09-19-2023, 09:15 PM | #477 |
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
09-19-2023, 09:24 PM | #478 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Irace86.2.0 (09-19-2023), NoHaveMSG (09-19-2023) |
09-19-2023, 09:27 PM | #479 | |
Drives: Q5 + BRZ + M796
Also, at any one time there are about 9k planes in the air, and there are 11k satellites. Look up in the sky. See any planes? I guess planes don't exist. What? The planes aren't blocking out the sky? Right, 11k is not that many objects, and the satellites are hundreds of miles higher. The renderings of satellites around earth aren't to show actually density because satellites aren't proportionally as big as they are depicted in such renderings. It is to illustrate the increasing number of objects in near earth orbit. Artists can't create an image to scale for such an image. You can't see a building or even some small islands or countries from such perspective because they are too small. You can't see a satellite. How about video?
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (09-20-2023) |
09-19-2023, 09:37 PM | #480 | |
Drives: Crapcan
Uh, no. The propulsion force can act on the spacecraft and because of the 3rd law of motion the reaction would be to push it.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Dadhawk (09-20-2023), Irace86.2.0 (09-19-2023) |
09-19-2023, 09:50 PM | #481 |
The Dictater
None of those show a flat earth. Show me a picture of the entire flat earth.
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Dadhawk (09-20-2023), Irace86.2.0 (09-19-2023) |
09-19-2023, 09:52 PM | #482 | |
feeding the troll: I explained this before, but clearly you can't read. Could you fire a gun in space? You could, right? That is because everything you need to propel the led end of the bullet is in the gunpowder propellent. Similarly, if you explode fuel and liquid oxygen from a rocket engine, it propels the rocket because of the conservation of momentum (something goes one direction, the other thing must go the opposite direction). P=mv. But there is more: just ejecting the mass of propellant out the rear of a rocket is like throwing a bowling ball in space; it will cause motion, but it isn't as effective. By exploding fuel in a confined space like in the case of an engine, there is a propagating pressure wave. In the case of the engine, it propels the piston. In a rocket, it pushes against a wall of hot, high pressure gases all trying to leave a small opening (gases pushing against trapped gases). This propels the rocket forward more effectively than just ejecting mass, and it ejects it faster. The faster it ejects something, momentum is conserved, so the faster the object travels. In space, there is an advantage that you don't have air resistance (friction) or as much or any gravity to fight, so it takes far less propellants to do the same job.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Spuds (09-19-2023) |
09-19-2023, 10:13 PM | #483 |
Nothing showing a flat earth. Just like the fish eye lens can create a round image of a flat surface, a flat image can come from taking a picture of something round from close up. Show me a picture of the entire earth that is flat. All I have every seen are renderings.
8 inches per mile times 52 miles is 416 inches or 35 feet, which means at sea level, you wouldn't see the first 2-3 floors of building, but could still see the city. Stand on top of a mountain, like in that picture, and you can see all but may a few inches. The reasons rays of light seem to converge is similar to how a highway seems to converge to a point in the distance despite the highway width being parallel.
09-20-2023, 12:22 AM | #484 |
The Dictater
Ok this is cool. Flight of the Parker Solar Probe through a coronal mass ejection. I'd need to look up the instrument they are using to understand exactly what I'm looking at and "hearing" but still pretty cool at first glance. More details in the video description that I can't copy using my phone.
The Following User Says Thank You to Spuds For This Useful Post: | Dadhawk (09-20-2023) |
09-20-2023, 01:10 AM | #485 |
In a "vacuum" rocket fuel cannot burn and it has nothing to act on, so propulsion would be impossible. The second law of thermodynamics indicate the fuel would be useless in a vacuum.
The reality is, there is no "space" or "vacuum of space." If it existed, it would have to be contained and have a solid barrier from the air we breathe. If a "spaceship" were to somehow pierce this solid barrier, the "vacuum" would displace all of the air in our "atmosphere" according to the law of entropy. |
09-20-2023, 01:13 AM | #486 |
09-20-2023, 01:16 AM | #487 | |
09-20-2023, 01:20 AM | #488 |
They can't even keep their "official" images of the "ball earth" consistent. I can't believe people believe these liars.
09-20-2023, 01:23 AM | #489 |
Does anyone here know when the first physical object was put into "space?" I can't find a solid answer... Do any of you folks know?
09-20-2023, 02:03 AM | #490 | |
Second law is conserved for a rocket in space/vacuum. Chemical energy in a state of low entropy (high energy state) is exploded into a high entropy (lower energy state) where molecules are broken apart and forced out of one end of the rocket to be shot out and eventually they dissipate and spread out, but to get out that pressure creates force that accelerates a rocket. Shake a bottle of wine and shoot out the cork. Same thing. Space is a vacuum because it is devoid of matter. It isn't an actual vacuum cleaner, sucking things. You are confusing those definitions. The reason things get "sucked" out into space is because air in a ship is flowing out of the door into space, which is no different than you laying in a freestanding pool and being washed away with the water if the side breaks. The reason everything doesn't float away is because of Einstein's general theory of relativity and Newtonian gravity.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (09-20-2023), villainous_frx (09-20-2023) |
Similar Threads | ||||
Which Space Saver will fit? | Andrew666 | AUSTRALIA | 25 | 06-18-2020 09:07 AM |
Cockpit Space | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-15-2014 03:24 PM |
First run 86's (Space Saver question) | DriftEightSix | AUSTRALIA | 11 | 01-10-2013 07:25 AM |
FR-S space saver | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-29-2012 12:18 AM |
Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 12:29 PM |
