Old 11-24-2021, 07:29 PM   #449
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Me too on the flywheel.
Old 11-24-2021, 07:37 PM   #450
Irace86.2.0
For my turbo setup, I will need to run the wideband 8-20”, or something like that, away from the start of the downpipe. I’ll have to see if the harness will reach. If not then I think I’ll be using the sound tube hole in the firewall to feed the sensor harness through. I can depin and repin it if necessary to get it to fit.
@captain awesome Wiring hopefully won’t be too hard, but it is always the least enjoyable part of all this in terms of figuring it all out. I do like assembling.
Old 11-25-2021, 01:52 AM   #451
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
What are you folks doing with the PVC nipple located on the water pump housing? Vent to intake manifold? There are two ports on the intake not used, I originally planned to just plug them but now thinking one was intended for that. Instructions don't mention any of this.
captain awesome is offline   Reply With Quote
Old 11-25-2021, 08:26 AM   #452
Irace86.2.0
You can do a catch can or not. I’m doing catch cans vented to atmosphere. You would want to circulate it to the intake manifold if not to atmosphere. You will want to vent the valve cover to atmosphere or to the intake pipe.
I welded a -10AN bung. K-motors makes an adapter that is a M14x1.5 to -10AN for the PCV valve delete for people running the system to atmosphere. They also make a press-in adapter to -10AN for the back of the valve cover, but I don’t think there is much room there, which is why Kpower is selling valve covers with the banjo setup.
https://kmotorperformance.com/shop/k...d-k-swap-cars/
https://kmotorperformance.com/shop/k...ngine-k20-k24/
K-Tuned also sells a valve cover with -10 ORB holes.
https://k-tuned.3dcartstores.com/Ven...ver_p_822.html
Radium makes this for the KA24. I contacted them to ask what the OD is on the fitting to know if it would press into the K24 valve cover, even though I have my setup. I’ll let you guys know what they say.
http://www.radiumauto.com/Swivel-Pre...ers-P1943.aspx
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
captain awesome (11-25-2021), ML (11-25-2021)
Old 11-25-2021, 10:25 AM   #453
captain awesome
Wears Pants
Manifold and pipe it shall be. I’ve got a catch can I can use later on if needed.
Old 11-25-2021, 03:04 PM   #454
Irace86.2.0
I need to look at my manifold closer. I know from the instructions that there is a block off plate, and I know there is a spot on the back of the manifold to connect to the brake booster, but I was expecting to find some NPT vacuum ports for a boost signal or whatever. I'll have to look today when I tinker around.
Old 11-25-2021, 04:20 PM   #455
captain awesome
Wears Pants
I totally forgot about the booster. There’s only two ports pre threaded, but 3 dimpled spots for those wanting to tap for extra near the block off plate.
Old 11-25-2021, 04:53 PM   #456
Irace86.2.0
Yeah, I saw those. Maybe I will get a tap and die for NPT threads.
Normally the EBC I have will require a boost source off the turbo that T's to the wastegate and EBC, but I have two ports on my turbo, so no T needed, and I don't want to use the manifold like some do, but like I said, I do have a Defi boost/vacuum gauge that I need a port for. I could also run a T off the brake booster, which is probably going to be much easier with less chance of failure or damaging the manifold. I just need a large to small brass fitting like these ones. Sorry, just thinking out loud.
Old 11-25-2021, 05:03 PM   #457
Irace86.2.0
I created this in the tuning subforum. There is surprisingly little information on Haltech here. I don't know if the Kpower base tune is locked or unlocked (I'm assuming unlocked because it is a base tune), or if someone wants to add larger injectors, Haltech is sophisticated enough to allow someone to select from popular, pre-scaled injectors from a drop down menu, and they are set. Hopefully someone will be able to answer my and anyone else's tuning questions.
https://www.ft86club.com/forums/show...97#post3484397
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 11-25-2021, 05:53 PM   #458
captain awesome
Wears Pants
I’ll follow along there as well. Hoping the base tune is unlocked so I can scale for e85. Sure would be easier to get some dyno time on 91 first and then e85.
The Following User Says Thank You to captain awesome For This Useful Post:
Irace86.2.0 (11-25-2021)
Old 11-25-2021, 06:31 PM   #459
ML
ML's Avatar
Drives: 13 White MT FR-S
I’m doing the same with some dw 1000cc injectors. Dw supplies the data you need like dead time and you need to go in the ESP haltech software find the fueling table and update the table with the correct data from the injector manufacturer. You need to scale the map too if you have a larger one
Also it’s not like ecutek. You buy the hardware and then everything else is wide open
The Following User Says Thank You to ML For This Useful Post:
Old 11-25-2021, 06:43 PM   #460
Irace86.2.0
Oh yes, 4bar map sensor too. Lol
Old 11-26-2021, 05:40 PM   #461
Irace86.2.0
If someone can verify the diameter of the rear valve cover vent then Radium will tell me if their other press-in fittings will work. Mine was tossed when I welded the hole shut.
Old 11-26-2021, 11:03 PM   #462
captain awesome
Wears Pants
A hair over 15mm on mine.
Irace86.2.0 (11-27-2021)
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
