Old 04-18-2014, 03:34 PM   #4397
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by olorin View Post
Doh, I was thinking flex-fuel kit. I'm thinking about getting the moto kit at some point.
oh whoops haha. Prime Motoring.
I'd suggest Moto's kit too. All plug and play. I may end up buying the one fitting needed for my kit to plug it into the stock line but right now i've had no issues so I can't complain. For the price of the Prime Motoring one you can't go wrong.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Dustin (04-18-2014)
Old 04-18-2014, 03:42 PM   #4398
swift996
swift996's Avatar
Someone should try this and see if it clears the OEM hood and if it adds power:
http://ft86speedfactory.com/crawford...lock-1558.html
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-18-2014, 03:56 PM   #4399
xxscaxx
It definitely will not clear the hood.
I already said something to crawford about making some for us, they were apparently going to get in contact with someone for the measurements of hood clearance on the SC and see if they could make something.
May have a little more room with the smaller pulley but those are definitely too big to run with our SC. I was hoping for something like 3mm or smaller, if only for heat purposes.
Old 04-18-2014, 04:47 PM   #4400
xjohnx
Grip>Slip
xjohnx's Avatar
even if it does make power on a FI setup (which it didn't when shiv tested on the ESC), i can't imagine it will be worth the hassle of pulling the blower to install them.
Old 04-18-2014, 06:08 PM   #4401
TemeCal
Drives: 86
The even bigger hassle, is having to get it retuned. I just don't see it being worth it.
TemeCal is offline   Reply With Quote
Old 04-21-2014, 01:27 PM   #4402
xxscaxx
Not the best shot, but a pic of the nameless intake pipe all polished up.
The Following 3 Users Say Thank You to xxscaxx For This Useful Post:
CK_Bladesmith (04-21-2014), evo4g63 (05-01-2014), Ryan86 (04-21-2014)
Old 04-21-2014, 08:19 PM   #4403
Pekingduck
Drives: 4 wheels
What tower bar fit with innovative supercharger? I know the cusco fit, but I am wondering what else.
Pekingduck is offline   Reply With Quote
Old 04-21-2014, 10:33 PM   #4404
Assunta
Assunta's Avatar
Ground control
Assunta is offline   Reply With Quote
Old 04-21-2014, 10:59 PM   #4405
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Assunta View Post
Ground control
do you have this setup? I was under the impression it wouldn't fit, but would be stoked if it did.
Old 04-22-2014, 01:24 AM   #4406
Assunta
Assunta's Avatar
No I don't, but here's proof:
I tried to order black but they were going anodize an already machined unit and I would lose all the shiny machined edges. Apparently this is a prototype.
You need the 25mm spacers.
The Following User Says Thank You to Assunta For This Useful Post:
xjohnx (04-22-2014)
Old 04-22-2014, 07:58 AM   #4407
xjohnx
Grip>Slip
xjohnx's Avatar
Hm, looks like the IC coolant reservoir might have to be relocated. @xxscaxx i believe you've done this, right? can you post some pics of where you mounted it and the hose routing for it?
Old 04-22-2014, 08:57 AM   #4408
xxscaxx
No that wasn't me actually lol. I can't recall who it was but they drilled and mounted the coolant reservoir to the tie bar in the back. I'm thinking about using some SS flat stock and just moving the coolant bottle back towards the firewall.
They have the non-ic setup on that speedhunter car too.
The ground control setup works but remember thats using the camber plates up front, PLUS that spacer.
I bought a GT Spec strut bar thinking it would fit since its cusco style, but it doesn't. I'm debating on getting a new bar or maybe getting spacers made or something to make this one fit. Not sure yet.
Old 04-22-2014, 11:57 AM   #4409
TemeCal
Drives: 86
Has anyone received Bill's ( @DeliciousTuning ), 8.54 tune yet? I realize he's been busy and moved locations, but it's been close to 3 weeks now. My car gets a lot of garage time, because I'm just not 100% confident in the 8.51 tune.
Old 04-22-2014, 12:22 PM   #4410
xxscaxx
I put in a request for it but knew prior that the flexfuel map was a little behind the standard pump gas maps in regards to release time. Haven't heard anything though. I know @Ryan86 has it, but not sure if anyone else does.
8.52 seems great to me, surprised you weren't at least updated to that revision.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
