#435 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Might be a silly Q, but does it matter if it's left hand or right hand drive?
I like driving!
#436 | |
Perhaps you could help me with a few Q's? 1. Is it easy to install for a beginner (not an experienced mechanic myself)! 2. Rough install time? 3. Shorter throw sounds good... Is it smoother than stock, but still with that nice positive feel? 4. I'm assuming it won't affect an aftermarket drive shaft if I want one in future?
I like driving!
#437 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#438 |
I agree,I went ahead and used the red and so far, so good.
Thanks guys, I thought for sure I was going to yank it out (giggity) but it works great now. The loose bolt was the problem. If your bolt is loose, you don't lose 1st and 2nd, but you really need to wrench it over to the left engage it. Now my problem is it slides so well into those gears and my muscle memory already kicked in for the loose bolt.
2013 Asphalt FR-86 (badge conversion) | TRD wheels | TRD CAI | TRD exhaust | TRD lowering springs | TRD front strut tower brace | TRD door stabilizers | TRD member brace kit | TRD spoiler | TRD quick shifter | TRD door speaker panels | TRD seat gap fillers | GT86 Armrest | Red Perrin Lightweight Pulleys, Drift Button, and Reverse Lockout | Winjet Foglights | Full LED swap | Custom dash and HVAC LEDs
#439 | |
2. About an hour at most. 3. In my opinion, it's much more positive in that you feel it go into gear. It takes very little wrist movement now. 4. Shouldn't. It fits in the same footprint as stock but hangs down about 1.5" more for the adapter. I didn't see it even get close to my driveshaft.
#440 | |
I like driving!
#441 |
Also make sure you have your tools ready. I have hex head sockets which made it easy and definitely have the red loctite ready to go.
#442 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Q: would the whiteline transmission mount bushing interfere with the quickshifter? I don't recall it would.
#443 | ||
I have the kit and driveshaft but have yet to install the bracket piece, I've been waiting to double check this very thing. The aluminum driveshaft I have is different than that poster, but comparing it to the stock driveshaft it is significantly thicker.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#444 | |
I like driving!
#445 |
I wouldn't think so. The bushing is pretty far away from the shifter and a totally different mechanism.
#446 | |
#447 |
DSS aluminum
Sent from my SM-G925T using Tapatalk
#448 |
Drives: Toyota GT86
Do you think this kit would fit a RHD GT 86
Thanks |
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
