#44437 |
Drive From Home
Drives: BRZ STI Performance
#44438 | ||
#44439 | |
Drives: '15 BRZ RA
http://hpwizard.com/rotational-inertia.html On a crankshaft pulley most of the weight is on the outside part, so a model would be something like: Outer diameter: 14cm, Inner diameter: 8cm Stock mass: 2.2kg, aftermarket mass: 0.4kg Gains in 1st gear ~15 kg Gains in 2nd gear ~6.5kg It might not sound that much, but you have additive gains from the other pulleys too and also some more if you underdrive the alternator. In general the secret is that you remove weight from rotational parts before the gearing ![]() And I'll say again that this is a very rough model. A better model would calculate also how fast the FA20 engine increases the RPMs. Then you would find that in specific areas the gains are more, because of more acceleration. Same holds for a flywheel ... |
#44440 |
Oh god not here!!!
#44441 |
Country Boy 4 Life
There are squirls barking at eachother on the branch just outside my bedroom window!
SHUT UP!!! I was trying to sleep!!!!
I LIKE TIRES! |
#44442 |
They are debating the benefits of light weight walnuts. Light ones are easier to carry but the heavier ones stay buried better.
#44443 | |
Country Boy 4 Life
I LIKE TIRES! |
#44444 | |
The Dictater
Drives: '13 Red Scion FRS
1. You are incapable of understanding that what you just described is exactly what I offered to do 4 or 5 times. My preliminary calculator is posted a few pages back. I didn't include pulleys because I didn't feel like looking up all the weights and diameters. If you want the calculations done, you would have had to put in some effort on your own end. If this is the case, you really aren't as smart as you think you are. 2. You are here to troll. Again. If this is the case, you F'ed up big time. Either way, bringing the one topic up that you know @ichitaka05 has asked not be brought up in one of the few threads he actually participates in is not a good idea, especially when you have your own thread that you abandoned. Hopefully this will be the last we hear from you. |
#44445 | |
The Dictater
PS, she likes the cat gifs in the gif thread. |
#44446 |
Famous Potatoes
Drives: '15 ultramarine
Too much beer and poker last night. I came in 3rd in the hold'em tournament, so not too bad.
#44447 |
My wife just says she knows I am on because I get a "goofy grin". She is not as impressed when I wake her up with laughing so hard at 2am. She was not happy with Ultra for about a year back in the heyday of the late night laughfests.
#44448 | ||
Drives: '15 BRZ RA
#44449 |
The Dictater
Yeah, those heavier ones just sink like a rock into the turned ground. But both squirrels would be wrong though, since lightweight acorns are clearly the best nut stash mod one can get. I skimmed through an article that says they vibrate at a frequency that let's you get more nuts in the hole.
#44450 | |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
