#4327 |
Drives: BRZ ts
Man, this has been a long road. Bought a used kit that was missing pieces that took weeks to get from Edelbrock. Found my d box got fried from a voltage spike. Took a few weeks to get everything with that sorted w Delicious.
Well, tonight I got that thing plugged in and it fired right up. Smoothly. Can’t wait to go for a drive tomorrow! |
#4328 | |
Drives: Honda Insight
This line of thinking puzzled me at first since I'm playing catch up from reading the early literature on the FA20 to now. Speaking to what someone just commented on which is at first glance everyone was saying how much better the FA series is than the EJ, now it seems like everyone has flip-flopped on that. It would be nice to be a purist and just for practicality keep the FA, but I certainly understand the rationale for going to a K series and only having to do the most minimum amount of internals to hit 400whp (while also saving 200lbs or so) and if the motor blows who cares there's a used one with under 50K miles for a few hundred bucks right around the corner. Is this thought process just an oversimplification, and if so what am I missing? |
#4329 |
Drives: 2015 FR-S
Just curious do you know what the cause of the voltage spike was? and what was the symptom of that malfuctioning D-box
#4330 | |
Drives: BRZ ts
I was hanging out at the dealership trying to get info on alternators since mine was in the way and learned the amperage difference on the 1st vs 2nd? Could’ve been that? Could’ve been an easy excuse from them for a dummy that doesn’t understand the world of electronics. I figured it was fucked because doing an ecutek log showed the pressure differences between the MAP and air pressure (I’m at sea level). It also wouldn’t show up on Bluetooth through the app. |
#4331 |
Drives: 14 BSP Edelbrock BRZ
The voltage spike did you a favor. You don't need a d-box, you need to remote the MAP sensor. I did it a couple years ago with a metal box, but someone made a 3-d printed nylon box that is even simpler.
#4332 |
That was me, I made some CNC remote adapters, the 3D printed model just wasn't reliable enough. I sold my last one of the batch to Zach @ counterspace garage. Maybe he still has it for sale?
#4333 |
Drives: BRZ ts
What is the remote adapter?
#4334 |
| The Following User Says Thank You to B T For This Useful Post: | dpfarr (10-25-2021) |
#4335 |
Drives: BRZ ts
That makes sense structurally. Doing that reduces or eliminates Delicious’s need to make averages for the MAP signal? Damn, I want one now.
#4336 |
Drives: 2015 FR-S
So how do you hook up 2 MAP sensors into the ECU? is it a special harness or do you repurpose another random sensor like O2 or Oil pressure sender
#4337 | |
Drives: 2020 BRZ Sport Tech RS
Do you feel that at a mild state of tune (at or slightly above the CARB tune levels for these kits) the Edelbrock / Harrop kits could be long-term reliable on stock internals (100,000 miles+), or is it too much torque too soon in the powerband for the FA20 as-is?
#4338 |
it plugs the old location and routes a new line to the MAP sensor. It also has reroutes the bypass valve to a more suitable location. I can make more, stil have the CAD files. problem is unless it's a batch of 10 or more, the costs get pretty high. they charge me $350 just for tooling before any actual blanks or CNC is done. The final part is black anodized aluminum.
| The Following User Says Thank You to B T For This Useful Post: | CSG Mike (10-26-2021) |
#4339 | |
I've seen all of 2 people go to K series motors at this point, so I don't think it is correct to say it is a common thing. EJ's get shit mileage, have no compression so they only make power when on boost and still blow up all the time. The FA motor is superior, but you are somehow talking about doubling its output and being suprised it blows up. Why do you need 400 whp? What are your goals? I had ~2700 with an Edelbrock and the car was very quick, breaking traction through 3rd. 400 hp in this car would be nuts on the street. No matter how you go you are looking at $15k to get there with any kind of swap (at least) or a built FA20 and some kind of monster tranny to go along with it. |
| The Following User Says Thank You to toast For This Useful Post: | Tatsu333 (10-26-2021) |
#4340 | |
Drives: 2017 BRZ Series. Yellow
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
