View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 06-02-2016, 06:43 PM   #4873
steve99
Any gas with a ethanol count of around 10% no matter what station it is from. The temperature reference is to how hot it is outside. Anything over about 70 seems to trigger it.
So I could get 10% ethanol gas when under 70 and no problems but when the temperature rises above 70 that same gas will cause crickets. Like I said I can almost call to the minute when they will stop or start based on what gas I bought and how hot it is outside.
Yep thats been my experience
if i run 100% petrol no chirps
running low ethanol content like 10-40% get chirps, more pronounced in high ambient temps
run full E85 no chirps except very occasionally when rearly hot day after track session
Old 06-03-2016, 02:58 AM   #4874
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Originally Posted by kritch View Post
Is that correct 2oz oil per 10 oz of fuel? That sounds like a lot. Don't want to get into the whole "Is it safe" debate again, just wanted to clarify. I tried it at a much much lower amount and seemed to do very little I might try it again at a higher amount if so.
You caught me before my edit lol. I meant 10 gal not 10 oz.
Originally Posted by MrDinkleman View Post
Thanks for your post. I just noticed this morning my injectors were REALLY noisy. And this is at 17,000 miles. When I read your post, I realized/remembered that I had filled my tank with 76 last night, at a station in a skeezy part of town. I normally use Chevron or Shell for no better reason than there are more stations near my house. Kind of weird since you say Chevron didn't help...
Anyway, when I refill my tank with Chevron or Shell, I'll see if it goes back to normal...
Well it's also been 85+ degrees every day so if it's temp related more so than gas related I guess it makes sense. Honestly people's results in this thread are so all over the place I have a feeling how much certain things help depends on what condition your HPFP is in. I kinda want to get mine replaced under warranty and start with the TC-W3 before the chirps even start to see if it's preventative maintenance.
treminaor is offline   Reply With Quote
Old 06-06-2016, 11:49 PM   #4875
Resolute
in the recliner of rage
Drives: Asphalt FR-S
Just before 1200 miles rolled on the odometer the crickets finally appeared in my new 2016 FR-S. I had done some research on common problems and complaints regarding the car before I purchased it, so I knew this was a possibility, but I never bothered to watch a video or anything to really get an idea of how obnoxious it might be.
Holy hell, it really does sound like a small flock/gaggle/herd of crickets in the engine bay! I almost died laughing when they first started. What an incredibly silly sound for an engine to make. Coupled with the rather agrarian/small tractor clatter it normally makes, this engine is like its own 'evening on the farm' soundtrack. In the list of best sounding engines, I would rank this FA20 decidedly near the bottom, and yet I find the racket to be so unique and odd for the engine bay of a sports car that I can't help but chuckle every time I hear it.
That being said, I have noticed that the crickets only come alive when I have filled up with Shell V-Power 91, but they have not made a peep the two times I filled up with Conoco 91. I'll keep switching between the two and see if the pattern continues.
Will
Resolute is offline   Reply With Quote
Old 06-07-2016, 12:51 PM   #4876
MrDinkleman
Drives: 2016 Oceanic, "base" model
So, after burning a quarter of a tank that is 75% local neighborhood Chevron and 25% of that skeezy neighborhood 76, the crickets are gone. However, temperatures are down quite a bit. OTOH, I first noticed the crickets when it was cooler (in the morning) as well. I'll keep monitoring it during the warmer weather...
MrDinkleman is offline   Reply With Quote
Old 06-07-2016, 08:01 PM   #4877
Tokay444
Anti stance.
Tokay444's Avatar
Still no chirping on my 2016 at 18000kms.
I've run every big brand 91 and Ultra 94 is what it normally gets.
Old 06-07-2016, 08:21 PM   #4878
Not hot enough out yet. Once you hit that sweet spot of ethanol and ambient temperature you will receive your free membership to the Cricket Club.
Old 06-07-2016, 09:15 PM   #4879
Impureclient
Drives: 2015 FR-S
Maybe I've missed this after reading all these cricket posts but why hasn't a parts manufacturer designed a replacement that doesn't chirp?
Impureclient is offline   Reply With Quote
Old 06-07-2016, 09:44 PM   #4880
stevesnj
stevesnj's Avatar
If it's more expensive they wont. Maybe on the 2nd gen the pumps will be compatible with Ethanol. In the US we don't buy enough of these cars for a redesign. You can buy an ethanol compatible pump but it's quite expensive. It seems the cricket infestation is prevalent in the US and Brazil.
My 2016 Build thread
Old 06-07-2016, 09:52 PM   #4881
stevesnj
stevesnj's Avatar
Here's what the membership t-shirt looks like.
Old 06-08-2016, 05:46 AM   #4882
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
After getting crickets for a couple of days, they haven't come back. I thought I heard a little something at idle a few days ago but not real loud.
The only difference is that I got gas once at a Wawa station instead of my normal station across the street. I'm not sure if there's a link but I'll stick to either the Citgo or Shell like I always have.
Old 06-08-2016, 07:25 AM   #4883
...and the official parking spot when in Carrollton, GA
Old 06-08-2016, 08:12 AM   #4884
stevesnj
stevesnj's Avatar
WaWa Is the worst fuel you can put in any car. They don't put in as many detergents and the Octane listed on the pump is averaged.
Old 06-11-2016, 05:14 PM   #4885
Tokay444
Anti stance.
Tokay444's Avatar
Hot one today.
Still no crickets.
Old 06-11-2016, 08:07 PM   #4886
Hot one today.
Still no crickets.
Ah but is the ethanol level right as well. It is a combo not a single.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
