Old 07-21-2013, 03:09 PM   #421
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I used Raammat, the area doesn't rattle anymore
I also did the opposite side
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following 2 Users Say Thank You to tonystewart For This Useful Post:
clintavo (11-08-2014), Sigh-on-Rice (07-24-2013)
Old 07-24-2013, 03:15 PM   #422
beachbum
Drives: Fr-S
Originally Posted by Mikepage View Post
I fixed mine finally, with this : Under glass cardboard
Cost : 0$
Result : No noise anymore
Thanks. I did this and it worked. No more rattle and clicking.
The other people are just wasting their time and cash.
beachbum is offline   Reply With Quote
The Following 2 Users Say Thank You to beachbum For This Useful Post:
Marrk (07-24-2013), Mikepage (08-12-2013)
Old 07-24-2013, 03:22 PM   #423
Marrk
Drives: Honda Fit
^^I admire the elegance of this solution. It's clean, simple, dirt cheap, and completely reversible.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
Old 07-26-2013, 01:35 AM   #424
van_fc3s
Drives: GT86
thank you for the solution. It was bothering me for weeks and a common wd40 does wonders. so far so good and fingers crossed.
van_fc3s is offline   Reply With Quote
The Following User Says Thank You to van_fc3s For This Useful Post:
Old 07-27-2013, 11:44 PM   #425
avholic
avholic's Avatar
Drives: BRZ WRBL6MT
The TSB for rear-deck popping issue didn't work on my car, so the dealer/service dept did this to fix the issue.
Now I need to buy some spray paint to keep the rust off. I should have tried the suggestions on this thread before getting the warranty work done. Too late now.
avholic is offline   Reply With Quote
The Following User Says Thank You to avholic For This Useful Post:
Marrk (08-01-2013)
Old 07-28-2013, 11:11 AM   #426
tonystewart
Yes
Old 07-31-2013, 10:46 AM   #427
mmarkFRS
Found rattle in ceiling area and I was able to solve
There is an area in the roof, where there are two spot welds right above thedriver side. Locating this was very difficult. It was only after I exhaustedevery possibility that I was able to find this. I literally had the back seatdown to the metal.
This spot was very deceptive; I thought it was in the trunk, or the air bagfasteners. Needless to say it wasneither of these issues. I also triedcenter punching the spot welds in the trunk, and taping down the fasteners inthe trunk below the spare tire.
If you remove the top ceiling (there are three plastic fasteners that holdthe ceiling in place). And you removethe side panel on the driver’s side you will see a dip in the metal directlyabove the driver side (right behind the sensor). If you put a little pressure on this spot therattle stops.
I took a piece of a rubber door stop and wedged it in, and this correctedthe rattle. I will be posting picturessoon.
I hope this helps.
mmarkFRS is offline   Reply With Quote
The Following User Says Thank You to mmarkFRS For This Useful Post:
civicdrivr (07-31-2013)
Old 07-31-2013, 10:36 PM   #428
ayilar
Drives: BRZ, MB C350
Thanks a lot for this. First experienced a ticking/clicking sound 3 months ago -- fixed by opening and closing the rear seatback. Experienced a similar noise again at the end of a 3k mile trip through twisties. This time opening/closing the seatback did not help, indeed if anything the sound got worse. After reading this thread, I tried a glass coaster-like solution. It worked in that 90% of the sound is gone. Reversibility is key to me.
Will experiment with variations in the next 2-3 weeks and hope to get 100% solved.
Only issue I've had with my car.
2013 BRZ Premium MT (lightning red)
2008 MB C350 PII (steel grey)
ayilar is offline   Reply With Quote
Old 08-01-2013, 10:40 AM   #429
djdnz
1337
Drives: 2013 BRZ WRB S/C
WTF!!!!
Send this to Subaru and get some sort of compensation. No way they should have done that to a brand new car.
I brought mine in yesterday and they fixed the rattle for me using the TSB, but reading this thread makes me worry it might come back. We shall see. For the moment I am a happy camper, this noise was driving me bananas.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
microbionic (08-01-2013)
Old 08-01-2013, 02:45 PM   #430
Marrk
Drives: Honda Fit
That's appalling. I don't think of this as a "grey area" f*ck *p. This is a solidly in the Red Zone f*ck *p.
Old 08-02-2013, 02:52 AM   #431
Sideways?
Drives: Toyota GT86 - Blue - Leather - Nav
Why do you need to buy some spray paint?! Surely the cack-handed dealer that did such an appalling job in the first place should be doing the touch-up... At least...!!!
Current Mileage: 5900 - And I still love it to bits!!
Sideways? is offline   Reply With Quote
Old 08-06-2013, 09:33 PM   #432
im2fr-s
Took the ride into the dealer today for the third time to fix this issue. It looks like they finally found it... so far no clunk. The pics show where the noise was coming from. It's the drivers side of the trunk. You can also see where they used a hammer drill to tap the welds. Hope this helps.
Sent from my SPH-L720 using Tapatalk 2
im2fr-s is offline   Reply With Quote
The Following User Says Thank You to im2fr-s For This Useful Post:
Sigh-on-Rice (08-06-2013)
Old 08-07-2013, 11:15 PM   #433
PNW FRS
PNW FRS's Avatar
Try this solution.. it seems to have worked for me...
And as noted in OP.. only took about 30 seconds...
http://www.ft86club.com/forums/showthread.php?t=42065
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 08-08-2013, 09:15 PM   #434
PNW FRS
PNW FRS's Avatar
Unbelievable... taking a hammer and whatever else to pound on the area and break the paint. This should be brought to the attention of the Regional Service Manager... completely unacceptable "service".
2013 Asphalt / MT
Olympia, Washington
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
