Old 10-23-2013, 07:54 PM   #449
ThisGuy919
Just got mine in today . stage 1 is fantastic already... cant wait to see how stage 2 feels. cmooooooooon release!
ThisGuy919 is offline   Reply With Quote
Old 10-23-2013, 08:10 PM   #450
akyp
Drives: 2012 86
@shiv@vishnu, did you receive the stock ROM of ZA1J700G that I've sent? The email got bounced back so I sent it twice.
akyp is offline   Reply With Quote
Old 10-23-2013, 08:16 PM   #451
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes I believe I do. Got 2 roms to work through ahead of yours but I should have it supported by the end of the work week
Old 10-23-2013, 09:02 PM   #452
akyp
Drives: 2012 86
Thanks. Was just wondering if I need to send again. Take whatever time you need. I work in software industry so I know this kind of work shouldn't be rushed.
Old 10-23-2013, 09:13 PM   #453
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Keen to see your results. What mods are you currently running?
Fizz is offline   Reply With Quote
Old 10-23-2013, 09:23 PM   #454
akyp
Drives: 2012 86
Only mods so far are TRD chassis stuff, brake lines and pads.
I think it's worth mentioning my ROM reading experience: After the reading was done, the doors wouldn't lock. After a few minutes of double-checking the doors and boot were properly shut, I switched back on the ignition then off, and now the doors would lock. For what it's worth my car has push-start button.
Old 10-23-2013, 09:48 PM   #455
8686
8686's Avatar
Drives: 86
The same exactly happened to me and I also have a push-start buttin.
also waiting for @shiv@vishnu to work on my stock ROM file # ZA1J700K I sent yesterday
Sent from my iPhone using Tapatalk - now Free
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 10-23-2013, 10:14 PM   #456
scarfo
Drives: gts 86
Has there been any recent mention of when flex fuel would be supported?
scarfo is offline   Reply With Quote
Old 10-23-2013, 10:18 PM   #457
sierra
Drives: Skoda Yeti DSG diesel 4x4
Was that the end of the problem or do you think it needs a keyless map?
Could climate control A/C be a problem?
sierra is offline   Reply With Quote
Old 10-23-2013, 10:44 PM   #458
akyp
Drives: 2012 86
I have yet to drive the car since reading the ROM. Hopefully it's just a hiccup.
I don't think the ECU knows or cares about what A/C is in the car.
Could just be that the car doesn't like something plugged to the OBD port during shutdown. Next time I'll try unplugging the OFT before shutdown and see what happens.
Old 10-23-2013, 11:44 PM   #459
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
That could be it....I remember reading somewhere that any OBDII readers have to be removed prior to shut down . Maybe when you have the time, try it again but this time unplug the OFT first to see whether the same issue occurs.
Old 10-24-2013, 02:07 AM   #460
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by forzajuve View Post
Haha understandable. So in other words, yes...but...no. What is a better dyno that reads true/accurate numbers in that case?
Dynos are just measuring tools. Especially load bearing dynos (Mustang Dyno) that can be configured to provide larger or smaller hp numbers. So comparing different Mustang Dynos is going to provide no useful comparative data. It's also worth mentioning that power gains can be generated by not only making power, but also presenting a baseline (pre-tune) pull that makes low power. This doesn't have to be done will ill-intention as some runs just make more power than others with no changes to the tune.
All the end of the day, regardless of what tuning software you use (OFT, BRZedit or Ecutek), we are all playing with the same tools. So one one option is going to make power power than the other all things equal. That said, I would be hesitant to ever say that X tune makes Y HP over stock. Because that is most certainly not going to be the case in different cars and on different dynos and on different days. I've been doing this way to long to get caught up in the numbers game. Because that is really what it is most of the time, a game.
Shiv
Old 10-24-2013, 05:36 AM   #461
scarfo
Drives: gts 86
sooooo E-85?
Old 10-24-2013, 11:34 AM   #462
Anorax
Drives: '13 BRZ SS
Don't do that. You'll likely throw a CEL. Mine did the same (doors wouldn't lock) after the first read, but not since.
Currently running the 1.3 map and definitely notice the improvement
Anorax is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
