, dpfarr
Old 07-15-2022, 11:53 AM   #4593
B T
Just wanted to share this wonderful photo of the ACEA350 header breaking apart at the flange. No response from ACE after weeks.
https://photos.app.goo.gl/cijtjhUaGsYWxrDM7 I still haven't learned how to add photos, lol
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
FrickingReallySlow (07-18-2022)
Old 07-15-2022, 12:00 PM   #4594
bhmax
Drives: 13 BRZ, 17 Focus RS
Had that start happening to mine a couple years ago. Went through CSG for warranty. Took 6 months or so due to covid stuff. Got it welded in the meantime. The replacement has thicker flanges.
bhmax is offline   Reply With Quote
Old 07-15-2022, 07:04 PM   #4595
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Do all ace headers come tack welded at the flange like that?
aKaGorganZola is offline   Reply With Quote
Old 07-18-2022, 10:51 AM   #4596
B T
That's how mine came. welded seam inside and tack welded outside. These headers have been terrible since the beginning. Going to get them fixed and sell them cheap.
Old 07-18-2022, 07:54 PM   #4597
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Idle issues with delicious tune
Idle will jump to 1.5k for about 3 second when stopping, drops to 600 for 3 second then evens out. The delicious tune had thrown CELs before. They fixed it but I'm again getting issues and had two ignition codes (which didn't pop on the ECUTEK DTC scan)
I'm wondering about the crankcase breather, behind and under the AC (black hard plastic with 2 hoses.) In the Edelbrock manual it's listed as a PCV valve. I get air movement both ways through the line that connects behind the air filter to that... Valve? Is that normal, or is it supposed to be one direction?
I have logs also if anyone's willing to help me out. To large for datazap, so I'll need to email them or something.
Edit: also have oil at the left timing chain gasket and coming out from where the oil filter threads on. Like it's blowing past the seal on the bottom of the filter?
Thanks for y'all's help in advance. Daily driver with issues is a problem lol.
snowtaipan is offline   Reply With Quote
Old 07-19-2022, 11:46 AM   #4598
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
I had the idle issue with the sprintex a couple weeks ago, Was told by delicious to do an idle relearn and it fixed that issue for me. Could be worth a try for you as well.
EvilPenguin04 is offline   Reply With Quote
The Following User Says Thank You to EvilPenguin04 For This Useful Post:
snowtaipan (07-22-2022)
Old 07-19-2022, 12:29 PM   #4599
snowtaipan
snowtaipan's Avatar
Do you have the idle relearn procedures handy?
Old 07-19-2022, 02:41 PM   #4600
EvilPenguin04
Not handy, you can search for them here or on youtube work computer has that blocked or I would have a link for you
Old 07-19-2022, 05:34 PM   #4601
FunnyGopher
Drives: 2015 BRZ Limited
I had this exact thing happen to mine just a few months ago! I had it rewelded at a local shop. I'll grab the pics when I get around to it.
EDIT: Looking closer at your picture, my header definitely has some meatier tack welds than yours. I do believe I remember reading there was either some quality discrepancy at some point somewhere on the forums.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 07-20-2022, 01:15 AM   #4602
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Later versions did beaf up the welds. Mine was bought as a second hand repair. Inner fractures. I rewelded to be stronger.
Old 07-22-2022, 06:18 PM   #4603
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
I had idle issues kinda similar to yours and replacing the vvt solenoids/oil control valves fixed that issue. Never had any oil escaping issues though.
apatel471 is offline   Reply With Quote
The Following User Says Thank You to apatel471 For This Useful Post:
Old 07-27-2022, 11:33 PM   #4604
Windycity
Drives: 2013 Scion frs
Hey guys, I am not sure if this has been covered, but I purchased a used Edelbrock kit with the ECUTEK cable and dongle. Will I be able to use this for the standard tune or will I have to request or purchase a new tune?
Windycity is offline   Reply With Quote
Old 07-29-2022, 10:54 PM   #4605
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Another soon to be grinning SC owner !
pages 8-11 (to step 20) of the installation manual will guide you
https://edelbrock-instructions-v1.s3...brock/1556.pdf
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
The Following User Says Thank You to Brewster For This Useful Post:
CSG Mike (07-29-2022)
Old 07-31-2022, 06:13 PM   #4606
B T
Slapped the JDL 4-2-1 header on yesterday morning and I have to say I'm deeply impressed after using the ACE unit. Everything fit great, the bolt and nut locations were all very easy to access and the header/overpipe were very well made. It really makes me question the integrity of the header from ACE in every aspect. If you're on the fence about one or the other, jus go with JDL and save yourself from headaches. I contacted ACE about their awful welding job a month ago and they never bothered to respond. JDL was very responsive to my questions.
Teseo (08-08-2022)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
