#463 | |
Drives: blue - Cosworth SC stage 3.0
the minimum radius you can run is 25mm on a PK tooth belt so bear that in mind when designing your nose pulley and you'll need to run about a 3:1 ratio to get the boost into the sweet spot for the unit, so as the crank pulley is 137mm diameter ( I think from memory) then you will need to make the crank pulley bigger and possibly require 8 ribs not 6 to account for the extra power to drive it. however one issue with extending the length of the pulley so its no longer overhung means that you will be canterlevering the bearings in the nose casting now they will cope with a certain level of load but the overhang needs to be kept to a minimum and some kind of tensioner will be required as you need to try and achieve a minimum of 180 to 200 degrees of belt wrap on the charger pulley Last edited by Matt@Cosworth; 05-10-2016 at 06:09 PM. Reason: stuff |
#464 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#465 | |
Drives: Gt86 Cosworth Stage 2
I will look at fabricating a tensioner bracket to get the correct pulley wrap. How close are the bearings on the SC? I could always make up a front bearing bracket to take the load but then perhaps just changing the full pulley set would be easier after all... |
#466 |
Drives: Subaru BRZ
So what is everyone's stocktake view on the Cosworth? In the market and in the UK but not overly impressed after reading this thread
#467 |
Drives: GT86 Cosworth
#468 | |
What exactly are you looking for, and what does not impress you about the kit vs the others?
#469 | |
so the standard pulley is overhung to put load in the middle of this race if you start overhanging the front of the existing pulley you'll cantilever on this bearing so a 2nd support would be wise. Perhaps incorporate it into your new tensioner bracket ? the reason I say to consider SD from the beginning is the Standard MAF installation starts to clip ( reach maximum voltage) at about 300Bhp and running a Bar of boost means you'll max it out early on unless you remount it in a larger tube |
#470 | |
#471 |
I'll chase it up
#472 | |
If I recall something alone the lines of "all warrenty or implied warranty would be out the window if it puts a leg out of bed" So its very much a, you can fit this but you are on your own. Which is the bit that put me off personally. |
#473 | |
Got Carrillo 10:1 pistons and forged rods on the way. Kelford uprated valve springs, ARP stud kit, cosworth head gaskets also in the pipeline. Gonna take a few months until it's all done... |
#474 | |
#475 |
Drives: 2016 FRS Release 2.0
Does Cosworth have any plans on making a CARB compliant tune? I am also curious on the expected release date of the third stage.
#476 | |
As for the Stage 3... yeah....... BUT you'll be happy with just the supercharger and full exhaust set up.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6049 | 06-25-2026 10:40 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 02:33 PM |
| Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 11:26 AM |
