#4607 |
The Dictater
Drives: '13 Red Scion FRS
TIL ichi is still alive. It's a good day.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 8 Users Say Thank You to Spuds For This Useful Post: | bcj (11-09-2022), Dadhawk (11-08-2022), ichitaka05 (11-08-2022), NoHaveMSG (11-08-2022), pope (11-09-2022), soundman98 (11-08-2022), Ultramaroon (11-08-2022), x808drifter (11-09-2022) |
#4608 |
#4609 |
Because compromise ®
Drives: Red Herring
#4610 |
The Dictater
+5hp right?
Edit:. Why does the forum make pictures ginormous even after I crop them down...
The Following User Says Thank You to Spuds For This Useful Post: | bcj (11-09-2022) |
#4611 |
You need to reduce the resolution. Although that one really does make the orange peel pop.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#4612 | |
The Dictater
The Following 2 Users Say Thank You to Spuds For This Useful Post: | Tcoat (11-08-2022), x808drifter (11-09-2022) |
#4613 |
Drives: Crapcan
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | Boomerang (11-09-2022), Dadhawk (11-09-2022), soundman98 (11-08-2022), Spuds (11-08-2022), Tcoat (11-08-2022) |
#4614 |
Do I need to go on my rant that the paint isn't too soft but too hard again?
DO I?? ![]() And orange peel is from drying too fast not hardness anyway. Bad bad meme.
#4615 |
Drives: frs
It's soft, the only way to keep it "mar" free is not washing the car
#4616 |
Drives: 2017 BRZ
Vinyl is soft. Go ahead, try to scratch it.
Also I'm in for the rant. I think I know where it goes but I don't think I've heard this one before.
#4617 | |
chicken tonight
Or you can upload them to imgur and post links to the image (not the post.) For instance, here's my upload of your image to imgur. h.t.t.p.s://i.imgur.com/T40MeHZ.png ![]() Then I append the file name with g (giant), l (large), m (medium), and s (small) h.t.t.p.s://i.imgur.com/T40MeHZg.png h.t.t.p.s://i.imgur.com/T40MeHZl.png h.t.t.p.s://i.imgur.com/T40MeHZm.png h.t.t.p.s://i.imgur.com/T40MeHZs.png we get ![]() ![]() ![]() ![]()
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | Boomerang (11-09-2022), Captain Snooze (11-09-2022), soundman98 (11-09-2022), Spuds (11-08-2022), Tcoat (11-09-2022) |
#4618 |
The Dictater
Testing this album thing...
#4619 | |
1st86 Driver!
I miss about 25% of the photos on here because of that, through two different companies that have had the same policy on imgur.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Tcoat (11-09-2022), Ultramaroon (11-09-2022) |
#4620 | |
2011 the world agreed to ban many solvents that produced high levels of Volatile Organic Compounds (VOCs) Most of the automotive paints in use at that time used these VOCs The companies scrambled to replace these with approved solvents usually water or alcohol based instead of xylene and acetone The new solvents often did not work well with the old application systems The results were heavier orange peel (forced to dry to fast) and hard, brittle, coatings due to the loss of elasticity because of the different flash off of the solvents The Subaru plants in Japan are still using the old application systems so have paint "issues" The newer Subaru plants in the US are using updated equipment and do not have paint issues (I doubt you could chip the paint on my wife's Ascent with a hammer although I am not going to attempt it as proof) The assembly plants pump cars through as fast as possible meaning they force the paint dry. With normal cars they make money on volume not mark up. This is why you will often see "better" paint on low volume, high markup cars such as Porsches and Mercedes. They aren't using a higher quality paint they just have the time to let it dry slower and maintain that flex. The "softer" the paint the more resistant to scratches and chips it will be since it will flex instead of being damaged. You could not make a paint "hard" enough to resist chips. Throw a rock at a piece of glass (hard) and then at a pillow (soft) and tell me which takes more damage!
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | cjd (11-09-2022), Dadhawk (11-09-2022), NoHaveMSG (11-09-2022), soundman98 (11-09-2022), Spuds (11-09-2022) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
