#4593 |
LMGTFY
Drives: 13 FRS, 91 Miata
Anyone have MSFS and wanna join me in a flight from Haneda to JFK?
#4594 |
The Dictater
Drives: '13 Red Scion FRS
Finally building a new gaming PC. Have everything except a GPU. Considering a 4090 of some sort. Anyone want to try to convince me to not spend more on a GPU than the rest of the PC?
Rest of build if anyone is curious: https://pcpartpicker.com/list/2rcvjH Right now, cost to me after tax and discounts is sitting at $1,225 before the GPU. Was originally trying to get below 2k total, then I saw shiny things and here we are looking at a $3k PC...
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#4595 | |
"No PC Build Budget survives the first visit to the parts catalog"
-Me, with every computer I've ever built. Quote:
My typical build uses a GPU one level down from whatever the "latest and greatest" is, and that usually serves me fine. Typically I do a mid-cycle GPU upgrade so I rinse and repeat. I'll probably be due next year.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | soundman98 (10-16-2023), Spuds (10-16-2023) |
#4596 | |
The Dictater
Your strategy was the same as mine on my last PC, circa 2013. I upgraded the GPU RAM and CPU cooler in 2018. First was a 460ti boost, which is mid tier and better than nothing, and then upgraded to a 1080 (non-ti). It ran most games at 4k but I had to make compromises on quality in some cases.
| The Following User Says Thank You to Spuds For This Useful Post: | Dadhawk (10-16-2023) |
#4597 | |
Drives: 2017 BRZ
#4598 |
Hadn't really thought about RT to be honest. It doesn't do much for me when I look at side-by-side videos. If I had it, I'd use it, but for now I don't miss it.
#4599 | |
The Dictater
Inflation... The problem with that is that all gpus are overpriced I think. Combine actual inflation with hot electronics market, low availability, high risk, high interest rates, straight up greed, etc and that's what happens. The only way not to support it is to not play. And that means use integrated graphics lol. I'd love to beat the system, but I don't think that's in my power at the moment.
#4600 | |
Pavement Grey
Takes an enormous amount of GPU power to utilize at acceptable fps and even then only nvidia cards can do it acceptably. AMD hardware doesnt have the dedicated hardware like NVidia does to do it so they'll never use it at the same performance level until they do their own hardware implementation. It'll take a couple more GPU generations until RT Is good enough on 'not overprice overpowered hardware that mere mortals cannot afford" class GPUs. Plus the implementation of RT hasnt exactly been eye meltingly "must have" yet. My RX6600 can do RT but i think its mind numbingly slow......yeah im not even going to try. Plus i dont have any games that use it so theres nothing really i can make comparisons anyways. When it starts hitting mainstream im sure devs will have figured out how to make RT more than just a pretty filter and then we might be able to see the real fruits of its labour. |
#4601 | |
Drives: 2017 BRZ
As for pricing... Nvidia is still more brazenly pricing high. Agree that they're not alone. Maybe step back ambitions with a 7800xt in the near future, I see downward pressure on pricing looking at $700 soon... I'm happy with a 5800x3d and 6800xt. Actually building a second system to replace my struggling 10yr old Ultrabook. Using the 5600x I have on the shelf, but finding the right video card is up in the air. Have a lead on a 580xt but I hear driver support is done, making me unsure now. Don't intend to game on this one really but would appreciate it being able to do the basics in a pinch (like being quarantined in that room as I have been.) Set your budget and be realistic about what you want to do. Don't build to "maybe", the ROI is worse. Then buy, build, and don't look back (or at the market).
| The Following User Says Thank You to cjd For This Useful Post: | Spuds (10-16-2023) |
#4602 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Decided it's time to pull an experiment.
