of sound you are hearing. If the bearing is locking up when you press the clutch, that's no good. You're done now.
If the sound you hear is from something rubbing inside the bearing, you have a little bit of time left. I think a few thousand miles is stretching it.
I'll guess that the bearing is not seizing yet. It seems to be rotating ok when there is no pressure on it and the sound goes away after it heats up. That's already a bad thing. If you want to save the cost of the clutch itself, get in there now. If it is driven at all after the bearing has seized or grenaded, your are in for the whole schmeer and likely stranded somewhere.
Old 09-19-2016, 03:15 PM   #481
Tt3Sheppard
Sorry for not providing enough information but I appreciate the reply! I'm going to keep an eye on this for the next week the sounds have been pretty low in volume compared to some of the videos I have watched on youtube with the same issue.
Sounds very very similar to this.
[ame="https://www.youtube.com/watch?v=LOJAnWEanmk"]FRS - High Pitch Whine - YouTube[/ame]
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 09-19-2016, 06:16 PM   #482
Ultramaroon
not playing cards
I remember seeing that one. I believe it turned out to be his alternator. A shorted rectifier diode will sound like that. Notice he had the whine even with his clutch disengaged.
Old 09-20-2016, 01:50 AM   #483
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Got my car back from the shop. They lubed up the clutch fork pivot points w/ liquid lube and the squeaks and crunchiness at the end of the travel is gone. If it comes back, then whole tranny has to be dropped according to them. Time to see if it comes back or not...
Bach415 is offline   Reply With Quote
Old 09-20-2016, 02:02 AM   #484
Ultramaroon
not playing cards
Oh, I just picked up on this. I was speaking in generalities. Not complaining or grumbling at all. Please, no worries!
Old 09-22-2016, 11:30 AM   #485
Stang70Fastback
A.K.A. Starlord
On a somewhat related note, n00b question: When they replaced my TOB, flywheel, pressure plate, and clutch disk, would they have needed to drain and refill the transmission fluid?
Old 09-22-2016, 11:55 AM   #486
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Nope not necessary
Toyarzee is offline   Reply With Quote
Old 09-22-2016, 12:15 PM   #487
Stang70Fastback
A.K.A. Starlord
Originally Posted by Toyarzee View Post
Nope not necessary
Alrighty. I'm coming up on 20k miles since my last replacement, so I guess I'll stick to my schedule.
Old 09-22-2016, 01:18 PM   #488
humfrz
Welp, it's my newly acquired understanding, that in order to pull the transmission (to get to the clutch etc) they usually pull the tail shaft out of the transmission, which would be less messy if they drained the transmission oil first.
@Toyarzee .... it may not be necessary, if you don't mind transmission oil all over the place when you pull the tail shaft .....
humfrz
Old 09-22-2016, 01:50 PM   #489
Toyarzee
Shibby!
Toyarzee's Avatar
Dang, well alright my bad. I was trying to remember how i changed tob before, then I realized it was a different car and its been too long. Gonna go take some vitamins or something
Old 09-22-2016, 02:13 PM   #490
humfrz
Yep, back in the day, we (or at least I) would drop the universal joint and leave the tail shaft in the transmission......
humfrz
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
