View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 03-23-2015, 11:23 AM   #4621
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Jfheisenberg View Post
I been reading this theard and this issue looks to be related to the high preassure pump. I always run shell vpower btw...
Thank you for reading. Yes, it is. Grade of gas doesn't seem to matter, although ethanol may or may not be a factor. Ambient temperature may be a factor as well (it has been in my experience at least).
It has priests in it?
Old 03-30-2015, 02:41 PM   #4622
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Wow this thread is still going. Besides the noise has anyone have actual fuel pump failures? From reading the latest posts looks like this is still an on going issue.
Hanzo is offline   Reply With Quote
Old 03-30-2015, 02:44 PM   #4623
HunterGreene
Hail Magnet
Old 03-30-2015, 03:08 PM   #4624
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Apparently crickets are popping up on the new Lexus RC-F ...that should attract some attention from Toyota
http://www.clublexus.com/forums/rc-f...ing-noise.html
rmjjensen is offline   Reply With Quote
Old 03-30-2015, 03:21 PM   #4625
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
I was wondering what the C stood for. Coupe was too obvious.
Old 03-30-2015, 03:23 PM   #4626
HunterGreene
Hail Magnet
Must...resist....urge...to sign up and troll...
EDIT: I just read through the genesis of their thread. Its like taking a stroll down memory lane. They even have some people already confusing the fuel tank pump (low pressure) with the HPFP.
Old 03-31-2015, 02:09 PM   #4627
srizzors25
Daedalus Moto
srizzors25's Avatar
Originally Posted by Decay107 View Post
Solved: $0.10 Engine Chirping Fix.
I think I should make a DIY
I had another big fix I think this will make history
Old 03-31-2015, 02:16 PM   #4628
What works for me I guess (only had them 3 days one time)
Old 04-21-2015, 09:20 AM   #4629
elyugi1
Drives: raven black
I drive a FR-S 15 i use to put gas in 76 and shell but i stop and only pumping in shell v power after 3 or 4 tanks of v power i guess it flush the mixture of gasoline..and chirps went away...this weekend had to pump 76 and chirping sound came back so it figueres that shell v power is doing the trick for my..i always pump same gas station and same pump hope it helps...
elyugi1 is offline   Reply With Quote
Old 04-21-2015, 09:27 AM   #4630
HunterGreene
Hail Magnet
I think punctuation would be a bigger help. However, people have gotten chirps on v-power as well.
Old 04-25-2015, 07:25 PM   #4631
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
10,000 Miles, light squeak around the ABS/Drives side (USDM spec car).
So, should I worry about it? It sounds like a super common problem, read around some are saying it's the Direct Fuel Injector also?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-29-2015, 11:01 AM   #4632
rucfj159
Drives: 15frs 89volvo765&780
1800 miles and just noticed the crickets this morning. damn
rucfj159 is offline   Reply With Quote
Old 04-29-2015, 11:02 AM   #4633
HunterGreene
Hail Magnet
Welcome to the club. You'll get used to them.
Old 04-29-2015, 11:04 AM   #4634
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
I got them after 300 miles. The only time I've not had them is when I'm running e85. 22k miles at the moment and still chirps on 91/93. I'm on my third HPFP replacement. I gave up a while ago on replacing them
Kronos is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
