#435 |
#436 |
Drives: 2014 Scion FR-S|Whiteout
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#437 |
Rotrex oil cooler bottle
Hi,
Does anyone know how to remove the bottle of the rotrex oil reservoir without leaking it everywhere? I can only think of sucking the bottle dry then remove since the system contain more than the bottle could hold and will have some remaining inside the line.
#438 | |
Basically you're turning it into a gravity pump. |
#439 |
Drives: lexus
Any updates on the smaller pulley??
#440 |
Drives: Fr-S
is the oil reservoir designed to leak excess oil of its overfilled, i seem to be leaking oil from the reservoir after driving for 5 minutes, i topped it off prior and now the oil level is at the 'max' line. thanks in advance
"mr.Balloon hands, no way, get real..."
#441 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I have the KW kit, but same Rotrex blower and reservoir, and am experiencing the same thing. I have siphoned out some SC coolant/oil little by little to the point where I'm right at the minimum level after the car has sat off for a few hours. The Rotrex instructions says to read the coolant level while running the engine between 2k & 3k RPM (iirc) and from what I can tell my level is at about right (half way between min and max) there. Still, I get some leakage from the top of the can occasionally. I think the coolant isn't getting enough cooling in stop & go traffic with it being behind the IC and therefore is steaming up into the reservoir top - but that is just my wild guess. Not sure how many others are experiencing this. |
#442 | ||
"full" is really about just 1 inch from the bottom of the dipstick, for clarification. The fluid shouldn't be overflowing at all. |
#443 |
Curious cat.
Drives: 86 GT base M/T - Red
Ppl always wanting more power.
![]() Are y'all truly revving the crap put of your SC'd cars in every gear and needing more already?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#444 | |
driving smoother faster
Drives: Sold
Jackson Racing Supercharger Owners Thread
I would like to get a little wider power band with JR SC on AT. P&L 4-1 header and cat + P&L overpipe + P&L front pipe and cat + Perrin 2.5" resonated + dyno tune got rid of the torque dip and work beautifully on power but power surge comes at around 5.5k rpm and I'd love to see it kick in around 4 - 4.5k rpm, especially with taller gears on AT. Hope a slightly smaller pulley would help with this. Update 7/14: I no longer wish for a smaller pulley. Went to Mike at moto-east for the first time to try a different tune - completely transformed the car. More than enough power for my (street and track) needs and excellent power band. Last edited by dp1; 07-15-2014 at 09:46 AM. |
#445 |
#446 |
Drives: Asphalt FR-S
So I will be getting this SC in the coming months and have a problem.... Do I get a clutch or an exhaust? Any advocates out there for either direction?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
#447 | |
Which kit? CARB Tune or Do-it-yourself tune kit? I'm on the stock clutch with the CARB Tune Kit, which I believe is a very conservative tune and I have NO clutch problems. Being in PA you won't need a CARB tune kit. So I would spend my money on a damn good tune and an exhaust. I doubt you'll need a clutch... @sklimo chime in my friend. You've got the beast! I'm still on the CARB Tune. Me need MOORREE POWER!
#448 |
Yeah I was going to get the tiy and have it tuned, I was worried about slippage on the stock clutch
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
