05-30-2014, 01:58 PM | #4649 |
Drives: 2013 SWP BRZ
Upgrade to 8.58 and see if the problem persists. Do you have the file, or still waiting? I ran .52 with no issues, I think it was 51 that had the codes popping up on people but I could be wrong.
The Following User Says Thank You to xxscaxx For This Useful Post: | Ethan (05-30-2014) |
05-30-2014, 07:54 PM | #4650 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
I keep popping I think code P0301. 8.58 tune, 93 octane, intercooled, 70mm pulley.
05-30-2014, 08:01 PM | #4651 | |
Drives: Raven FR-S
I can make my car misfire on cylinder 2 if I get around 5k rpms and roll on to the throttle slowly. Same specs as you listed. Makes a really nasty almost tearing sound when it happens. Probably my coil pack being a piece of shit.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
05-30-2014, 08:50 PM | #4652 |
Drives: Flat grey Toyota 86
I can as well using a similar technique but I don't get any sound, just a flashing cel of P0303. I can also get it to flash it by not allowing full warm up and pushing it early.
I logged all 4 cylinder misfire counts and it happens actually in both 2&3 cylinders, even though it only throws P303 which is for #3. Checked plugs, they looked good but replaced them anyway and swapped coils, neither had any noticeable effect if I induce as per above. Now if I don't intentionally induce it and allow time to warm up before getting into it, I've had no issue. |
05-30-2014, 09:00 PM | #4653 | |
Drives: Raven FR-S
Same thing if mine isn't warmed up as well basically. If I go WOT it never happen, but if I try and hold the rpms up high around 5-7k it goes nuts and misfire like crazy causing a flashing cel as well. Mines only been on cylinder 2 so far.
05-30-2014, 09:44 PM | #4654 |
Twin Screw You
Exact same with mine to the letter. It's awful of I don't let it warm up first. WOT though it's awesome.
The Following User Says Thank You to Dustin For This Useful Post: | CK_Bladesmith (05-30-2014) |
05-31-2014, 01:29 AM | #4655 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
I've heard Toyota have a TSI out on the coil packs. Soon as I have a copy I'll post.
Many stock cars are having coils replaced so this is not tune or F1 related. |
The Following 2 Users Say Thank You to Ryan86 For This Useful Post: | CK_Bladesmith (05-31-2014), Ethan (05-31-2014) |
05-31-2014, 09:16 AM | #4656 |
Drives: Subaru BRZ
I have a 2013 BRZ and the 2014s apparently have a different part number for the coil pack. When I replaced the coil pack I just replaced it with the 2013 version and, as stated above got the same P0302 CEL a month later. So, are the people here with the coil pack problem in 2013 cars or 2014?
05-31-2014, 09:24 AM | #4657 | |
Grip>Slip
05-31-2014, 09:44 AM | #4658 | |
Thanks
06-01-2014, 11:55 AM | #4659 | |
Twin Screw You
This mornings drive to work with the Nameless intake pipe, not coated. Peak IAT temp was 58 C which is 136 F with the average being in the low to mid 30's C which is around the 90 F mark during highway driving. Outside temp was between 70-75 F. I'll do a drive tomorrow or the next day with the Innovate intake pipe to see if there is much of a difference.
The Following User Says Thank You to Dustin For This Useful Post: | xjohnx (06-01-2014) |
06-01-2014, 12:03 PM | #4660 |
Drives: Subaru BRZ
I installed Delicious Tuning's 8.58 tune and its really nice. Very smooth.
06-01-2014, 04:29 PM | #4661 | |
When I purchased the dual cans from Radium I had them send their universal dual mount, I provided the dual mount and the FT86speedfactory tie down to a aluminum fab shop and asked them to make one flat piece incorporating both. This is what they made me. I had it powder coated and put the sticker Radium provided. I could email you the design drawing if you send me your email. Last edited by Lawnik; 06-01-2014 at 04:49 PM. |
The Following User Says Thank You to Lawnik For This Useful Post: | Boxer486 (06-04-2014) |
06-01-2014, 11:52 PM | #4662 | |
Road Warrior
The Following User Says Thank You to Ryan86 For This Useful Post: | Lawnik (06-02-2014) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
