Old 06-23-2018, 07:18 PM   #45907
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by MuseChaser View Post
Happy to hear dissenting opinions..
About any topic, or just fungii?
Ultramaroon is offline
Old 06-23-2018, 07:25 PM   #45908
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Do I really have a choice?
Drive like everyone's life around you depends on it...
MuseChaser is offline
The Following User Says Thank You to MuseChaser For This Useful Post:
Ultramaroon (06-23-2018)
Old 06-23-2018, 07:38 PM   #45909
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Studs are fixed... but now, my right front brakes are getting stuck. It’s not extremely stuck that it lean towards right, while I drive. BUT there’s a clear temperature diffeerence between left and right. Plus when I lift it and let the wheel spin, I can clear pads are touching more than it should and causing the wheel spin as much. I’ve looked pads and don’t see an issue, so caliper? Man... one after an another issue.
ichitaka05 is offline
Old 06-23-2018, 07:46 PM   #45910
Ultramaroon
not playing cards
What kind of brake? How many pots?
Old 06-23-2018, 07:49 PM   #45911
ichitaka05
Site Moderator
ichitaka05's Avatar
OEM 2 pistons
Old 06-23-2018, 08:41 PM   #45912
Ultramaroon
not playing cards
OEM 2 pistons
How worn are your pads?
If your pads aren't new and you don't mind removing your wheel, can you then compress the inner pad all the way evenly and slowly doing something like this?
Old 06-23-2018, 08:45 PM   #45913
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Went For a little drive this morning. Just not into it today. After 3 days of working on cars my legs and back are aching. Now it is 100°. Zero energy.
Sapphireho is offline
Old 06-23-2018, 08:54 PM   #45914
ichitaka05
Site Moderator
ichitaka05's Avatar
Is that just compressing the pistons back? Is that’s he case, I have the tool for it. I’ll try em out tomorrow.
Also I was thinking of getting KNS Subaru 4/2 caliper kit... but sadly just noticed that they stop selling them.
Old 06-23-2018, 08:57 PM   #45915
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, removing the wheel is what got him into this mess in the first place sooo........
Also, I don't remember if you did any brake work, but if you did you might want to recheck all fasteners. I missed a rear caliper bolt once. Made weird sounds, but the fronts might behave differently?
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Old 06-23-2018, 09:34 PM   #45916
Ultramaroon
not playing cards
Yes but there's more to it. Again, are your pads new, or worn.
If they're new, then your pots are already retracted, but if a bellows was torn when you replaced the pads, the contaminated/corroded pot could have jammed in place.
Doing it the way I show allows you to check your guides like this.
[ame="https://www.youtube.com/watch?v=4xNZu18bxg4"]https://www.youtube.com/watch?v=4xNZu18bxg4[/ame]
Ok, I'm putting mine back together now.
Old 06-23-2018, 09:38 PM   #45917
Ultramaroon
not playing cards
Do it. Do it. Do it. Do it. Do it...
You should use it. I bequeath it to you.
Old 06-23-2018, 09:38 PM   #45918
ichitaka05
Site Moderator
ichitaka05's Avatar
Doing it the way I show allows you to check your guides as well, like this.
I had used pads (75% still left) & put Summer used pads in (85% still left).
Old 06-23-2018, 09:42 PM   #45919
ichitaka05
Site Moderator
ichitaka05's Avatar
When I was driving back from the shop, I smell burnt pads, so when I got home I checked & Shop put the front pads weird. I thought that fixed the problem, but it still doesn’t spin the wheel smooth as driver side. I’ll double/ triple check tomorrow morning.
Old 06-23-2018, 09:43 PM   #45920
Ultramaroon
not playing cards
Did you reinstall them in exactly the same position as you removed them? If you mix-and-matched after they wore unevenly, that could exacerbate the misalignment.
