Old 05-20-2015, 02:05 PM   #435
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Originally Posted by gramicci101 View Post
Would it be beneficial for the inside of the horn to be polished smooth, or is it not a big deal? Or do the slight ridges perform some function that I am unaware of?
As far as I'm aware. The ridges are from the manufacturing of the horns. Polishing it would mean less resistance and turbulence I guess.
Sent from my toaster
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline
Old 05-21-2015, 01:53 PM   #436
fika84
fika84's Avatar
@NotEric6.. is this thing installed on your car yet or what??? This suspense is killing me!
fika84 is offline
Old 05-21-2015, 04:03 PM   #437
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Make the manifold slighty higher and add a throttle body to each veolcity stack so you can have debris-less ITB's ;D
cdrazic93 is offline
Old 05-21-2015, 07:56 PM   #438
burdickjp
Drives: 2013 ultramarine Scion FR-S
If that is the case then their CNC programmer has gotten so bored he's doing some very strange things with tool paths.
burdickjp is offline
Old 05-21-2015, 08:43 PM   #439
RJasonKlein
RJasonKlein's Avatar
Originally Posted by NotEric6 View Post
The car has a mid-pipe back aluminum exhaust that likely does nothing for power, I just wanted some noise.
I don't want to hijack your thread, but your aluminum exhaust has piqued my curiosity - can you tell us a little about it and post some pictures? If not here, then maybe on another thread?
RJasonKlein is offline
Old 05-21-2015, 08:48 PM   #440
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm hoping this weekend .
Space is an issue.
It was milled, not turned. So realistically the cut time was the same regardless. If we take this exact design to production (which is very much unsure right now), it will be a turned part.
PM'd
VerusEric is offline
Old 05-21-2015, 09:06 PM   #441
2much
I wanna go fast
Drives: 2013 FR-S 6MT
what aluminum exhaust??
2much is offline
Old 05-21-2015, 10:40 PM   #442
burdickjp
It'd be impossible to do that on a lathe which doesn't have live tooling!
Of course it's milled. It's still a funky toolpath. Maybe they had difficulty getting a conventional path to work and this was the best way they could minimize tooling marks? I'd argue that's what post processing is for. Of course customers would rather see a sexy milled part than something which has been finished by sanding. I'm more of a form follows function kinda guy.
Are you going to finish these prototypes out to a smooth interior surface?
Old 05-21-2015, 11:02 PM   #443
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Space is an issue.
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
civicdrivr (05-21-2015), gramicci101 (05-21-2015), HUNTERANGEL121 (05-21-2015)
Old 05-22-2015, 07:21 AM   #444
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why would it be impossible to turn a bell mouth on a lathe?
Calum is offline
Old 05-22-2015, 10:59 AM   #445
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
obsoive
http://www.ft86club.com/forums/showp...&postcount=129
Awesome! Can't wait to see what this does for NA.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline
The Following 2 Users Say Thank You to phobos512 For This Useful Post:
2much (05-22-2015), Hyper4mance2k (05-22-2015)
Old 05-22-2015, 01:36 PM   #446
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
The right way to make a velocity stack.
[ame="https://www.youtube.com/watch?v=cgnB4bmodv4"]how to make a velocity stack - YouTube[/ame]
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline
Old 05-22-2015, 02:11 PM   #447
VerusEric
VerusEric's Avatar
This can be made without live tooling on a lathe, and was actually designed to be made as a turned piece. To do it in one operation, yes you would need live tooling.
The function of these bellhorns are being blown way out of proportion. Like previously stated, between peak and valley their is only 10 thousandths of an inch difference. We are not concerned that the ridges reduce or add any performance. We will not be sanding them.
It isn't, these are easily made on the lathe .
Originally Posted by phobos512 View Post
This is my own custom aluminum exhaust, neat to see someone offering an off the shelf piece.
There are multiple ways to make a velocity stack or bell horn. As you can see in that video (this is called metal spinning I believe, and is a forming technique), the accuracy and repeat-ability is up to the operator. To us, this is too large a discrepancy from article to article, so we went with a CNC machined piece. Each route has its benefits and draw backs like so many things in life, but there is no right or wrong way.
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Calum (05-22-2015), Hyper4mance2k (05-22-2015)
Old 05-22-2015, 02:24 PM   #448
burdickjp
That's not what I said. I said it is obvious they are milled because the ridges would be impossible without live tooling. Turning bellmouths on a lathe is cakewalk. If you're clever and have some time you can even do it on a manual lathe.
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 02:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-24-2014 12:08 AM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-13-2014 12:40 AM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
