Sam Strano
Old 12-17-2018, 01:35 PM   #4761
tony_r
tony_r's Avatar
Drives: '15 STX
Originally Posted by Shark_Bait88 View Post
We use the same points calculator as SoCal, although we are open to adjusting in the future. Yeah, it can be kinda tricky when bringing over an autox or HPDE prepped car. It doesn't quite line up with SCCA TT either, but you could find a nice balance to run multiple events. It's more just a way to add another element of fun for those doing track days and TT/TA events.
For sure - the system heavily weighs GT Radials (or other 220+ treadwear) so it makes sense.
tony_r is offline   Reply With Quote
Old 12-17-2018, 02:10 PM   #4762
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Yeah. To really simplify the class points structure it essentially goes:
Stock: Camber bolts, pick wheels and tires, oil cooler, and pads & fluid. (you can get more creative in this class, and do a surprising amount if you take advantage of tires. But most people seem to be close to fully stock)
Street: power, grip, aero (Pick 1)
Modified: power, grip, aero (Pick 2)
Unlimited: Go nuts with all three
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-17-2018, 04:27 PM   #4763
Roadphantom
Drives: FR-S - STX
Originally Posted by Biggins View Post
Been there, done that, got denied... perhaps referencing the RX-8 is what kept the TRD and RX-8 in CS. Below is the letter I submitted last spring/summer.
Thanks for the notice. Did they provide any other reason other than "we think the TRD is currently appropriately classed"? What makes the SEB consider a proposal? If I submit a second letter, would it help by showing that there is more support for this move?
Roadphantom is offline   Reply With Quote
Old 12-18-2018, 11:03 AM   #4764
Biggins
Drives: Yes
I think it was the usual "Thank you for your input."
I was always told that it is always good to submit a letter to at least document what people are seeing/thinking/wanting. I'm pretty happy that my letter from over a year ago to move non-turbo E90 BMWs to GS is a real possibility for 2020. I can barely keep track of all the moves/changes in Street which is why I hope to co-drive other cars this season at the big events.
Biggins is offline   Reply With Quote
Old 12-18-2018, 04:25 PM   #4765
steverife
Drives: 2016 Scion FRS
I really don't think that move makes sense for anyone other than people that want to run DS in a twin.
The twins have SSC and STX. It is probably with the RX8 as the cars to have in CS outside of the ND. There seems to be a real push to get diversity in DS and they probably don't want to risk the twins being perceived as the car to have in another class.
steverife is offline   Reply With Quote
Old 12-18-2018, 09:09 PM   #4766
Roadphantom
Drives: FR-S - STX
I understand the situation is difficult with SSC and STX, I didn't think the twin would be a car to have in DS if the TRD went in, but I was thinking of giving it a little life so it becomes more like the ND1 vs ND2 in CS, but not the top dog. At this time, there simply is no good place for a street class twin. The diversity could be more interesting that way too, but I don't see an ex CS car being the top car against ex BS cars.
Old 12-18-2018, 10:55 PM   #4767
cirros
Drives: 2018 Subaru BRZ tS
Hello, I have a question regarding BRZ with the Brembo calipers.
I got a set of BBS RG-R wheels with 17x7.5", +48mm offset, 56.1mm center bore specs with the hope of running them for CS next year. When I rest it on the front hub, the spokes touch the brake caliper with about 3mm more to go.
I was looking into the market for 7mm wheel spacers for maximum clearance. The problem I see is that the car's wheel hub centric lips are about 7mm as well, making the hub + spacer combination to make a flush hub face for the wheel. I do plan on adding extended wheel studs to help reinforce each corners, but it cannot be an ideal way still.
Has anyone used such a combination before?
Also, are there any aftermarket wheel hub that could have longer hub lips?
Thank you very much in advance for your inputs!
cirros is offline   Reply With Quote
Old 12-19-2018, 07:38 AM   #4768
steverife
Many spacers are hubcentric and have that lip.
Also, while I can't recall ever running a set up without a lip on the hub, I've ran without the hubcentric rings (so the wheel is centered by torqueing your lugs properly) many times without any real kind of vibrations or issues.
Old 12-19-2018, 07:41 AM   #4769
steverife
Definitely write a letter, if that is what you want.
Old 12-19-2018, 01:59 PM   #4770
strat61caster
strat61caster's Avatar
I've been running spacers without centering features for almost three years now with ARP studs, no issues. Just be sure to snug the wheel up evenly and not to overtorque one lug.
https://949racing.com/Hub_Centering_Ring_FAQ.aspx
Recentish thread here
https://www.ft86club.com/forums/showthread.php?t=128460
ineedyourdiddly
Old 12-22-2018, 05:41 AM   #4771
cirros
Thank you so much steverife and strat61caster for your insights!
Old 12-22-2018, 10:43 PM   #4772
conehead
Drives: RS 2.0
The hub lip is simply there to hold the wheel in place while you bolt it on. The conical lug nuts center the wheel and provide all of the support for it.
conehead is offline   Reply With Quote
Old 01-03-2019, 10:31 AM   #4773
AX_FRS
Drives: 05 Ford Focus ZX4
Originally Posted by Locust View Post
So CS now has an index that's .001 softer than BS. Crazy. The ND is essentially a B-Street car with its own class!
I know I'm late to this, but WHAT? that's .09 difference on a 90 second course. For what is supposed to be a difference in performance. This is effectively reinforcing the common complaint of having a class for everyone. I suppose there is a lot more that goes into this, but there are uncompetitive cars in each of these classes, I'm sure. They could try to take a bit of time to group the ones that have similar performance and boost the competition in multiple classes. (Complaints, no real suggestions, I know.)
The TRD edition 86 will be a CS car, I'm sure. Yeah? Probably been talked about, but there are a lot of posts in here. Sorry.
AX_FRS is offline   Reply With Quote
Old 01-03-2019, 02:07 PM   #4774
TrqlessWonder
Drives: 2014 FR-S
The person trying to devise the PAX index has no input on the classing. He's just observing results, and trying to set a handicap for the structure given. This is not the first time the indexes have produced such a result.
TRD FR-S and all 86's as I understand it, are CS.
I can't imagine the horrific result that would come if we actually tried to class such that AS was 0.5 sec faster than BS, which is .5 sec faster than DS.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
