Old 08-10-2016, 03:59 PM   #4341
AlanLGuy
Drives: Raven 6 speed Manual FRS
Originally Posted by SeanRTR View Post
Interesting. How much tread is left, and how many street miles?
Effectively zero street miles(less than 100), the outside shoulders are significantly worn, I had them flipped last week, but the front left was actually corded slightly because of crash bolt coming loose at Toledo and giving me some active camber >
I definitely didn't rotate front to rear as often as I should have and should have flipped them on the rim after the 2nd national event.
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 08-10-2016, 04:06 PM   #4342
86_Freak
86_Freak's Avatar
Drives: 2015 FR-S
I put a brand new set on for the Blytheville Pro, and after 16 runs, there is no more tread around the outside corner on the fronts. I will rotate them from front to back, but I am nervous about putting anymore runs on them before the Pro Finale.
86_Freak is offline   Reply With Quote
Old 08-10-2016, 04:34 PM   #4343
TMF
TMF's Avatar
Drives: '14 FRS TT5
Speaking of tires, I got my hands on a set of the new 200 TW Federal 595 RS-RR:
These are 225/45-17's on a 17x9 +35. Yes, I know they aren't legal for CS, but that doesn't mean I can't run them at a practice event...
So far I have one track night and a few runs at an autox test n tune on these. This setup completely transforms the car. For the first time, it is hard to overcome the available grip to get the car to rotate, and also for the first time, I felt like the car needed more power.
At the test n tune, I ran a few runs on the Federals and then switched back to my 225 RE71's on class legal wheels (17x7 RPF1's). My codriver couldn't beat his times from the Federals when we put the RE71's back on, and I could just barely match my times on the Federals.
In terms of tire characteristics, the Federals felt very precise with stiff sidewalls - just like the RE71's. The level of grip was high, and when you surpassed the level of grip, they were not totally gone and it was easy to recover. The tires were fairly silent (in terms of squealing) until you surpassed the grip level. The longest track session I ran was about 10-15 minutes and the tires did not seem to grease out. Wear has been minimal as well. For street driving, the Federals are loud as hell (probably due to the tread design).
Now, I totally realize that some of the benefits I experienced are from jumping from a 7" wheel (with the RE71's) to a 9" wheel (with the Federals), but regardless, the level of grip and characteristics of the Federals are awesome. Plus, it was only $500 shipped for a set of 4.
Another local FRS owner bought the same size Federals, but put them on a class legal 17x7 RPF1. We are both attending a timed track night next week, so I'm looking forward to comparing times.
I'm hopeful that these tires are approved for next season and are competitive!
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 08-10-2016, 10:45 PM   #4344
cjd
cjd's Avatar
Drives: 2017 BRZ
That's a somewhat different impression of the Federals than I gathered at an event a month and some ago, though those were 255/40's on a full STX prep. I never heard a full review though, and the surface was something less than ideal at that time. It kept getting slower over the two days we ran. Quite interesting, regardless.
Old 08-10-2016, 11:13 PM   #4345
TMF
TMF's Avatar
Drives: '14 FRS TT5
Was that Bill Cook's brz by chance? I heard through the grapevine that he was less than impressed also. I really had quite the opposite experience, but it is a tough comparison due to my wheel choice. I'm very curious to see how these are on the stock wheel size. I'll keep everyone updated as I learn more.
Old 08-11-2016, 02:57 AM   #4346
justint5387
Drives: 4 wheels
Question, is McCelvey actually going to try and run those stupid BFG tires @ Lincoln? I assume he was running those because he preferred their superior contingency, and figured he could cover the field? I'd be very surprised if a big player like him choses to run BFG over Bridestone on that surface, that has proved all compounds of BFG to be completely inferior to Bridgestones for a CS car.
James Yom had been dominating with BFG in a STR car. Not sure how that translate to Street class cars.
justint5387 is offline   Reply With Quote
Old 08-11-2016, 10:15 AM   #4347
chucky12012
Drives: 2013 Asphalt Scion FR-S
I can't even believe people are still doing this, the tires are definitely faster with runs on them, as much as people don't want to believe it.
As mentioned Dan and Andy were running the BFG's just because for a bit they couldn't get the Stones. Once they had them, they ran them at the pro's because of the contingency. We won't see them on the BFG's any more at this point.
Side note, well done in Blytheville Jared. You really drove it well. That site will remain on my bad side at this point since I couldn't really put it together at all, and caused me to be one point shy of the Pro Finale.
-Chris
chucky12012 is offline   Reply With Quote
Old 08-14-2016, 07:34 PM   #4348
Skurj
Drives: SOLD...
Apart from koni yellows.. what other options do we have for shocks for CS? Thinking its time I retired the OEM's...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 08-14-2016, 08:05 PM   #4349
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
There's some set that costs like $3,000 I believe.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 08-14-2016, 08:15 PM   #4350
Skurj
Drives: SOLD...
Been consulting the google..
MCS TT1 @ $2750 + $375 for the CS kit
Koni Yellows
Cusco Touring A
All with just adjustable rebound...
On the north side of the border.. option A the MCS will be over to 4k all said and done..(perhaps almost 5) the other 2 closer 1500 ish..
Thinking the MCS would be wasted on my skillz.. I do like the idea though that they can be converted into a dbl adjustable coilover .. if I ever decided to step to STX..
Paid for Mar 2018
Old 08-14-2016, 08:22 PM   #4351
klittl06
Drives: FRS?
Koni Yellows
Cusco Touring A
That is a pretty awesome feature but konis + kw v3's (should you go to stx) < MCS.
I'm sure Bilstein also has an offering.
Sent from my SM-N920V using Tapatalk
klittl06 is offline   Reply With Quote
Old 08-14-2016, 08:28 PM   #4352
Skurj
Drives: SOLD...
Good call.. tirerack is listing B6 and B8 Bilsteins though B6 is on closeout... not sure what that really means.. new model? or no more B6 for 86's...
Paid for Mar 2018
Old 08-15-2016, 11:21 AM   #4353
ryan t
Drives: frs
im on the cusco touring a. they work great, and go a little stiffer than the koni in adjustment. you need the adjustability no matter which shock you choose.
ryan t is offline   Reply With Quote
Old 08-15-2016, 10:24 PM   #4354
Skurj
Drives: SOLD...
Do you have to remove the rear shocks to adjust them for the cusco's?
Anyone care to comment if the koni rears need to be removed to adjust?
I had yellows on my e46 m3 and ya had to remove the rears to adjust them.. pita..
Paid for Mar 2018
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
