Old 05-06-2014, 10:35 PM   #435
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So, when going into reverse, the image seems cutoff, at least at the top. I'm seeing my bumper just like I did before, but I definitely remember seeing more up top than what's showing now, like I'm having trouble seeing more than just concrete, and the wheels of cars, is there some sort of video calibration I can access? Also, is it just me or are the notifications in the upper bar going off the screen, the top edge of the screen is cutting off all notification text that pops up (like when an app has finished installing or something) but all the other icons are not cutoff... weird.
Deathalo is offline   Reply With Quote
Old 05-06-2014, 11:43 PM   #436
DC2R
Drives: 2014 Scion FR-S
Just installed mine. Freaked out and kept raising volume. Factory reset fixed it.
Honestly wasted most of my time trying to remove the factory bespoke GPS module. Anyone know how to remove that thing?(just left for now but would like to sell my old radio with it).
Spent about five minutes going through menus and that's about it so far....
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-07-2014, 12:59 AM   #437
Deathalo
The top lip of my unit is covering part of the screen, just slightly, but that explains why my notifications are getting cutoff, that's really disappointing since I don't know how to fix that without breaking plastic... As for the mounting holes, my brackets aren't right up against the front touching, but they are only a few millimeters back, I don't see how they could be in any other position but I might double check...
The Following User Says Thank You to Deathalo For This Useful Post:
DC2R (05-07-2014)
Old 05-07-2014, 05:53 AM   #438
eliminist
Anyone know how to get radio to keep the stations you tune to?
It keeps changing once I exit the app.
eliminist is offline   Reply With Quote
Old 05-07-2014, 08:56 AM   #439
Onelifeliveit
Drives: Toyota 86 GTS
Just press and hold the preset button(s) when you are tuned into the station you want
Onelifeliveit is offline   Reply With Quote
Old 05-07-2014, 09:30 AM   #440
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Originally Posted by SHIFTER View Post
This unit SHOULD - but would need fully rewired.
I could do it for a fee.
Wiring isn't an issue, physical dimensions were my worry. Just gotta find/fabricate mounting brackets
ProTekk is offline   Reply With Quote
Old 05-07-2014, 10:22 AM   #441
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Deathalo View Post
Oh, and my AUX port works great now after the pin swaps I made via the diagram I linked.
Do you remember what you put where? The diagram is better than nothing, but I'm still scratching my head.
Prog is offline   Reply With Quote
Old 05-07-2014, 10:26 AM   #442
Prog
Prog's Avatar
Yep, mine is like that too. I never even thought to bring it up here cause it doesn't really affect me except for the rare occasions I have notifications. Unfortunate, nonetheless. These units are great, but no doubt need some refining.
Old 05-07-2014, 11:35 AM   #443
Deathalo
On the diagram, the bottom left 3 pins is what you need to look at. Pin 28 is VAL+ (left channel/white), VA- (ground/black), VAR+ (right channel/red). That's looking at the 28-pin harness wire-side btw, so you'll plug those wires on your SWC harness into the lower right corner.
Well I'm glad I'm not the only one, but it kinda sucks, it's cutting off an important view from my backup camera, where every little bit more I can see counts =/
Old 05-07-2014, 02:29 PM   #444
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
Could you post a picture of what you guys are referring too, maybe we can get an answer from the supplier too? ...
microbionic is offline   Reply With Quote
Old 05-07-2014, 05:52 PM   #445
jskurucz
Yep!
jskurucz's Avatar
Drives: 2015 WRX Sti
Just to be sure.
I read most of the pages and I think that the radio will only run off unit via the Wifi/3g dongle.
Could I use my phone with Wifi tether to allow the headunit to work? Also, will the phone run off internet with bluetooth connectivity. I'm guessing I will need to the 3g dongle to use the internet while driving such as pandora... etc.
jskurucz is offline   Reply With Quote
Old 05-07-2014, 06:33 PM   #446
Deathalo
Originally Posted by jskurucz View Post
Just to be sure.
I guess you haven't read that much, because this has been covered. Wifi tethering works, bluetooth not right now, but you don't need a dongle if you're tethering to your phone....
Regular radio, FM/AM does not need internet, it needs the antenna from your car, just like a normal radio.
The Following 2 Users Say Thank You to Deathalo For This Useful Post:
DC2R (05-07-2014), jskurucz (05-07-2014)
Old 05-07-2014, 06:46 PM   #447
t.chk
Drives: Subaru BRZ Limited
Anyone try wiring up steering wheel controls with this? Have links to someone who has? (even if it is non-BRZ/FRS/GT86)
t.chk is offline   Reply With Quote
Old 05-07-2014, 09:31 PM   #448
DC2R
My OBD2 dongle isn't working. Anyone else. Got a suggestion on buying some new one?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
