#421 |
Site Moderator
Drives: Stuff
I'm running a cooler and have not had a failure...... Yet.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#422 | |
I'm not saying you wouldn't, but that's their thought process. |
#423 | |
Drives: Attitude
@CSG Mike I think you should start linking good/interesting posts in the OP.
eg #406, #412, #417, #421 And those are just from this page... Quote:
I have done many things that were grueling, painful, and wasteful even...because I am a principled person. |
#424 | ||
Hail Magnet
TL : DR--"The squeaky wheel gets the grease" |
| The Following User Says Thank You to HunterGreene For This Useful Post: | 2forme (06-06-2013) |
#425 |
Drives: 2013 FR-S Ultramarine
I drove over an hour back to my dealership when I had the cam sensor issue one day after I bought the car. I made it clear I was very unhappy. A month later my free 7 year 100k warranty paperwork showed up.
| The Following 2 Users Say Thank You to SubieNate For This Useful Post: | HunterGreene (06-06-2013), Marrk (06-06-2013) |
#426 |
Hail Magnet
Had a similar issue happen after the dealership screwed up the S/C installation on my previous car (tC). And it turned out to be well worth it when the synchros in 3rd and 2nd gear wore out around 80k miles.
#427 |
Apostle
Drives: JesusMobile
#429 | |
| The Following 2 Users Say Thank You to suaveflooder For This Useful Post: | HunterGreene (06-06-2013), whataboutbob (06-07-2013) |
#430 | |
Drives: SSM LT MT BRZ
I had addressed this earlier in the thread, but I will bring it up again here. I have several of the "other" direct injectors here at work on my desk, (we make upgraded pumps for DI motors among other DI solutions) All gasoline direct injectors i have sampled (except the siemens provided bmw injectors) use very nearly identical injectors, all that changes is the orientation, spray pattern and mounting tabs. this goes for both the Denso and the Bosch injectors, they all use this Teflon band to seal to the head and all in the same location ours is neither closer or further away than any of the others. Considerations not yet mentioned? perhaps the tolerances on the head are not as tight as the other manufacturers? if there is even .0003 more clearance in the diameter where this seals in the head, it could make all the difference in the world as far as heat transfer, and integrity of the seal. Lets quit blaming the seal though, it hasn't been an issue in audi's Mazda's nissan's or chevy's yet....the problem lies elsewhere. BTW you aren't gona find any ceramics that will stretch to get down into the relief where this seal sits. |
| The Following 7 Users Say Thank You to SkullWorks For This Useful Post: | Bristecom (06-06-2013), CSG Mike (06-06-2013), Hawaiian (06-07-2013), Marrk (06-06-2013), robispec (06-07-2013), Sportsguy83 (06-06-2013), Xero-Limit (06-06-2013) |
#431 | ||
Grip>Slip
http://www.therpmstore.com/store/p/5...-3-6-CX-7.html Quote:
or is that a different part all together? |
#432 | |
Drives: SWP Subaru BRZ Limited MT
This guy saw a peak oil temp of 276F while on track running a completely stock motor. ![]() http://www.ft86club.com/forums/showp...&postcount=309 Even just normal driving around town without any heavy throttle is producing fairly high temps. http://www.ft86club.com/forums/showp...&postcount=181 http://www.ft86club.com/forums/showp...&postcount=182 Perrin also documented the power loss that is associated with high oil temps in this car on their blog. http://blog.perrinperformance.com/pe...-s-oil-cooler/ In my opinion 276F (or really anything above 230F/110C) seems like it is WAY too hot for engine oil to be sitting at. After my oil cooler, I usually sit around 175F and peak around 185F during around town and freeway driving while on the track during 30 minute sessions, I usually average around 215F while peaking to 220F every once in a while. |
#433 |
The teardown was authorized by the regional rep. The teardown was extensive enough that the entire engine was taken out of the car, and as you can see from the pictures, more or less have the entire engine completely apart.
| The Following User Says Thank You to CSG Mike For This Useful Post: | P@ul (06-06-2013) |
#434 |
I usually post drunk
Any final word on the conclusion? i.e. who is financially responsible and why.
| We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 09:55 PM |
| Denied service... | Chen | Northwest | 37 | 09-13-2013 09:37 PM |
| HELP with diminished value claim! | zohare | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-03-2013 12:17 PM |
| Hit and Run Insurance Claim | CharlieChaos | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 12-26-2012 09:54 PM |
| Japan loses its claim to "Creepiest Asian Country" | reni | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-08-2012 12:57 AM |
