Old 04-19-2021, 05:20 PM   #435
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
You have an actual fob or the key with the buttons?
Yeah I think the button version would not use power being close to the car
gen3v8 is offline   Reply With Quote
The Following User Says Thank You to gen3v8 For This Useful Post:
Ultramaroon (04-19-2021)
Old 04-19-2021, 05:32 PM   #436
Ultramaroon
not playing cards
Ultramaroon's Avatar
Interesting because mine still has the original 2012 battery in it.
Both my keys still have factory cells. Still good for over 100 yards.
gen3v8 (04-19-2021)
Old 04-19-2021, 06:00 PM   #437
The key with button doesn't send a signal unless the button is pushed. The car only looks for the security code when you start it. This is close proximity and no broadcast is required.
The remote entry feature of the fob means it is sending a signal to the car saying "I am here you can unlock now" all the time even when not actually near the car. This is why the interior lights come on when you are about 6 feet away from the car and just touching the handle opens it up.
Naturally the fob uses way more power to send the signal all the time. Three or four years is pretty good for a broadcast fob and the normal key should get maybe three times that.
Dadhawk (04-19-2021), gen3v8 (04-19-2021), Spuds (04-19-2021)
Old 04-19-2021, 06:37 PM   #438
I thought about that after I posted my response. I guess I always thought the fob worked like an RFID tag where it only sends a signal when the receiver "energizes" it.
Old 04-20-2021, 05:31 AM   #439
JD001
JD001's Avatar
Drives: Subaru BRZ
Yes, a key fob with buttons but I don't press anything, as soon as I grab the door handle the car unlocks (that's assuming that the fob is in my pocket and the car battery is tip top)..
Old 04-20-2021, 05:50 AM   #440
So a remote fob.
The FRS has the actual key with buttons which is the difference. You have to take the fob out and push the button to unlock the door.
Whole different system then the remote fob.
Dadhawk (04-20-2021)
Old 04-20-2021, 06:02 AM   #441
JD001
JD001's Avatar
Drives: Subaru BRZ
So a remote fob.
It's a fob, with an emergency key contained within the body of the fob. The emergency key only opens the driver's door as that is the only door with a physical lock. I don't have an ignition barrel (I think I don't..).
Old 04-20-2021, 06:29 AM   #442
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Today I learned that whether I go to bed at 20:00 or 01:00, I will never be able to wake up easily for work.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (04-20-2021), soundman98 (04-20-2021), Spuds (04-20-2021), Tcoat (04-20-2021), Ultramaroon (04-20-2021)
Old 04-20-2021, 07:09 AM   #443
Same as I have on the 86 now.
I don't know about there but here the FRS, 17+base 86 and the BRZ Premium all had just the key with the buttons. Those batteries will last forever (well in comparison).
The keyless entry/start fob like we have will chew up batteries in a relatively short time. It is the price we pay for convenience. I had keyless entry and start on the 3 cars prior to getting the FRS and even 5 years into owning it I would still leave the key in my pocket and look for the button about once a month. Then I would mutter under my breath about primitive technology as I rummaged around in my pocket the find the damned key.
JD001 (04-20-2021)
Old 04-20-2021, 07:43 AM   #444
Originally Posted by DarkPira7e View Post
Today I learned that whether I go to bed at 2000 or 01:00, I will never be able to wake up easily for work.
That will change! I go to bed at 2100 or 0200 I will be awake by 0500.
DarkPira7e (04-20-2021), NoHaveMSG (04-20-2021)
Old 04-20-2021, 08:30 AM   #445
DarkPira7e
DarkPira7e's Avatar
I used to not have an issue with it, I was up at 0500 for work, did my stretching, coffee, etc and was ready to face the day. But now I just want to fall down the stairs so I have an excuse to keep sleeping
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
JD001 (04-20-2021), NoHaveMSG (04-20-2021), Tcoat (04-20-2021)
Old 04-20-2021, 08:59 AM   #446
JD001
JD001's Avatar
Drives: Subaru BRZ
Not sure falling down the stairs is a good strategy for sleeping.. try falling into bed or a comfy chair/sofa..
The Following User Says Thank You to JD001 For This Useful Post:
Tcoat (04-20-2021)
Old 04-20-2021, 09:15 AM   #447
Lantanafrs2
Drives: 2013 frs red
Today I learned that YouTube was causing ibs symptoms
Old 04-20-2021, 09:19 AM   #448
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It makes shitting difficult?
OFT KC learned Nah Software Tuning 3 03-17-2016 12:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 02:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 02:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-15-2014 11:37 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 08:15 PM
