11-12-2018, 09:53 AM | #4789 |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Anyone wanna buy this stuff? I know someone can benefit... Brand new C30 high boost pulley and brand new hard intake pipe/couplers (replaces V1 full silicone pipe). (Ignore the 4 bar MAP sensor - this is already sold) |
11-17-2018, 02:49 PM | #4790 |
Drives: 13 Brz Jrsc
this sound right or is something wrong?
11-17-2018, 04:54 PM | #4791 |
pessimistic skeptic
11-18-2018, 12:30 AM | #4792 |
Drives: 2013 FRS
Hm mine doesn’t flutter, just wine a little and hissing when lifting
It seems there are different “normal” behaviors?
2013 FRS - JRSC CARB
"Use all of the track" they say |
11-18-2018, 12:33 AM | #4793 |
Drives: 2017 Toyota 86
That flutter actually sounds like a blow off valve..hmm.
11-18-2018, 08:09 AM | #4794 |
pessimistic skeptic
I can clearly hear that recirc valve is open based on the whistling sound when engine is idling. It sounds like working to me. Checking MAF reading at idle would be good. It should be 2.8 - 3.0 g/s.
11-18-2018, 06:29 PM | #4795 |
Drives: '14
Thinking about getting this kit for my AT. Will this kit be reliable for 260HP? I'm not hungry for more horsepower, just wanted a little more oomph in my daily driving.
11-18-2018, 07:09 PM | #4796 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
It's one of the more reliable kits for the platform. So at that level it should be perfectly fine (with proper tuning, supporting mods, and approval from CSG Mike).
11-21-2018, 03:41 PM | #4797 |
Drives: 2018 BRZ tS
Question:
For those of you running Flex Fuel/e85 on the C30 w/ Stock Pulley - have you had any issues? Also - are you running stock fuel pump and injectors or did you upgrade those? I am considering going HBP later in the future, when/if I decide I want anymore power, and know I would have to do injectors/pump at that point, but if there is no reason for them just running the stock pulley and E85, I’d rather wait. I’ll be primarily tracking it, so I’ve been told E85 is a better option because it burns much cooler, but I’m also concerned with pushing the motor to its limit, and worried that the extra power from E85 may do that. Any insight is greatly appreciated! |
11-21-2018, 07:48 PM | #4798 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | J1Avs (11-21-2018) |
11-23-2018, 12:23 PM | #4799 | |
Drives: frs
I had a number two rod failure. Catastrophic, destroyed the entire engine. Only my passenger side head blank was reusable, as it was machined for larger valves. It was not reusable with stock valves. C30 on regular pulley and e85 with full exhaust. The rods are the weakest link in my experience. It was epic fun though!
11-23-2018, 12:43 PM | #4800 | |
Drives: 2018 BRZ tS
11-23-2018, 03:34 PM | #4801 |
Drives: frs
I had a custom engine built. It’s not done yet. Very long process. I would not do it again. I will leave it at that.
11-25-2018, 04:15 PM | #4802 |
Drives: 2018 BRZ tS
Radium or Mishimoto PCV Catch Can?? Is the boomba check valve only needed for the Mishimoto, or would I need to grab one for the Radium also?
Thanks! |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
