#435 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Hahahaha!! Thanks man! I try to be helpful where I can.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Celica00 (01-12-2016) |
#436 |
Drives: BRZ + Ducati M796
#437 |
Drives: WRB Brz / SR S14
Here is his entire interior thread
http://www.ft86club.com/forums/showthread.php?t=41877 |
| The Following User Says Thank You to drew_kar For This Useful Post: | Irace86 (01-24-2016) |
#438 |
Drives: 2013 Scion FR-S in White
Gauge Pods?!?
![]() Here is my setup. 52mm Defi Boost gauge. Just ended up using the universal mount with the double sided tape. I ordered the Craven Speed mount but really did not like how high it would have put the gauge. In comparison the cravenspeed would have been about an inch higher. I actually would love a smaller gauge than this one but its fine. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to HuntingtonFRS For This Useful Post: | tfp (08-12-2019) |
#439 | |
Drives: anything you let me
And honestly, on track, warning lights are MUCH more effective for getting your attention than gauges. If you have to rely on gauges only, it's also a good idea to rotate them (if possible) not so the text/numbers are readable or aesthetically pleasing, but so that under ideal operating conditions all the needles point the same direction (generally straight up). This way a quick glance tells you go/no-go and your eyes are back on the track. |
| The Following 2 Users Say Thank You to Uplink For This Useful Post: | go_a_way1 (03-18-2016), Hostile_Kittens (04-30-2016) |
#440 | |
Not Bаnned Anymore
and my gauges change colors at my preset levels and will even flash at me if I reach the 2nd warning level.
#442 |
Not Bаnned Anymore
autometer elite series. I HIGHLY recommend them.
Edit: you can even wire up an audible warning if you want |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Uplink (03-18-2016) |
#443 | |
| The Following User Says Thank You to Uplink For This Useful Post: | go_a_way1 (03-18-2016) |
#444 | |
Not Bаnned Anymore
#445 |
Vtec Jesus
Subed
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
#446 |
Drives: 13 Scion FR-S
#447 |
Drives: GT86
I know a couple of guys who have done it that way and the answer is yes, they had to drill a hole into that "wall".
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday |
| The Following User Says Thank You to Iceman For This Useful Post: | FutureFT86 (04-14-2016) |
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 06:46 PM |
| LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 07:19 PM |
| Gas Gauge Issue | Jruex22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-04-2013 11:28 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 05:29 PM |
| Gauge Sweep? | himbo | BRZ First-Gen (2012+) — General Topics | 17 | 12-12-2011 12:39 PM |
