#449 | |
Drives: '06 AM V8V Coupe
Around 500hp on the LT1 is what I am reading from reasonable cam grinds. The C8 probably has somewhat similar cam specs. Any more intake duration/overlap would probably produce unacceptable loss of torque and worse idle to the OEM. The OEM is also not going to be able to use different headers since they have emissions to worry about. How is 495hp @ 6450rpm not close to maxed out (rev limit is at 6600)? The C6 Z06 only spun to 7000rpm with titanium valves, this engine is not going to spin any faster without that kind of trick. Last edited by serialk11r; 07-20-2019 at 04:55 PM. |
#450 | |
The Dictater
Drives: '13 Red Scion FRS
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#451 | |
Drives: 2018 BRZ tS
IMO - A track warranty (if you track) is too HUGE to pass up to be chasing some minor gains in HP (particularly if trying to argue a modded C7 over a C8). If Subaru told me I could have tracked my car and kept my warranty on my tS, my car would be in a very different situation. I know at least one of you is going to mention committing insurance fraud, so just bite your tongue/hold your breathe if you think you can use a factory warranty when tracking your twin. |
#452 | ||
Because compromise ®
Drives: Red Herring
I don't understand why you have quoted my flippant post. ![]()
#453 | |
Panda Trueno
Drives: No twin now.
That engine isnt close to being "maxed out" from the factory. Tuning is a question mark on this new platform but a cam swap and some headers and tuning can easily net some real power traditionally. There have been "recipes" to make 500 whp with basic naturally aspirated mods on the ls1 for years.... we are well beyond that at this point with the current generation of motors. Also they'll use that motor as a platform to build on and a hand built version or a boosted version will come out in a couple years as a higher trim making more hp from the factory. Traditional gm stuff. |
The Following User Says Thank You to Summerwolf For This Useful Post: | Tokay444 (07-21-2019) |
#454 | |
This is close to as much power as Chevy can give you in an NA engine from the factory without titanium valves. OEM concerns because...The more power it makes from the factory, the less bang for buck you get from swapping in aftermarket stuff, which is expensive. The comparison with a cammed C7 is because the C7 is cheaper. It's clear to me that there's much less to gain from a cam swap than in the LT1, given how the power has moved to the higher rpm ranges, and it's probably a bad idea to "add more cam" given where the power peak sits. I would not mess with the intake ports on a direct injection engine. More duration reduces low end torque, more lift reduces low speed efficiency and stresses the valvetrain more. My guess is this is an LT1 with slightly modified intake/combustion chamber and slightly longer duration intake cam, while the LT1 has a somewhat conservative cam in it. Headers yes, but that's not something the factory can do, and it's not emissions legal in states that care about it. C7 and C8 are on equal footing here, they both can pick up similar gains for similar money. Last edited by serialk11r; 07-20-2019 at 11:02 PM. |
#455 | |
Panda Trueno
Why is titanium valves a big deal in your statement anyways, GM has used all sort of materials from the factory and the aftermarket has any option available. Point is, how can anything be "clear to you" when gm hasnt realeased specs for the lt2? Nobody knows what's been changed or cam specs yet. Safe to say it's not a motor that's maxed out from the factory though. Based on history at least. |
#456 |
Drives: 2015 FRS - FFR GTM
Speaking of headers... these are pictures from the Chevy website. 2020 Corvette motor
2015 FR-S - One Day I'll Finish The Swap |
The Following 6 Users Say Thank You to gtpvette For This Useful Post: | Irace86.2.0 (07-21-2019), Rampage (07-21-2019), serialk11r (07-21-2019), Sportsguy83 (08-07-2019), Summerwolf (07-21-2019), unhappymeal (07-21-2019) |
#457 |
Drives: 2018 Miata RF, 2017 Golf R
#458 | |
495hp @ 6400rpm is 80hp/L at a specific torque of a little under 90Nm/L. A 2 valve/cylinder direct injection engine is not going to do much better than that from the factory, since they have to put crappy short headers on for emissions. Note that the C6 Z06 produced very similar peak numbers at similar rpms with 13% more displacement but without VVT. The design differences (MPFI vs DI, VVT being the most important) you would expect to account for all of that. Essentially, through cam phasing the max retard intake/max advance exhaust position is "more aggressive" than the LS7 pushing the power higher up, and they've possibly done work to the intake ports to trade off a little low end combustion stability for flow. Titanium valves are a big deal because they add several k to the engine's cost and would indicate a much more serious effort at performance. If it lets the engine go to say 7300rpm, I'd expect 530-560hp @6.9-7krpm depending on how the intake manifold is set up. I'm not saying this engine won't go higher than that (more money always helps), I'm just saying this is a pretty good effort from the factory considering they didn't spend crazy money. Last edited by serialk11r; 07-21-2019 at 12:56 PM. |
#459 |
Drives: Q5 + BRZ + M796
There are many more videos...
[ame]https://www.youtube.com/watch?v=cKMP_i-5XZI[/ame]
[ame]https://www.youtube.com/watch?v=UmI4wCniT1k[/ame] [ame]https://www.youtube.com/watch?v=k0FjkvFQcso[/ame] [ame]https://www.youtube.com/watch?v=EIi8xrI068A&t=1s[/ame] [ame]https://www.youtube.com/watch?v=Bffra1n68Nk[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | humfrz (07-21-2019) |
#460 |
1st86 Driver!
I am eating my words...it's better looking than I expected...its cheaper than I expected...its faster than I expected...the interior is better than I expected....
I was hoping this would drive down C7 prices (and it will) but now I have to think long and hard because supercar....
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 07-21-2019 at 06:24 PM. |
The Following 7 Users Say Thank You to Dadhawk For This Useful Post: | FR-S.13 (07-21-2019), funwheeldrive (07-21-2019), HachiRokuX (07-21-2019), Lantanafrs2 (07-21-2019), maslin (07-21-2019), Rampage (07-21-2019), why? (07-22-2019) |
#461 |
I read an article that makes it sound like a manual isn’t in the foreseeable future if ever. The Supra doesn’t stand a chance being so close in price to this thing. Seems a manual gearbox would at least give them one thing to market with.
#462 | |
Panda Trueno
The Following 2 Users Say Thank You to Summerwolf For This Useful Post: | maslin (07-21-2019), Sportsguy83 (08-07-2019) |
Chevy Camaro Mid-Engine anybody? | Impureclient | Other Vehicles & General Automotive Discussions | 42 | 03-14-2020 08:19 PM |
Chevy Bolt? What do you think? | EAGLE5 | Other Vehicles & General Automotive Discussions | 41 | 09-02-2016 03:38 PM |
Mid-Engine C8 Corvette Mule Spotted | Sideways&Smiling | FR-S / BRZ vs.... | 16 | 01-09-2015 09:30 PM |
BRZ vs Chevy SS | Razz | FR-S / BRZ vs.... | 109 | 03-07-2013 08:09 PM |
