go_a_way1
Old 10-05-2018, 05:56 PM   #4775
Originally Posted by redlined600 View Post
I'm not looking to get addicted to (purple)crack.
71R is already dangerously close to purple crack grip, for a very short period of time.
Old 10-05-2018, 05:56 PM   #4776
Originally Posted by kch View Post
Speaking of VR1s....
Still NDA?
Unfortunately.
Trust me, I want to talk about things.
Old 10-06-2018, 12:14 AM   #4777
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
how someone can help me getting faster on the track
my question is about trail braking
i think i did trail braking in my video
can someone point out am i did the trail braking in the video or not
here is video link
[ame]http://www.youtube.com/watch?v=nZVoOEvoeLk&t=411s[/ame]
by the way i will take anything for me to be faster
thx
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 10-06-2018, 12:21 AM   #4778
You're not often trail braking, as your inputs are very punctuated, but there are some moments where you are definitely using the brakes to help balance and rotate the car on entry.
Have you considered hiring yourself a driving coach? You have a pretty good level of confidence in your car, and you'll pick up time by cleaning up the fundamentals and focusing on clean, rather than fast.
The electronics are definitely interfering with your driving here and there.
Old 10-06-2018, 07:52 AM   #4779
DerekM
Drives: White BRZ
A lot of it comes down to not up front cost, but the upkeep and running cost of each of those cars. What are you willing to spend in that area?
Replacement OEM Sachs dampers can be found lightly used for very cheap!
I'm guessing 3 to 5 per season for 10-15 track days after the car is set up correctly. That would be tires, brake pads, rotors and fluids. I would like to go the e46 route. Am I in the ballpark? Do you have other options that might work better? Thanks again for sharing your experience.
DerekM is offline   Reply With Quote
Old 10-06-2018, 07:18 PM   #4780
Turbo
Drives: FR-S Turbo
What hot pressures/temps do Hankook RS4 tires like to see?
Here is the pressure and (outside/middle/inside) tire temp data from my last session on the (predominantly right turn) track layout. All data from Joe's Racing gauges:
Run 5/
1:15.82 fastest lap / 1:14.30 RaceChrono optimal
LF 154/156/160 39.6 psi
RF 130/140/151 39.2 psi
RR 124/139/142 34.7 psi
LR 132/139/140 34.7 psi
Temps measured in the order above, then pressures done in same order. Measured right off the track after a 1/4 mile cool down, tops.
1) Will running lower front "hot pressures" increase front end grip?
2) If so, will this also translate to more initial bite on turn in?
Turbo is offline   Reply With Quote
Old 10-06-2018, 11:39 PM   #4781
It'll depend on heavily ont he pads, but that would be in the ballpark.
With equal tires, a 86 will cost you less than half the running cost of a E46.
Old 10-06-2018, 11:40 PM   #4782
Run 5/
Front pressures are good. Rear is slightly high. You need less rear camber for your current setup/driving style.
More likely, your setup/driving is front loaded.
Turbo (10-06-2018)
Old 10-06-2018, 11:52 PM   #4783
Turbo
Drives: FR-S Turbo
I'm not sure I know what you mean by this, Mike. Could you expand, please?
Are you referring to the overall handling balance of the car? Or maybe 'rake' of the car? I believe the rear fender-lip-to-ground distance is set 1/4" higher then the front (with me in the cockpit).
Should I maintain a level ride height? And if so would you advise lowering the rear or raising the front to get there? I believe I'm -26mm from stock all around with HKS SP IV coils.
Also, I have Hotchkis bars on the car front & rear. Front on the softest setting, rear on the second softest.
Old 10-07-2018, 12:02 AM   #4784
thx for point out!!
currently waiting for the racing seating with 6 points harness get install
this video was my first track day with re71r 245 40 17
was using stock tire for last 4 track day
so i need work on trail braking for now right ?
and disable the traction control fully by hold the left button right ?
or should i do a pedal dance thing ?
i dont know if the track has the driving coach for this track
but they do have a $1000 per one track day with instructor
should i try that ?
and what kind of question should i go with if i take that deal
i get group which we rent a track for one day and share the price 500 per day with 5-6 section with 20 min per section
Old 10-07-2018, 03:08 AM   #4785
You and/or your car overuses the front tires relative to the rear.
Turbo (10-08-2018)
Old 10-07-2018, 03:09 AM   #4786
Originally Posted by jayliu.jiayu@gamil.com View Post
thx for point out!!
should i try that ?
If your local instructor is proven, that would be a great route to go. I also offer private coaching if you're interested.
You should be using the pedal dance. First, explore the limits in a safe area.
If you are renting an entire venue for the whole day, I can accomplish a LOT with you in one day. I can go a full 8 hours of seat time, if you can.
Old 10-26-2018, 02:45 PM   #4787
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Figure here is the most likely place anyone has done it.
Looking to refresh my brakes and want to replace the guide pins and bolts. Already have seals. Has anyone found any solid OEM alternatives for the slide pins? Or do I just bite the bullet from Subaru?
Old 10-26-2018, 02:55 PM   #4788
Bite the bullet with OEM.
You could do what I do, and just buy junkyard calipers. It's very easy to see if a caliper has ever gotten hot by inspecting the outer dust boot and caliper coloration. Most have never gotten hot, and are in great shape for very cheap.
I replace my calipers regularly due to the extreme heat they see.
finch1750 (10-26-2018)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
