Old 01-19-2017, 10:25 PM   #4411
zypher
Drives: WR Blue BRZ
@CSG Mike
I am running a set of KWV3's I will be moving to running Nitto NT01s in 225/45/17 for next season.
Should I think about upping the spring rates?
Thanks
zypher is offline   Reply With Quote
Old 01-25-2017, 07:32 PM   #4412
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Hi mike @CSG Mike, thank you for making this Q&A post.
I have tein flex z coilover with -3 camber front/ -2.5 rear/ 0 toe front, and 0.5 toe rear
Damper: from hard, 4 clicks front/7 clicks rear.
255/40/17 tires, front strut bar, stock sway bar.
Car has amazing grip in daily drive or mountain drive, but is it good enough for high speed track?
Also, how can I increase car rigidness?
Any recommend setting for damper for track?
Thanks
FR-Sky is offline   Reply With Quote
Old 01-25-2017, 07:47 PM   #4413
ayyyypex
Drives: 2016 FR-S
SO im a noob in regards to the track and racing. Ive got an frs and im looking to start some suspension mods. Ill be driving the car stock first to get a feel for it but id like to know what i should be buying in the future.
the car is driven on the streets and will be taken to the track a few times during the summer. I dont care if street driveability is lost. Car will be used for grip and occasional drifting (for fun). My budget isnt the biggest but ill spend a decent amount for quality. Just an idea on my budget id like to spend around 1200-1300 CAD before tax for coils at most.
Any suggestions on what i should aim for?
ayyyypex is offline   Reply With Quote
Old 01-25-2017, 08:17 PM   #4414
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Read this whole thread along with the RCE/CSG suspension thread and decide if you still think coils in that price range will benefit you after driving the car stock
Old 01-25-2017, 08:21 PM   #4415
Originally Posted by zypher View Post
@CSG Mike
Thanks
Unless you know WHY you want to up the rates, you should probably leave them alone.
Old 01-25-2017, 08:21 PM   #4416
Thanks
It's fine for tracking.
A roll cage will increase rigidness.
See my FLZ review thread. http://www.ft86club.com/forums/showthread.php?t=81829
Old 01-26-2017, 06:40 AM   #4417
zypher
Drives: WR Blue BRZ
Well the question is more are the Nitto's in 225 enough grip to warrant increasing spring rates to keep from bottoming out, and riding the bump stops?
Thanks
Old 01-26-2017, 12:03 PM   #4418
Thanks
Unless you're super low, you shouldn't be compressing enough to bottom out the V3, except perhaps over very large on-load berms.
How much of a drop do you run from stock? Anything less than 1.2" or so will be fine.
Old 01-26-2017, 07:27 PM   #4419
zypher
Drives: WR Blue BRZ
I'm running about 0.8 to 1" drop.
Thanks for the advice Mike
Old 01-26-2017, 09:57 PM   #4420
FR-Sky
FR-Sky's Avatar
roll cage will be too much for me,,since i am going to track less than 5 times a years, and its my daily.
Does the under bracing bar or trunk bar helps?
Thanks
Old 01-26-2017, 10:40 PM   #4421
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Thanks
Why do you feel that your car is lacking rigidity?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 01-26-2017, 11:16 PM   #4422
FR-Sky
FR-Sky's Avatar
Well, to be honest, I drove the new 2017 model, and I feel that the car is less "loosen" than the 2013-2016 model, it feels like the its more "closed box", and feel more rigid for precise cornering.
Old 01-27-2017, 12:20 AM   #4423
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
With that budget, you will not find a quality coilover suitable for track work. My recommendation would be Racecomp Yellow springs on the OEM struts with camber plates, camber bolts, and if you can fit them in the budget, SPC rear LCAs. I think you'll be very close to your budget with a quality and well performing setup vs. spending that money on a subpar set of coilovers.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 01-29-2017, 02:26 PM   #4424
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Hi guys,
I'm going to buy a BRZ, probably next month. I'm in canada and we don't have the PP, except for the yellow edition, which include the PP.
I'm more interested in the limited, because the yellow edition end up costing much more.
But I'm concerned that maybe I'll regret not having the big brake of the PP.
I do mostly autocross (for which the base brake will be more than enough), but I'll also do a couple of track days per year. 20 minutes sessions.
In my base RSX (not type S), I had to go easy on the brake or they were seriously overheating. It was frustrating, so in the last 2 years I stopped doing track day, and did only AutoX.
Do you think the BRZ with the base brakes can do 20 minutes sessions without having to "manage" the brake all the time.
I'll be running semi-track pads (like the hawk hp+), and sticky tires (rival, rs3...).
I was running Hawk HPS in my RSX.
nico_rsx is offline   Reply With Quote
