09-19-2017, 04:38 PM | #421 | |
Drives: 2014 FR-S
1-Are centering rings part of the wheel? 2-Are spacers part of the wheel? 3-Are balancing weights part of the wheel? 4-Are we just going on published mfr data? Left to my own biases, I'd think only #3 would fly, but I can see any combination of those as not being terribly unreasonable ways for defining things.
-Mike
#24 CS/CSR |
09-19-2017, 04:42 PM | #422 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
09-19-2017, 04:51 PM | #423 |
Drives: '15 STX
Glue the centering rings to the wheel. They're now part of the wheel "as-raced". 949racing 17x8 +40 wheels with lead centering rings.
The Following User Says Thank You to tony_r For This Useful Post: | Shark_Bait88 (09-19-2017) |
09-19-2017, 06:05 PM | #424 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
If we go only by manufacturer listings, then we could end up with the same BS we got when we decided to define 200TW as whatever a given manufacture says is 200TW. We also have the issue of unlisted weights. This is usually with heavy wheels but unlisted shouldn't mean illegal when weight is easy to verify. At least with TW, every DOT tire has it listed on the tire. Wheel weights....not so much. I don't want a 20lb wheel to be illegal because the weight isn't listed and I don't want 12lb wheel to be legal if a manufacturer decides to list it as 17lbs. The ballast rules for classes that have minimum weights just say it needs to be secure. I don't remember seeing that ballast specifically needed to be "part of" the car. Valve stems and wheel weights are secured to wheels as is a coat of paint. I personally would not object to including hub-centric rings and spacers so long as they are safe. Last edited by Twinz; 09-19-2017 at 06:30 PM. |
09-19-2017, 08:27 PM | #425 | ||
Drives: Toyobaru FRZ
They will be off the car in early October once my Konis come in. These are the Street class legal variants (the 'standard' shorter body is not Street legal). It comes with spring perches for OEM and OEM-like (TRD) springs. I also purchased a separate set of 60mm spring perches for aftermarket 60mm springs in case I wanted to go STX that I can throw in too. Those are a little over $100 if you buy separately. I also have the dyno plots from MCS for the front and rear. Shocks have one season of autocross on them and about 8k~ street miles (3k~ of which is driving back and forth to Nationals). Performance wise, they've been great, I've been very happy with them. Sad to see them go but I can't use them in SSC. Hard to explain this briefly but they are also eligible for a free rebuild/service from MCS as a part of a warranty job. Basically the shocks in the current configuration (OEM Springs, stock ride height), the rears make a rattling/knocking noise when driving over broken pavement/bumps at lower speed. At higher speeds and smoother roads like highway the noise isn't there. This seems to be somewhat normal based on what the MCS webpage says... Quote:
Anyway, I contacted MCS about the noise and they said that my set was manufactured before they did a change over to a newer design of some parts which helps with this. MCS offered me a no-cost warranty service that replaces the older components with the newer redesigned components. The job basically rebuilds the shock as well. Since the noise has no issue on performance of the shock and the car isn't my DD, it didn't bother me all that much so they suggested to run the shocks until it needed a rebuild/service before sending them in since I'd be getting a free rebuild out of it. Since the shocks were still basically brand new it made sense to me to run the car for a while first. I've already been in touch with MCS and they will honor that warranty service for the next owner. MCS is really good about this stuff and my experience with them has been great. Anyway, if you or anyone else is interested, send me a PM. Last edited by Jawnathin; 09-19-2017 at 08:46 PM. |
09-20-2017, 07:48 AM | #426 | |
Drives: 2022 Toyota GR86
swap out of your current struts.
Eric
2022 Toyota GR86 Steel |
09-20-2017, 10:08 AM | #427 |
Drives: 2013 Asphalt Scion FR-S
I'll be moving out of DS to SSC and just like two others above, there may be a set of street legal two-way remote reservoir MCS shocks coming onto the market. It's complicated, because I'm not going to be the one selling them personally, if they are for sale, but if there is any interest in this top shelf version of the MCS's, let me know.
I'll also have two sets of Kosei 17x7 wheels for sell I'd imagine. |
09-20-2017, 10:36 AM | #428 |
I'll put it this way, if anyone wants to give me their used MCS as an early-wedding gift I'll happily invite you to my wedding.
09-20-2017, 12:34 PM | #429 |
just think of it as your wedding present to your new bride?
Eric
The Following User Says Thank You to edj For This Useful Post: | Shark_Bait88 (09-20-2017) |
09-24-2017, 07:16 PM | #430 |
Corvette convert
For anyone remaining in CS/DS, I'm selling my MCS 2-ways:
http://www.ft86club.com/forums/showthread.php?t=122229
John W. | 191 DS
09-24-2017, 09:22 PM | #431 |
I knew MCS shocks were supposed to be awesome, but I had no idea so many people were running them. I will probably have a set of off-the-shelf one-season Koni yellows up for sale in a couple months
09-26-2017, 10:32 PM | #432 |
Drives: 2013 Scion FR-S - Raven
I also am planning on making the switch to SSC. Here is another set of MCS 2WNR for sale:
http://www.ft86club.com/forums/showthread.php?t=122292 |
10-07-2017, 10:26 AM | #433 |
For people like me who aren't well connected yet:
http://apexjunky.com/2017/10/ultimat...8z-xg.facebook |
The Following User Says Thank You to strat61caster For This Useful Post: | cueball89 (10-07-2017) |
10-07-2017, 12:36 PM | #434 | |
Custom User Title
It's interesting results but there's a lot of variables still to this. The FR-S is the only one on two way MCS and then the RS is on Konis. Civic and Camaro still on OEM shocks. I know Mark and Des have said they don't feel the Camaro would get much out of shock and sway bar upgrades but it would certainly gain something, right? Another thing is familiarity with the cars. Annie drives an STX FR-S and has driven them in STX basically since they came out in 2013, Mark used to drive a twin in STX too (???), and I don't know Justin Moore so not sure what he's driven before. Kind of shocked the RS did so poorly. I knew it struggled in BS this year but wow. Also expected the Civic Type-R to do better. When we see more development for that car will it get stronger results?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
