Old 05-09-2016, 01:10 AM   #421
zeal86
zeal86's Avatar
Drives:
Originally Posted by Mike&Ike View Post
Check out the KTS coolant tank. I think it would complement your engine bay nicely. I have one and the construction is very well made. It only like $180.
thanks... I'll take a look at it...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 05-09-2016, 01:12 AM   #422
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Originally Posted by zeal86 View Post
I don't even wash my wheels on the 86...jajaja I cover them up with towels... then I jack up the ride after I'm done washing and drying it... I then remove them one by one to clean and polish the wheels and shine the tires. Oh ya, I clean and Armor-All my fender liners while I'm at it too. My Runduce BBK never gets wet... jajaja
You must be kidding me ahah
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 05-09-2016, 01:17 AM   #423
zeal86
zeal86's Avatar
Drives:
Nope... that's how I roll...
Old 05-09-2016, 01:59 PM   #424
zeal86
zeal86's Avatar
Drives:
It was too much trouble to modify the polished plug I installed in the resonator hole a while back... just sticking to the instructions and using the supplied rubber plug on this one...
I should have the modified air box installed this afternoon... then I have some really minor things to do before I go back over my install.
Old 05-10-2016, 12:02 AM   #425
zeal86
zeal86's Avatar
Drives:
Well... I effed up the HKS supplied stopper for the resonator opening... I measured my cuts from the outside and not the inside... So now I have to find a replacement tomorrow...
I started this detail today... I am in the process of creating a packing to replace the flimsy factory one. I have to make some adjustments but here is where I am at with it...
I hope to make the adjustments and have this completed tomorrow.
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (09-06-2016)
Old 05-10-2016, 07:51 PM   #426
zeal86
zeal86's Avatar
Drives:
Here is a pic of my custom foam packing... it turned out well...
On another note... the HKS air intake duct I received today does not fit...the intercooler outlet pipe gets in the way... I do not want to modify it so I'm going to just modify the OEM air intake duct and be done with it.
Bummed that neither the Beatrush nor the HKS air intake ducts fit without modifications. :-(
Instructions made it seem as if I had the HKS part that it would be plug-and-play...smh
I'm still tinkering with the fitment of the OEM airbox...I hope to square everything away soon.
Edit:
Airbox fitment issue was a mistake on my part... to the naked eye, the remaining silicone sleeves looked identical in size... anyway, I had them mixed up...all good now!
Old 05-12-2016, 12:57 AM   #427
zeal86
zeal86's Avatar
Drives:
Finally complete! Well, not quite... but real damn close. I just have to tie up some loose ends...loose ends that are indirectly related to the SC install and go back over my install to make sure I did not miss anything.
All I have left with the actual SC install is fluids, flash the ECU, and cranking her up!
Tada...
The Following 8 Users Say Thank You to zeal86 For This Useful Post:
8R6 (05-12-2016), ajaxthebetter (05-12-2016), Bramick (05-16-2016), Clipdat (05-16-2016), D88 (05-12-2016), gkubed (05-15-2016), Koj (09-06-2016), new2subaru (05-12-2016)
Old 05-12-2016, 04:55 PM   #428
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Wub wub wub.... beautiful build
The Following User Says Thank You to SkAsphalt For This Useful Post:
zeal86 (05-12-2016)
Old 05-12-2016, 05:03 PM   #429
8R6
8R6's Avatar
Drives: FRS
that is amazing.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
zeal86 (05-12-2016)
Old 05-12-2016, 11:51 PM   #430
zeal86
zeal86's Avatar
Drives:
Some preventive measures I completed today...
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Bramick (05-16-2016), Koj (09-06-2016)
Old 05-14-2016, 07:02 PM   #431
zeal86
zeal86's Avatar
Drives:
It's alive!!!
Installation manual stated there could be some noises emanating from the supercharger until the traction fluid warmed up (2-3mins)... ecstatic to say there were no weird noises on startup at all! The traction cooler operated as normal. No coolant leaks or fuel smells as far as I could tell. The only thing that was off but expected was the smell coming out of the exhaust system... that smell can be attributed to the new exhaust manifold and front pipe. It wasn't even that bad though.
I'm going ro wait until late next week or the weekend to take her out on the road... I should have my aero kit back from the painter by then... I need to have that installed before I go for a test ride.
Barring any unforseen issues, I am very relieved to have this install complete!
D88 (05-14-2016), Kris86 (06-21-2016)
Old 05-15-2016, 10:05 PM   #432
zeal86
zeal86's Avatar
Drives:
I test fit my bumper cover today to see if I would need to modify it at all... the answer is yes.
I have to shave the bumper a bit on the oil cooler side and on the bottom of the deck that intercooler and oil cooler sit on. The intercooler and oil cooler push down on the deck so I'll have to shave some off the bottom so that the bumper cover could wrap around it.
I have a feeling that I'll have issues with bumper fitment near the headlights so I've ordered 2 Quick-Latches... so I'll be installing those real soon.
Old 05-16-2016, 04:16 PM   #433
zeal86
zeal86's Avatar
Drives:
My build received a mention on HKS USA's official Instagram today!
https://www.instagram.com/p/BFeQyd6syP7/
The Following 10 Users Say Thank You to zeal86 For This Useful Post:
8R6 (05-16-2016), AznKirby (05-17-2016), Clipdat (05-16-2016), DustinS (05-16-2016), GTHachiRoku (05-16-2016), Hot-Lava_Dave (05-16-2016), Koj (09-06-2016), Kris86 (06-21-2016), mmmcambelsoup (05-16-2016), stevemp5 (05-16-2016)
Old 05-16-2016, 07:50 PM   #434
hellokyles
Drives: Not running
That's a whole lot of beautiful in that bay.
hellokyles is offline   Reply With Quote
The Following User Says Thank You to hellokyles For This Useful Post:
zeal86 (05-16-2016)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