I have a dedicated gaming desktop mini-ITX style. It's the bee's knees for me and gets the job done with anything I throw at it. However, for work, I had to purchase a laptop to do many of my computer-related tasks as the Army and it's wonderful wisdom can't seem to provide me one for whatever reason. I went with an Asus ROG Zephyrus G14 as it has a dedicated graphics card, is compact to carry, and I figured why not? It's specs include a Ryzen 7 5800HS, 16gb RAM, and an RTX 3060 6GB. For the next month, I figured I'd use only my laptop and see how life is with it. I haven't exclusively run a laptop in 10 years, so this should take a little getting used to. To prep for it, I had to upgrade the hard drive from the atrocious 512gb hard drive to a 1TB drive. Did a fresh install of windows, and put all the things I needed to get the computer running smoothly. So far I've gone about a week and it's not been too bad. Going from a 27in screen to a 14in does suck a lot. As well as going from 1440 165hz to a 1080 144hz is a bit of a downgrade for my eyes. The pros, so far, are I can take it everywhere and I don't have to jump between computers for work. It runs very quiet on silent mode, and even in the default mode. Because I did a fresh install, I could get rid of some of the bloatware Asus put on the computer and even changed the Wi-Fi card to a better Intel AX210. It's been super quick with the better SSD and Wi-Fi card. The computer runs the few games I loaded very well with little or no reduction in performance. The most demanding game being Ghost Recon Breakpoint. There are a few cons, however. The computer sports a RTX 3060 so that's a hell of a downgrade (obviously) from the 7900XTX I have. The computer, being slim profile, gets insanely hot when gaming. I'm usually hitting 94-96c for the unit when gaming. Granted, I've only played Half-life 2, Ghost Recon Breakpoint, and Minecraft. Apparently this is normal, and a cooling pad would help. Although I do notice it gets warm just doing idle things. But I attribute that to it being a laptop and my hands are right there. The another con I discovered (and this could be fixable but I couldn't figure it out) was the dedicated graphics card shut off regardless of the computer being plugged in or not. Once I installed Armory Crate, it began working just fine. It's not the end of the world, but it was bloatware I was wanting to avoid. I figured I'd see how this goes for the next few weeks and try some other games I normally play such as Dirt Rally 2.0, Company of Heroes Blitzkrieg Mod, and possibly Metro Exodus (to see if it will cause the computer to light on fire).
#4603 | |
Drives: 2018 Subaru BRZ
RAM, go with 5600 instead of 6000. Intel CPUs, unlike Ryzen, do not depend on fast RAM. Though it should run fine, higher frequency means higher latency, also do check the compatibility with your MOBO. GPU, 7900XTX. Its cheaper, uses less energy, and it would be a beast for 1440 and even native 4K. FSR is also making it way to compete with DLSS. RT is nice, but to this day I have yet to find it as a deal breaker when deciding on GPUs. In any case, say if you wanted to play a simulator, you can still be competitive with 1440p at Ultra settings while pushing 100FPS+. Edit; for consideration, as you may have a preference for Intel. As of the time of writing, there nothing, for pure gaming wise, that beats the 7000X3D configurations from AMD. While they would be slightly more expensive than the 13600K, they consume less power.
#4604 | |
Be Kind
Drives: 2020 86
| The Following User Says Thank You to Wally86 For This Useful Post: | Spuds (10-17-2023) |
#4605 | |
The Dictater
![]() Got a great deal on the Meshify 2 Lite, specifically in white (either someone made a mistake, or really wanted them gone), only reason why I got that particular case lol. Has everything I need and drops features from the Meshify2 that I wasn't planning to use anyway. Might need to swap for something else depending on what GPU I get, but it was cheap enough to not really worry about it. Intel can OC memory. Specifically got CL36 version to reduce latency. Higher clock actually means lower latency in real time given the same spec. Latencies are specified in clock cycles and higher frequency is more cycles per second. FSR doesn't really compete with DLSS yet. Not as widely supported iirc, and still doesn't give good enough performance based on benchmarks I've seen. You are right on the 7900 for 4k rasterization. It's really down to whether I really need to see the ray tracing features as to whether I go 4090 or 7900xtx. RT, games today don't necessarily NEED it to look good, but 3 or 4 years out? We might be looking at larger adoption of the technology in more games where it makes a difference. Yeah I just know Intel stuff better so I went with that for CPU to simplify the decision tree.
#4606 |
The Dictater
Decided to build it with my recently reacquired gtx1080 for the moment. Wife got her rtx4080 installed, that thing is massive!
| The Following User Says Thank You to Spuds For This Useful Post: | Wally86 (10-23-2023) |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
