Old 06-05-2014, 03:35 PM   #449
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by Dezoris View Post
I am on the 4th rev of the SD tune for Vortech, I don't want to get into impressions but wanted to find what others with FI, namely SC, thought of the throttle response and drivability was on the street so far?
I currently have a MAF tune from Visconti, and as soon as I get my SD tune from Delicious I can give you some impressions.
post_break is offline   Reply With Quote
Old 06-05-2014, 04:32 PM   #450
protpibe
protpibe's Avatar
I've had the tune for a little while now. Driveability is pretty good. There were some initial hiccups like high idle when decelerating in gear, and the odd rough spot when sharply getting on the throttle. Those issues are about 95% solved right now and I would say I'm pleased overall. Driving around town is very near OEM in that there isn't a giant power surge as soon as your RPM's get into spool range, and the idle is also rock solid.
I would STRONGLY recommend ECU controlled boost to anyone that is running a Turbo setup. Being able to swap between maps and boost levels with the cruise control stalk is awesome.
I'm running an AVO turbo at 7psi and 10psi.
Old 06-05-2014, 04:56 PM   #451
GremlinGSP
I just got my SD tune going Tues. I'm running an AVO kit and the Delicious EBCS.
So far its pretty good. After I drive it some more I should be able to get some better feedback. protib's description is pretty accurate as to what I've noticed as well.
GremlinGSP is offline   Reply With Quote
Old 06-07-2014, 12:08 PM   #452
protpibe
protpibe's Avatar
Here it is at 10psi 94 Octane - SD Tune
Old 06-08-2014, 10:51 PM   #453
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
What injectors are you running?
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 06-08-2014, 10:56 PM   #454
protpibe
protpibe's Avatar
Stock injectors
Old 06-08-2014, 11:06 PM   #455
pixel67
pixel67's Avatar
Stock injectors
Cool. That dyno plot is uber smooth for a turbo!
Old 06-10-2014, 01:26 AM   #456
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Not bad for a Flash and Go map. Glad to see it is running well. We are still working on refining the tune a bit more as there seems to be some smaller areas in the tune that need refining.
For those of you that want a true stock feel, I completely feel you. I do too, but do realize this is a naturally aspirated vehicle we are converting to forced induction, then converting it to SD with RaceROM features added and setting it up to run on almost any system. Along with switchable boost maps and FlexFuel added into the mix. This is not something you make over night and it does take some time to dial in that perfect tune.
Just want everyone to know it is constantly in development but the power is there (as seen above) and the timing values are solid, dynamic advance is great, boost is controlled and all that is really left is getting the fueling proper. I would say the hardest part is dialing in the fuel, as we are using both direct and port for our tunes even while boosting, and it gets a bit complicated the way we have set it up.
Anyway thank you everyone for your patience and hopefully things are little better not then they were a month ago, as we are getting settled in our new shop and keeping up with customer requests.
Cheers,
William Knose
Old 06-10-2014, 01:44 AM   #457
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Anyone with N/A Stg2 Tune dynos? ...please post
fooddude is offline   Reply With Quote
Old 06-10-2014, 11:13 PM   #458
DeliciousTuning
Hey fooddude, next week we plan on getting my car on the dyno to get some stock baseline runs..no tune. She's been stripped down to factory format. After that run we'll be adding our stage 2 tune and parts in...including a JDL EL header, Crawford Billet Power Blocks, and possibly an Airaid intake. The hopes are to have results of a completely stock car untuned, stock car on stage 2, 91 and E85, and then with all the fancy parts
Sincerely,
Old 06-10-2014, 11:16 PM   #459
DeliciousTuning
Did I mention we're working on something very special of our own?
Sneak Peak:
@JDLAutoDesign
Old 06-11-2014, 12:05 AM   #460
acro
Drives: GT-86
Sincerely,
Zach
What about a stock car on stage 1 as well.
Would be good to be able to compare stage 1 and 2 tunes on 91
acro is offline   Reply With Quote
Old 06-11-2014, 12:13 AM   #461
DeliciousTuning
As stated earlier, while the difference in Stage 1 & 2 tunes may have been noticeable a while back, they both make virtually the same power as of late. The variation is going to be in the specific mods on your vehicle. The intention is to have one "stage" that is simply customized for whether or not you have a header (and which one), intake, and any other NA power mods such as billet power blocks, etc. This will be represented in the difference between our stock untuned, stock tuned, and modified tuned charts.
Again, we hope to knock these tests out sometime next week.
Sincerely,
Old 06-11-2014, 12:35 AM   #462
fooddude
Sincerely,
Zach
Awesoooome saaauuuce
Nice! Sounds very exciting and great you're dyno'ing with different levels of mods.
Will this be on the dynojet or mustang?
Just one request...while you're doing a dyno per level of mods that you've mentioned, can you do one with headers and drop in only (+tune of course.and maybe any additional exhaust bit if you want)...ie: a dyno level with header but no BPBs (since I think not everyone is interested in those blocks, and there's more interested in just the headers, etc)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
