Sam Strano
Old 11-10-2018, 06:33 PM   #4747
Shadotracker
Drives: 2018 Subaru BRZ TS
Did some autocross today and was only .6-.7 seconds off from the fastest in my class, an RX-8 and ND2 that both (prepped for CS) had stickier tires than me, currently running on my stock tires on my TS. I could have picked up a little bit more time, but I need to start fiddling with the alignment and front sway bar and I could be a bit closer before dumping money on wheels and tires.
Shadotracker is offline   Reply With Quote
Old 11-10-2018, 06:53 PM   #4748
redfred
Drives: Red BRZ
We had snow today. Season over 3 weeks ago, you sound like you're doing pretty well.
Question for the group:
Got back into autos this year with a 100K mi 2013 BRZ, totally not prepped other than new BFG Rivals. Best pax was 15th overall, average around 21 in the 10 or so events I ran this year. Ran with Akron and Pittsburgh, I'm in DS. The good guys in WRX's beat me consistently.
I'm thinking about next season, do I prep for DS with Konis and TRD springs plus a sway bar? I'll need to rebuild most of the suspension anyway.
OR do I go with coil-overs and run locally in STX?
Thanks for your advice.
KO
redfred is offline   Reply With Quote
Old 11-12-2018, 09:30 AM   #4749
steverife
Drives: 2016 Scion FRS
KO
What are your goals?
steverife is offline   Reply With Quote
Old 11-12-2018, 12:38 PM   #4750
redfred
Drives: Red BRZ
Great question, thanks. My goal is to compete with a prepped car in order to run faster times. Goal also includes being able to trust the car when being aggressive by reducing the amount of over steer or tendency to spin.
Since the car has over 100K mi and is my DD, I will be replacing shocks this year, along with control arms or bushings. Currently these items are from 2013.
Thanks for the input. KO.
Old 11-13-2018, 07:23 PM   #4751
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
TRD springs aren't allowed in D-Street, so it would just be the Koni's and a swaybar. I can't speak on the need for a swaybar (still stock bars front/rear, and did plenty well at both Local, Milwaukee Region, and Nationals, but that may be driving style), however I would recommend at the very least the SSC Koni's so that if you don't want to stay in DS for 2019 (with the rally cars coming), that you can move to SCC easily.
P.S. - I have SSC Koni shocks readily available for sale, right now
STX is a whole different level in terms of prep, so it's hard to advise that to someone with a year back into it. I just don't see DS as the class anymore for these cars (not that was in 2018, but at least we got another year out of it).
PointDSM is offline   Reply With Quote
Old 11-14-2018, 10:07 AM   #4752
steverife
Yeah. Any twin in Street is going to have some rough days going forward. Day 2 at nats shows the potential of the Camaro/Hype R/WRX and that doesn't even address the new additions to the class. If my goal was to be competitive, I wouldn't run that category in that car.
SSC had an unrealistic PAX in '18. In a few days, we'll see how that changes for '19. Running a Spec class is a blast, if you have competition. I have mixed thoughts on the package for autocross.
STX cars are a blast. For a slightly larger investment than SSC, you will have a much faster car that should be pretty competitive. If you are the type that "needs" a full build, you'll either spend a lot of money or constantly be frustrated with being "underprepped".
Old 11-19-2018, 04:55 PM   #4753
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
So CS now has an index that's .001 softer than BS. Crazy. The ND is essentially a B-Street car with its own class! (I called it btw)
It's really interesting how everything has unfolded for the 86 platform after the initial decisions were made with the ND (and really how street has evolved in general). The initial classing of the ND into CS forced the twins down into DS (with a little assist from the BRZ crowd being upset about the TRD parts) and then the 4 cylinder Camaro and Mustang were brought up to DS from FS. That further forced the twins out which ultimately resulted in a spec class.
If the ND was classed into BS initially I bet AS, BS, CS, and DS would all look drastically different than they do now. Wonder if we'd have even gotten a spec class or if the ND might have become the spec car instead... I'm shocked anyone is still in CS with the twins. Subaru and Toyota aren't ever going to do any power upgrades to these cars so I don't see how they could ever compete in CS.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following User Says Thank You to Locust For This Useful Post:
DaWorstPlaya (12-14-2018)
Old 11-28-2018, 12:01 AM   #4754
Shadotracker
Bought myself an K&N air filter, 22mm front sway bar, and Nameless track pipe. Can't wait to use them at the next autocross event I do after then installation of the parts and a proper alignment.
Old 12-17-2018, 12:21 AM   #4755
Roadphantom
Drives: FR-S - STX
This might be time for all the twins including TRD upgrades to go down to DS. At this point, it shouldn't threaten the top dog DS cars they want to win, but it will give the twins a little more relevance in street classes for those who do not want to run SSC. What do you think? Anyone want to try to write a letter?
Roadphantom is offline   Reply With Quote
Old 12-17-2018, 08:06 AM   #4756
Biggins
Drives: Yes
Been there, done that, got denied... perhaps referencing the RX-8 is what kept the TRD and RX-8 in CS. Below is the letter I submitted last spring/summer.
Please consider moving the remaining "best-of-breed" TRD FRS/86 and the BRZ Performance Package to DS with the proposed 2019 moves. With all of the pre-ND MX-5 Miata being stable in CS and an influx of S2000 as a possibility, please consider moving all of the FR-S/86/BRZ into DS in 2019 IF the RX-8 and especially if the STi, Evo, Focus RS, Audi S3 get moved into DS in 2019. The TRD FR-S/86/BRZ PP have proven to have nearly identical autocross performance to the RX-8 over the past few years and would likely be less competitive than the above AWD cars proposed to move into DS in 2019. I am for all of these changes even if the TRD/PP FR-S/86/BRZ are forced to stay in CS, but I would prefer they all be lumped into DS. Yes, the spec class exists, but it would be nice to have a competitive street class for the the "best-of-breed" FR-S/86/BRZ to go for competitors who enjoy multi-marque competition. Thanks!
Biggins is offline   Reply With Quote
Old 12-17-2018, 12:05 PM   #4757
tony_r
tony_r's Avatar
Drives: '15 STX
With DS getting another shake up there isn't any reason to throw yet another package car into the mix. The twin has SSC and STX for a competitive place.
tony_r is offline   Reply With Quote
Old 12-17-2018, 12:15 PM   #4758
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Have you considered looking into some track day fun instead, or to supplement autox? Midwest 86 Cup is starting its second season in 2019, and with the recent announcement of NATA we are hopeful that we can get a fairly diverse schedule for 2019. It offers another place to play with your BRZ, where it can be competitive in every class!
www.midwest86cup.com
www.facebook.com/groups/midwest86cup/
Sorry to derail from CS talk, but wanted to throw this out there as I know a lot of Twin owners haven't been all that thrilled with where the platform has gone in autox classing.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-17-2018, 01:00 PM   #4759
tony_r
tony_r's Avatar
Drives: '15 STX
This is a cool option, too. I did one with the Norcal 86cup this past weekend and it was pretty fun, it's a great way to play with the car in lower prep levels.
SoCal rules throw a lightly prepped STX car into unlimited, though.
The Following User Says Thank You to tony_r For This Useful Post:
Shark_Bait88 (12-17-2018)
Old 12-17-2018, 01:02 PM   #4760
Shark_Bait88
We use the same points calculator as SoCal, although we are open to adjusting in the future. Yeah, it can be kinda tricky when bringing over an autox or HPDE prepped car. It doesn't quite line up with SCCA TT either, but you could find a nice balance to run multiple events. It's more just a way to add another element of fun for those doing track days and TT/TA events.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
