View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 09-02-2014, 09:17 PM   #4509
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by extrashaky View Post
So last week I took a trip on a tank of the ethanol-free 92 octane gas I found. The crickets disappeared, but my mileage dropped from 34 mpg (on E10) to 30.5 mpg on the E0. Just to be sure, I filled up at Chevron, and my mileage is back up to 34.
Fuck this. I thought it was an interesting problem to try to solve, but I'm going to stick with top tier from now on and not bother with thinking about it any more.
That's pretty weird. Usually going to non-ethanol gas improves fuel economy. In the past I usually got a few more MPG's on average.
smg1138 is offline   Reply With Quote
Old 09-03-2014, 01:16 AM   #4510
extrashaky
Drives: 2014 BRZ Limited
I know. That's why it was such a surprise. Could stale gas cause that?
In any case, I'm done. I'm sticking with the top tier stuff that is predictable, even if the prediction involves crickets.
Old 09-09-2014, 10:13 PM   #4511
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
Well filled up my car at a cheep gas station last week and immediately it started chirping. Very annoying in drive thrus...Just filled up again yesterday at a Chevron and it went away...so far...
InspGadgt is offline   Reply With Quote
Old 09-09-2014, 10:32 PM   #4512
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
~9,600 miles and the chirping is slowly coming back. Some days it will do it, and other days it won't.
On some cold start ups I get a couple weird misfires. I might have to take the stupid thing to the dealer to see if that's normal. (Which I doubt it is.)
Bobblehead is offline   Reply With Quote
Old 09-16-2014, 04:47 PM   #4513
scionforlife
Drives: FRS asphalt
I've got about 3k miles on my FRS, I've had the noise for awhile now. It happens on start up, idle, and in first at low RPMS. I took it in and they said it's normal and all FRS do it. Sounds kinda fishy to me.
scionforlife is offline   Reply With Quote
Old 09-16-2014, 04:57 PM   #4514
Since you are new I will restrain myself!
This is completely "normal"! Not pleasant maybe but not a real problem either. It harms the performance and function of the car in no way whatsoever.
I bet there are a couple hundred threads and dozens of websites that talk about it.
If you read anything at all about these cars before you bought you should not have been taken by surprise.
It may or may not go away with a fuel pump change, different additives, warmer or colder temperatures, different gas or eventually just by time it's self. If you want to spend loads of time there are about a 1000 things you can try (that ultimately never work for long). Otherwise embrace it as part of the car!
Frishkorn (09-16-2014), Ramster (09-16-2014)
Old 09-16-2014, 10:41 PM   #4515
ZZT86
ZZT86's Avatar
Drives: BR86
I was re-fueling the other day when a Mazda 6 pulled up - boy was it noisy ! I later read that it too has direct injection . . . .
ZZT86 is offline   Reply With Quote
Old 09-17-2014, 09:34 AM   #4516
JPFr-s
No chirping for over 20k miles now and have been using strictly 93 octane at Sunoco in GA. Any other gas (BP, Chevron, Texaco, etc.) immediately starts the chirps. Only other guaranteed solution I've found is ethanol free, which I don't have access to locally.. Not 93oct anyway. Just my 2 cents in case anyone cares.
JPFr-s is offline   Reply With Quote
Old 09-17-2014, 01:59 PM   #4517
Have used nothing but ethanol free for as long as owned the car (8000 kms) and never had a chirp. Today got caught low and the only gas I could get was the famous "up to 10%" stuff. Will see if I get a visit from the cricket monster.
UPDATE!!!!!!!!
Less then 100 kms into the first ever tank of gas with ethanol and Cricket CITY!!!!! Now we will see if it goes away when go back to the old fuel!
Old 09-18-2014, 01:15 AM   #4518
litemup
Drives: around
UPDATE!!!!!!!!
No worries. They'll go right back to sleep once you go through the tank. I've gone back and forth a dozen times.
litemup is offline   Reply With Quote
The Following User Says Thank You to litemup For This Useful Post:
Tcoat (09-18-2014)
Old 09-18-2014, 01:19 AM   #4519
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Someone was saying adding 2 stroke oil silent the cricket? Anyone tried that method mind share the result & what kind oil it is exectly?
Sent from my SGH-T989 using Tapatalk
Old 09-18-2014, 07:11 AM   #4520
Good! Don't want to attract spiders you know>
Old 09-18-2014, 09:26 PM   #4521
litemup
Drives: around
Fo sho!
Old 09-23-2014, 10:33 AM   #4522
UPDATE!!!!!!!!
Update on the Update!!!!
Burned through that tank and went back to normal station. Couple of hundred kms and crickets gone! Been almost a week now with no chirps.
Was ready to settle in my own head that it had to be the ethanol as this was the very first time it went into her but then got thinkn'! The station I normally get gas at is on a very busy intersection just off the highway and must go through massive amounts of gas including the premium.
When I needed to get gas and had to use the closest station the only thing available was a small neighborhood 4 pumper. Was going past the station yesterday and thought I would stop by and ask a couple of questions (the attendant seems to live there and is a jovial sort so didn't think I had anything to lose). After explaining what happened (and reassuring him I was not looking for anything but info) I asked him how much of the premium they sold and how often the tank was refilled? He just laughed and said "with the junk they drive around here not often".
We looked at the records and that tank had not been filled since MAY! That was the only record we could find of a fill in 2014 so the gas in the tank already was even older. Don't claim to be a fuel expert but know enough to think that the fuel would degrade well past it's rated octane in 4 months!
Moral of the story is... Try to use gas that hasn't been sitting around for months!
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
