Old 08-21-2012, 01:57 AM   #4873
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by OldSkoolToys View Post
It was a mixture of the styling and its power, mostly the styling. While a Miata is said to be 'girlish' in its design (early on at least), the Spyder was was more feminine looking, imho. That being said, I have driven a Spyder spirtedly before and Dimman is correct. It's basically a modern day AW11 (1st gen MR2), only with a ragtop and more rounded curves.
I agree that it looks girly, but I think it's mainly the front bumper that's the problem. The abrupt vertical cutoff accentuates the stubby headlamps. Most of the aftermarket bumpers slant downwards and have more of that "nose" to it (middle part protruding past the sides, ala S2000). From the rear the car looks quite nice, imo.
I think the Miata's main flaw is the rear, which looks really bubbly. From the front, the non-smiley face ones look quite good.
I don't know how the AW11s drove, but since you say Dimman is correct, it must be good
The 2ZZ is an amazing engine, but I feel like bolting one into this car would be...too easy? What I want to do is build a 1NZ to hit 8500-9000rpm (84.7mm stroke, 1.67 rod stroke or something, should be doable). NA, that would have perhaps 160hp in it. If I can get my paws on an Eaton TVS R720 by that time, because those things are so freakishly efficient, I'd like to do a Miller cycle setup good for perhaps 190hp The 1NZ is 30.5 kg lighter than the 2ZZ, so this gives some room to mess around with the balance of the car.
serialk11r is offline
Old 08-21-2012, 02:34 AM   #4874
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Originally Posted by serialk11r View Post
Yes, thank you very much for the recommendation! Yes it is manual. Only complaint is that I wish it had slightly closer ratios and one more gear.
Bingo!! We have a winner. You got what you wish for. Good for you.
If only had I not live so far away with strings attached, I would have gone there to get the car myself.
Now you can put on your, oh wait, you already have it on, crazy scientist hat, you can do lots of thing to this car to make it faster. Interesting time.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline
Old 08-21-2012, 02:49 AM   #4875
serialk11r
Not gonna try building the 1ZZ, transmission options for these engines are hopeless. C60s are so expensive. Waiting for a 6 speed from Toyota that comes on a cheapo mass produced car.
Now that I'm getting more familiar with stick, I feel like there's not enough gears with 5 speeds! The rpms drop so much between the gears, and 5th gear is just way too short burning a ton of gas spinning 3600rpm at 70 or whatever.
I do plan on attacking aero drag sometime. Gonna try to do a winternship, so I'm limited to the occasional free weekend to work on the car :/
Old 08-21-2012, 07:11 AM   #4876
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
I dropped the ball tonight and went home alone
I'd change the world if I could change my mind
DaveFTW is offline
Old 08-21-2012, 07:20 AM   #4877
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
my home weight scale said I weight 180's... my work's gym weight scale said I weight 160's. Which one is true and which one I wish I was...
What chu need is a doctor's scale:
Most accurate way to weigh yourself. My gym has one and last time I checked I was around the low 130's and my home scale said high 130's.
Look at some Lotus tuned 2ZZ engines since Toyota/Yamaha supplied them. Swap one of those in there and have fun with it. Lotus balling on a budget.
That happens to the best of us. I struck out with an Eastern European woman last night. Oh well on to the next one
Walk like a King, Be like a Sir, Swag it out like a Boss
S2kphile is offline
Old 08-21-2012, 07:54 AM   #4878
serialk11r
No no my point was that it's no fun if it's an easy swap!
The 2ZZ is high revving and has great specific output, but it is naturally aspirated, so we can do better I don't know though, superchargers and intercooling add up to quite a bit of weight.
By the way @Dimman, here's your full supercharger power consumption and volumetric efficiency map for the TVS R2300 or something.
http://www.smokinvette.com/corvette/...-supercharger/
Old 08-21-2012, 09:17 AM   #4879
Dimman
Kuruma Otaku
Dimman's Avatar
Looks like a good find. Skimmed a bit, I'll go over in detail after work. Don't know how much I'll understand though...
There is still the problem of finding a small TVS.
Because titanium.
Dimman is offline
Old 08-21-2012, 09:22 AM   #4880
S2kphile
S2kphile's Avatar
spyderchat forums has plenty of information.
S2kphile is offline
Old 08-21-2012, 12:59 PM   #4881
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
On the way to Chi-city! Then on Thursday to Urbana! It's gonna be a hell of a drive..
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 08-21-2012, 03:10 PM   #4882
serialk11r
Yea, those damned unicorns. The only small TVSs that have seen the light of day are the TRD Aurion in Australia and TRD Auris in South Africa, to the best of my knowledge. Actually I suppose you could say the Audi S4 has a "small" R1320, but that's way too big already. Ideally for these smaller 4 bangers we'd want the R720 (for a 2 liter engine we'd have to spin this all the way to its own "rev limit").
I'm starting to feel like a Toyota motor isn't the best idea for a radical swap. It would be so much easier to keep the stock ECU and reflash it, but this is like impossible for Toyota ECUs.
Old 08-21-2012, 03:47 PM   #4883
M-17
Ninja Cat Mod
M-17's Avatar
I'd say the gym scale is more likely to be accurate than vs. the home scale. So don't sweat over it.
And if it makes you any feel better, my mother was telling me that she thinks I'm overweight cause she rather hear that I'm 130lbs or 135lbs than my current weight of 145lbs, so that I'll be more in proportion to my height/weight scale.
But screw that, my goal was 150lbs this year, but I'm considering of aiming for 160lbs instead. So 160lbs is/might be my limit and I'll be perfectly content with that.
M-17 is offline
Old 08-21-2012, 04:10 PM   #4884
NickD
Drives: '05 Corvette
I'm trying to hit like 170. Got about 6 lbs left, going to keep cutting calories til halloween orr so
NickD is offline
Old 08-21-2012, 04:15 PM   #4885
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Broke it off with the lady...
Sorrows will be drowned in deadlifts and cardio instead of the usual suspects... Better, faster, stronger hah
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 08-21-2012, 05:45 PM   #4886
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Me too, said my goodbyes today.
blur is offline
