Old 11-05-2016, 02:38 PM   #463
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Originally Posted by Yoshoobaroo View Post
Try Nova launcher, the stock one is pretty heavy. Also disable any stock apps you don't use. A lot of them will still load into the ram, which is why hitting the rocket button works.
-Josh
Yeah I was actually just about to try that. I think I'm going to switch to a more powerful unit next month regardless, these hangups aren't acceptable to me since the whole purpose of having this thing is gauges.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 11-05-2016, 02:58 PM   #464
Leeto
Leeto's Avatar
Drives: 2016 BRZ Series.HyperBlue
Mine was super slow as well, but after disabling Google App and Google Play Services and tweaking some values in the Governor it's relatively quick now.
More info on the governor stuff here: http://forum.xda-developers.com/show...66&postcount=3
I'm using the latest Malaysk MTCD rom which has root access. I used kernel adiutor to set the go_hispeed_load to 60 and hispeed_freq to 1608000 and it's been pretty good since then.
Downside of disabling Google Play Services is that you can't store offline areas in Google Maps (among other things), but I guess I can live with that.
Leeto is offline   Reply With Quote
Old 11-05-2016, 03:08 PM   #465
Leeto
Leeto's Avatar
Originally Posted by Pointmutation View Post
I've modded the stock lines but I'm just using the png on carjoying's RAV4 blog post at: https://www.carjoying.com/Joying-blog/28.html Visually it isn't as in your face chunky as the stock Malaysk rom reverse image.
But that png doesn't match our twins' cam angle and wheel track (obviously because it was made for a RAV4. lol). Here's what it looks like on the unit.
The red 0.5m line is pretty good distance wise. But the green 2m line is more like 1m on our car. And the yellow track lines are obviously off. I just use it for the red line distance as I reverse mainly using mirrors and head check and only refer to the reverse cam for distance to wall once I'm already straight. I may just go in and remove those track lines and the numbers on the green line.
I ended up messing with the lines myself. I laid out two tape measures along the car's trajectory and tried to line up the stock lines with the ones in the picture. It's not perfect but it is a lot better than the original.
Original lines with the real trajectory on the ground:
Modified lines png file:
Modified apk with the new trajectory lines
MTCBackView.zip
I didn't get a picture yet, but it's pretty decent now.
Old 11-05-2016, 09:44 PM   #466
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
There's a more powerful one?
-Josh
Old 11-15-2016, 12:48 PM   #467
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Has anyone on 5.1.1 noticed significant increases in performance from upgrading to JY_1.90 (Sept) from JY_1.63 (June)?
Also, has the sound output changed? I am worried that if I upgrade then it will mess up my oem audio+ tune.
l0aded is offline   Reply With Quote
Old 12-13-2016, 01:41 AM   #468
l0aded
Addicted
l0aded's Avatar
Update, I retuned my sound and it's great with OEM audio Plus. If anyone has the Joying 5.1.1 HU or OEM Audio Plus setup I would recommend pairing the two as it sounds amazing.
As for the 5.1.1 headunit, I decided not to root it and stuck with v1.90 as it fit my needs. Disabled a bunch of google services which sped up the unit ALOT.
Old 12-23-2016, 07:53 AM   #469
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
They added the new 2gb units running Intel processors (rockchip partnership)
https://www.carjoying.com/us-warehou...entertain.html
Rican_D is offline   Reply With Quote
Old 12-27-2016, 07:25 PM   #470
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
how are you guys getting your units (internet) ?
I'd perfer not to use a hotspot.
Does BLUETOOTH Internet connection sharing work?
Everytime I go into google maps it needs a connection when I have GPS. what am I missing?
steve87j is offline   Reply With Quote
Old 01-01-2017, 10:50 AM   #471
Rican_D
Rican_D's Avatar
Never tried connecting via Bluetooth. Use either hotspot, Wi-Fi, or dongle. You can always download offline maps of your area.
Sent from my Pixel XL using Tapatalk
Old 01-03-2017, 03:49 PM   #472
xjohnx
Grip>Slip
xjohnx's Avatar
Just got mine today. (This version, anyway) https://www.carjoying.com/android-5-...-din-wifi.html
Old 01-03-2017, 08:34 PM   #473
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I've had half an eye on that one...I have the older MTCB version. Curious if the DVD button is truly dead or if something like mtc-keys can make use of it. I currently have all my buttons re-purposed and losing one would really mess up my routine ><
BRZyJ is offline   Reply With Quote
Old 01-03-2017, 09:00 PM   #474
xjohnx
Grip>Slip
xjohnx's Avatar
I'll have to check out mtc-keys. will that work on the stock rom? i had a ca-fi before so the joying side of things is new to me.
if i recall, before i disabled it, pushing the eject button did elicit a keypress beep, so it should still be functional. but i can confirm further once i figure out more about how it works.
I can confirm that my USB OBD2 adapter works great, which means super fast refresh rates.
Old 01-04-2017, 01:52 AM   #475
BRZyJ
BRZyJ's Avatar
IIRC it will, but the unit still needs to be rooted and have xposed installed.
Basically you activate the mtc-keys xposed module and create an mtc-keys.ini file on the SD card. The file contents map the buttons ID to the package/action/intent you want it to run...mine looks like this:
Code:
# Remap physical HU buttons to apps
# MUTE button [home]
action_4=home
# DVD button [mtcmusic4]
app_42=com.microntek.music
# BAND button [torque]
app_43=org.prowl.torque
# NAVI button [HERE WeGo]
app_51=com.here.app.maps
Thread is here:
https://forum.xda-developers.com/sho....php?t=3246426
That sounds promising. If I can retain the use of all the buttons I might have to upgrade...the boot time on this thing is killing me. That made me think...using the eject button for something never even occurred to me...I might try that, can never have too many buttons
I have an OBDLink SX myself...reading all of the headaches people are having with bluetooth over on XDA makes me real happy I opted for USB
Old 03-09-2017, 07:38 PM   #476
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Evening All -- Has anyone updated to the latest march or february firmwares for their 2GB 5.1 unit?
I had OEM Audio+ retune my amplifier but the imaging and sound balance was far off. I'm on the Dec 2016 firmware and they had based their tune off of the Nov 2016 firmware. Joying must be modifying the sound output with some firmware revisions.
I'm trying to decide if I want to stick to Dec 2016 firmware and let OEM+ tune to that (I am sending my headunit in with the amplifier for retuning), or if I want to upgrade to the latest firmware so that i'll be current before they begin the tuning. It's tough to know, because there aren't too many folks providing feedback on the february or march firmware updates. Anyone have thoughts?
ajcarson11 is offline   Reply With Quote
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
