Old 06-15-2014, 06:04 PM   #4775
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by DeliciousTuning View Post
We have not changed the speed limiter due to safety concerns. This is due to the fact that the manufacturer has set this limit for some reason aerodynamic, or other reasons unknown to us. From previous experience we have found it better to leave the limit in place. But if anyone does request it to be changed please send an email informing us that you are aware of the risks involved and agree to take full responsibility of anything that may occur by changing this limit.
The OEM speed limit in the us is set to 221 kph or about 136.
Cheers,
William Knose
usually they put in speed limiters because of the rating on the OEM tires...
Sellout is offline   Reply With Quote
Old 06-15-2014, 08:00 PM   #4776
evan
Drives: fr-s
Cheers,
William Knose
I would want mine set to 88mph.
evan is offline   Reply With Quote
Old 06-15-2014, 08:05 PM   #4777
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Michael Blue View Post
I wonder how hard it would be for one of the illustrious ECU tuners to remove that?
Our tunes do not have any speed limits. We get rid of fuel cut altogether, and leave throttle cut at 200 mph. No problems topping it out here but the tracks for that are few and far between even supercharged. Because everyone is doing this on the track right?
Xero-Limit is offline   Reply With Quote
Old 06-15-2014, 08:26 PM   #4778
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I bet you'd see some serious sh!t.
Old 06-15-2014, 08:33 PM   #4779
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by whataboutbob View Post
My car has just started to have misfire issues above 5K RPMs. I suspect the DI seals are gone on 3 of 4 cylinders based on it's behavior being consistent with DI seal failure and the fact that the dealer did some diagnosis and found 3 of 4 cylinders misfiring above 5K RPMs.
Old 06-15-2014, 09:29 PM   #4780
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Based on your sig I'm assuming you are running Bills tune so all the comments below are based on that....
Is your car popping at idle, or is it just misfiring up in 5k range?
Which version of Bill's tune do you have?
Wondering if you are experiencing the same types of problems at least 3 of of have seen - if so I think you would be the first auto.
mikalem is offline   Reply With Quote
Old 06-15-2014, 10:51 PM   #4781
DriftEm
DriftEm's Avatar
He is not running the flexfuel tune.
DriftEm is offline   Reply With Quote
Old 06-15-2014, 10:54 PM   #4782
mikalem
mikalem's Avatar
ah I stand corrected then. hope it turns out to not be the direct seals though at any rate!
Old 06-16-2014, 03:28 PM   #4783
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hey Bob, don't forget the part where you had a custom tune for the headers you installed, took the headers off, didn't tell me and kept the custom tune on for a couple weeks while you did some Autocross events.
Just a FYI.
Cheers,
William Knose
Old 06-16-2014, 09:59 PM   #4784
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've just hit CEL PO300 multiple cylinder misfire, car is idling rough and misfiring badly. I'm in stress mode.....
Ryan86 is offline   Reply With Quote
Old 06-16-2014, 10:28 PM   #4785
whataboutbob
AutoX-10/10ths every run
Just a FYI.
Cheers,
William Knose
Yes, that is true.
Build thread:Here
Old 06-16-2014, 10:29 PM   #4786
whataboutbob
only above 5k.
Build thread:Here
Old 06-16-2014, 10:31 PM   #4787
whataboutbob
Just to be clear here, I don't have any evidence that this is related to the tune. I did have Bill do a custom 91 tune w the PPE header/overpipe and the 70mm pulley. I had issues with the PPE headers ratlling, and swapped back the OEM parts without reverting back to the 8.58 tune. That may have induced the problems I have now. It is too early to tell at this point.
I'm going out in the garage now to pull the blower and try to get at the DI units.
Details to follow.
Build thread:Here
Old 06-17-2014, 03:36 AM   #4788
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Details to follow.
Bob, I'm sorry to hear that your PPE headers rattled too. I thought about taking mine off and swapping back to stock as well, but then I contacted Zach from Delicious tuning and he advised me against it because just as Bill mentioned for you, the car was tuned for those headers on the dyno.
Ever since I added the blower and headers I've actually been driving the car way less aggressively (but not necessarily slower). Mainly because the headers are so raspy and they rattle really bad unless you slowly roll on the throttle. I have found that the car now likes to be driven either slow and lazily or fast and at WOT, but not much anywhere in-between.
I don't know about you guys, but now that I'm boosted I hardly drive past 5,000 rpm. Before the SC kit 6,200 rpm and up was this engine's home. More so at the track and in the canyons. Now, I actually back off before I hit 5,000. Mainly because of the noise and somewhat because of how the engine feels above 5K.
From what I have noticed, the engine does like to rev past 5K and all the way to redline as long as it is in quick bursts. It gets rough and chokes up a bit if you try to hold the revs up there for more than a few seconds. I mainly noticed this at the track this past weekend. I'm still in an intermediate run group that only allows point-by passing, so when I'm stuck behind some slow schmo who isn't paying attention I get stuck holding my revs at around 5,500 rpm. I noticed that the exhaust would sometimes pop and the throttle would feel a bit "chunky". Sorry, I don't know how else to put it.
Anyway, Bob I hope you are able to get this issue resolved ok and that it doesn't occur for you again.
Good luck
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
