Old 03-07-2017, 09:18 AM   #4453
JoeC
Drives: Subaru BRZ Limited
It doesn't matter for the RC1.
Thanks. When does it matter?
JoeC is offline   Reply With Quote
Old 03-07-2017, 11:30 AM   #4454
Racing slicks. Like real slicks, not "dot slicks".
Old 03-07-2017, 11:43 AM   #4455
JoeC
ok. I figured the RC-1 we basically slicks with two small grooves to satisfy some DOT technical requirement which would allow them to be used in certain race classes.
I guess not. Thanks for responding to my question.
Old 03-07-2017, 02:00 PM   #4456
Xevuhtess7
First time using a tire pyrometer this weekend and it was quite interesting!
The track was CCW and right side tires were hotter on the outside edges by ~15F, but the left side tires were hotter on the inside edges by ~10F. Should I disregard the left side readings since I was doing predominantly left hand turns?
Also, I haven't been able to find good info on what is proper temperature for my RS3 v2's (or hardly any tire for that matter). The highest I saw was 135F. Sounds pretty low to me though ambient was pretty low at 50F.
Thanks in advance!
Xevuhtess7 is offline   Reply With Quote
Old 03-07-2017, 08:02 PM   #4457
zypher
Drives: WR Blue BRZ
Thanks in advance!
Did you keep up your cornering speeds during your cool down lap? My guess your tires cooled down from that. I don't have first hand experience with the RS3's but ball park should be around 150F-190F
zypher is offline   Reply With Quote
Old 03-07-2017, 08:51 PM   #4458
Xevuhtess7
No cool down except the last 2 corners or so when I must slow down for track exit.
Old 05-17-2017, 05:30 PM   #4459
Azzudien
Drives: 2017 Series Yellow BRZ
Had my first track day
Had a great coach, learned a ton both on the track and in the classroom sessions. A few questions before my next track day.
Instructor said I was already pushing the limit on the stock brake pads and recommended I upgrade the pads, and fluid.
Just want to confirm, Ferodo DS2500's and Motul 600 or 660 be a decent combination? Not a daily driver, but I do drive on streets occasionally and I also drive to and from the tracks, all are about 2 hours from me.
If the ds2500's are good choice, where can I purchase for the brembo calipers? I was looking at many sites and most just had them for the non pp calipers.
They other question was on tire pressure. I checked the pressure after my third session and it had gone up to 44psi. I waited for them to cool down and checked again just before my next session, they were still at 38psi so I bled them down to 35psi where I started the day at.
Stock primacy tires, should I be running at 35psi cold to start or another recommended pressure?
Just so you know, I only plan on modding the car once my ability catches up to the cars ability in an area. Example being the brakes currently.
Azzudien is offline   Reply With Quote
Old 05-22-2017, 01:58 AM   #4460
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
If you haven't upgraded your fluid, you've probably boiled it already. I recommend Castrol SRF, but the Motul is great too. There are a lot of good pad options out there and you'll want a track set and a street set so you can swap them when you arrive at the track, and then again before you head home. CSG can get you set up with pads and fluid.
If I remember correctly, those tires like it about 38psi hot. ALWAYS make your adjustments hot after every session, immediately off the track, as in the pit lane if possible.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-22-2017, 10:10 PM   #4461
Whooosah
Drives: FRS
Looking to upgrade dampeners and suspension. Budgeting for 3k ish. Plan to run 200tw tires mostly for hpde events with some autocross mixed in. Was initially looking into rce t2 or st xta. Time attack guys not fimilar with platform at the track were saying mcs singles and pay a bit more. Havent heard much about MCS on this platform in single adjustable..two way is out of price range and I don't have experience tuning suspension so I'm fine with a 1 way. Pretty sure I'll be set with an rce t2 setup or something similar, but some of the track guys were saying skip and spring for mcs... just wanted the boards advice. Keep uping budget in order to avoid buying something I'll grow out of sell and upgrade again.
Whooosah is offline   Reply With Quote
Old 05-23-2017, 11:26 AM   #4462
Pat
Pat's Avatar
Drives: 2023 BRZ
If you're comfortable with the cost of MCS they are an excellent option. I would much rather have those over T2s. I own T2s and like them.
Old 05-23-2017, 11:38 AM   #4463
Tokay444
Anti stance.
Tokay444's Avatar
Looks like you get a lot for you buck at the 6k price point.
Old 05-23-2017, 02:13 PM   #4464
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Originally Posted by dradernh View Post
Photo is of a car lifting its inside front wheel in the Toe at the Glen at 68 MPH.
Front Spring Rate = 1598#. Front Bar = 38mm with six adjustment holes; bar is set on 4th stiffest hole.
So, the front end of this car is extremely stiffly sprung, and it's still lifting the wheel. It was a non-issue as far as driving the car fast.
Wovzers on the spring rates... We run 800lbs front and 900lbs on the rear of the IP-BMWCCA (E36) car. Which series does this car run in?
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 05-26-2017, 07:16 AM   #4465
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by Whooosah View Post
some of the track guys were saying...spring for mcs... just wanted the boards advice. Keep uping budget in order to avoid buying something I'll grow out of sell and upgrade again.
If you can afford them, that's good advice. Single-adjustables sound like they'll meet your needs just fine. You will not outgrow them - it's conceivable you could eventually choose to have them upgraded to two-ways, but I doubt it.
dradernh is offline   Reply With Quote
Old 05-26-2017, 09:38 AM   #4466
dattran86
Driver
Drives: 2013 Whiteout FRS
When im braking very hard from 150KM down to 100KM before the turn. my steering wheel would shake, the car feel off balance.
Is this normal under hard braking? or my tires are not good enough?
Please educate me if you know the problem.
dattran86 is offline   Reply With Quote
