#4411 |
Drives: GT86 Blanco Ed #17
#4412 | |
Drives: 2018 BRZ tS
#4413 |
It's really pretty simple. unbolt the old MAP, instal this in it's place, put the MAP into the adapter and re-insert bolt (new longer bolt included). There are two optional ways to install the pressure lines depending on how you would like your bypass valve to operate. I supply the the tee adapter and lines to intercept the original bypass valve feed line. The alternative (which I use) is to run the bypass valve line to a tee in the brake booster line and run a direct line from the MAP adapter to the pressurized port at the top rear of the supercharger. I'll get some pictures and install up when it's closer to delivery. I should have some older posts showing the install already I believe.
| The Following User Says Thank You to B T For This Useful Post: | Side (01-30-2022) |
#4414 |
| The Following 2 Users Say Thank You to B T For This Useful Post: | aKaGorganZola (02-02-2022), Auto_egr (02-02-2022) |
#4415 |
Drives: BRZ ts
I want to install one but have some questions for anyone.
I have a dyno tune with a double d box. The intention for remote map sensor is to have a more stable signal than from one runner. There in lies also the need for the d box right? Getting a bit less noise in the graph. However, in an effort to not further squander money, there are several things that are against me. I have spent the money on a tune w the dd box, so flex fuel goes out the window. Can I run a remote map sensor and dd box? Would it make a difference? I don’t particularly want to pay for another tuning session if it’s running well. |
#4416 | |
Drives: 2017 CWP BRZ w/PP
My understanding is the DD box takes erroneous MAP values and ignores them, thus smoothing out the signal to The ECU. If you install the remote sensor kit, you should see far less spikes/dips in your MAP signal and can safely run both. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Auto_egr For This Useful Post: | B T (02-03-2022) |
#4417 |
Response from Zach Tucker - "You can run both, but there wouldn't be any benefit to doing so. In fact, I'd say running the D-Box draws its own cons since I believe it to inherently apply a minor MAF voltage shift in addition to the smoothing factor."
| The Following User Says Thank You to B T For This Useful Post: | Tatsu333 (02-04-2022) |
#4418 |
We've hit our minimum order guys, I'm going to allow until Monday a week from now for any more additional people to jump on board then I'm putting in the order.
| The Following 3 Users Say Thank You to B T For This Useful Post: |
#4419 |
Drives: 2017 BRZ Series. Yellow
#4420 |
I'm going to make up any difference in the minimum order (10) and the number of deposits (currently 8) with my own money. I'll get with those of you on the list this coming Friday about the remaining order balance so I'm not floating the entire order. That way I can stick to the price I initially told you guys.
| The Following User Says Thank You to B T For This Useful Post: | aKaGorganZola (02-06-2022) |
#4421 | |
No need to do that! I'm sure we would all be willing to pay a bit more so you aren't floating the bill. Just let me know how much more and I will send the money! ![]() Sent from my iPhone using Tapatalk |
#4422 |
Howdy
Drives: 2020 BRZ PP
Anyone know if I could hit 300whp without E85? Built block, smaller pulley, upgraded injectors and fuel pump, and 92 octane?
Currently at 250whp with stock pulley/fueling and thinking about starting the journey.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#4423 |
Drives: BRZ ts
Probably not.
| The Following User Says Thank You to dpfarr For This Useful Post: | BrahmaBull1990 (02-06-2022) |
#4424 |
9 people in with deposit now. There's a few guys who said they were in but never heard from again and didn't send a deposit.
I have deposits for the following: @Auto_egr @boldfin @aKaGorgonZola @Brewster @dmorgan38 @Colin86 @bokehmon @BAT_BRZ If your names not this list, you're currently not on the order. Last edited by B T; 02-10-2022 at 10:40 AM. Reason: Had one drop out |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
