, dpfarr
Old 03-01-2022, 10:00 PM   #4439
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Originally Posted by DrB View Post
I'm 58 and rally new to the scene
Got 2018 BRZ TS in April 2018
Tomei UEL in 2019
E85 ad flex fuel kit 2020
Two weeks ago Edelbrock SC and Borla Axle back exhaust (touring)
AND A FEW OTHER SMAL MODS ALONG THE WAY
300 whp and it is the perfect ride
Wow!
Dr Bob
Good to know there's other "middle age" enthusiasts here, I'm 66. Bought my 2013 FRS as a Retirement present a couple years ago and installed the Edelbrock SC last June. Ceramic coated Tomei EL header/overpipe have improved performance even further. BT's MAP relocation kit and a CSG tune by
Zack have been purchased, to be installed soon. looking forward to Spring and installing Michelin Pilot Sport 4S's
Brewster is offline   Reply With Quote
The Following 7 Users Say Thank You to Brewster For This Useful Post:
B T (03-02-2022), BrahmaBull1990 (03-01-2022), CallmeDave (04-25-2022), CSG Mike (03-02-2022), Dadhawk (03-02-2022), Dzmitry (03-03-2022), Tatsu333 (03-04-2022)
Old 03-03-2022, 02:16 PM   #4440
B T
CNC shop gave me an estimated ship date of March 30th so hopefully I'll have the RMAP blocks on your doorstep by mid/late April!
B T is offline   Reply With Quote
The Following 2 Users Say Thank You to B T For This Useful Post:
Auto_egr (03-03-2022), BAT_BRZ (03-16-2022)
Old 03-03-2022, 07:44 PM   #4441
SOCON
SOCON's Avatar
Drives: 2017 WR Blue PP
Edelbrock Equipped Clutch Replacement
Has anyone attempted to replace the clutch on an Eforce equipped engine?
Were you able to accomplish this without removing the supercharger first?
Thanks
SOCON is offline   Reply With Quote
Old 03-04-2022, 08:49 AM   #4442
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Thanks
I had to lift the S/C an inch to replace a leaking banjo bolt crush washer.
I’d have to think lifting the S/C even more would be necessary to remove the slave cylinder bolts and most likely the starter bolts as well. All were easily accessible per Edelbrock.
Good luck! I may be going down that road soon as well.
Muskoka800 is offline   Reply With Quote
The Following 2 Users Say Thank You to Muskoka800 For This Useful Post:
Pgh_Area (03-04-2022), SOCON (03-05-2022)
Old 03-04-2022, 09:27 AM   #4443
B T
Thanks
You can pull it without removing the superchager, I've done it at least 5 times. Those slave cylinder bolts are def a pain in the ass. A crows foot will help it go a little smoother or lift it slightly as stated above.
The Following User Says Thank You to B T For This Useful Post:
SOCON (03-05-2022)
Old 03-04-2022, 11:18 AM   #4444
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
While it can be done like BT has said, it makes doing the work a lot easier to just remove it. I had to replace my clutch last spring. We loosened, and lifted when needed to, to do the job. If I had it to do over again, I would just remove and reinstall.
Pgh_Area is offline   Reply With Quote
The Following User Says Thank You to Pgh_Area For This Useful Post:
SOCON (03-05-2022)
Old 03-04-2022, 10:23 PM   #4445
Brewster
Brewster's Avatar
Has anyone tried installing the Cusco water to oil cooler with the EB SC already installed ?
Just wondering if there are any clearance issues, specifically the hose that connects to the existing top radiator hose ?
https://www.cusco.co.jp/en/jpg/Water...r%20New_A4.jpg
Anyone at all ??
Old 03-09-2022, 07:33 PM   #4446
Blanco#17
Blanco#17's Avatar
Drives: GT86 Blanco Ed #17
Originally Posted by Blanco#17 View Post
Good Question, I guess I just assumed it, was the thing to do, as radium sold the delete tube. I.e. when I went to the website to buy the can it recommended the delete which was GT86/BRZ specific.
Engine had burned 2 litres of oil minus what was in the Catch can. Got a new PCV on order but its a week for delivery.
Update, for those interested, went to local Toyota dealer they wanted £40 for PCV and it was not in stock. Phoned Subaru £4.33 I paid more for the postage.
Fitted new PCV keeping the catchcan installed as well, and topped up the oil. First start sounded like shit and I shut engine down after 30 sec run to check fluids all ok. No Codes on DTC ECUtek.
Kept restarting and shutting down for longer and longer duration checking the fluids all fine now.
Car is running better than ever no idle fluctuations, so far. But I haven't risked a longer trip yet.
I did get the PCV for the turbo FA20 (11810AA141) told Subaru it was a Forrester. Not sure if that was the difference or if it was the old PCV was Knackered. But if you are getting erratic idle and no load stalls, try swapping out the PCV.
Blanco#17 is offline   Reply With Quote
Old 03-09-2022, 09:02 PM   #4447
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
In case anyone is interested, I'm selling my horizontally mounted oil cooler. I no longer have the car and it's just sitting in my garage.
Here is the link to the for sale thread. LINK
I posted this fun upgrade long ago in this Edelbrock thread and have since received many inquiries about over the years. I just figured this should go to an Edelbrock equipped owner since it worked so well with this setup.
Nitro22 is offline   Reply With Quote
The Following 2 Users Say Thank You to Nitro22 For This Useful Post:
B T (03-10-2022), CSG Mike (03-11-2022)
Old 03-15-2022, 01:55 AM   #4448
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I’ve been running richer and richer lately on my LTFT trim (-20% at times). I know I have a cracked weld at the header that is probably leaking. But I read that would read as a positive LTFT? I have a new JDL header coming this week.
My concern is it could be the BPV. I have 7k miles on my SC I bought last year. Are rich LTFTs a sign of a bad BPV or is this likely a result of the cracked weld on the header?
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
CSG Mike (03-15-2022)
Old 03-15-2022, 06:16 AM   #4449
It depends on WHEN youre getting the trim. When does the trim appear and when does it go away?
BrahmaBull1990 (03-15-2022)
Old 03-15-2022, 07:33 AM   #4450
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thanks Mike.
The trim is at idle and with slight throttle. It improves under hard acceleration but my trims do not go positive and they used to under hard acceleration. The trims are the most negative at idle and when in a vacuum (decelerating/engine braking)
The car is running fine except for a slight feeling of power loss during a pull (could be in my head).
My BPV has two bolts which I believe is the upgraded one?
Old 03-15-2022, 10:48 AM   #4451
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Update: I’m so fukking frustrated. I just tried to get coffee and it did the normal cold start. Then almost died when the cold start ended. Then it tried to stall at a stop sign and I had to immediately head home while blipping the throttle when stopped.
I saw LTFTs where -10%+ going 10mph while feathering the clutch. This problem has been progressive since I was getting slight shutters at stop lights for about a week.
2020 BRZ 13.5k miles. Edelbrock since 7k
Stock fueling with WA 92. Stock boost pulley. No issues ever till this.
Old 03-15-2022, 11:09 AM   #4452
Auto_egr
Drives: 2017 CWP BRZ w/PP
Ignore my past comment about unmetered air going into the engine, I misread your update since you mentioned it's running rich. If you're getting negative LTFT it's pulling fuel for some reason. Not adding fuel to compensate for unmetered air. A leaky header can cause negative LTFT if it's upstream of the O2 sensor(s).
Auto_egr is offline   Reply With Quote
The Following User Says Thank You to Auto_egr For This Useful Post:
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
