Old 12-15-2017, 07:45 PM   #421
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is it 1.36 bar or 19 psi including atmosphere or 5 psi of boost on the gauge, or is that 1.36 bar above atmosphere and thus 19 psi of boost on the gauge?
That's MAP, so 0.36 bar of boost. However mine is a Sprintex and running the OEM sensor, so capped reading. Where the output is 1 is where it's going into positive pressure.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-15-2017, 09:18 PM   #422
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Kodename47 View Post
That's MAP, so 0.36 bar of boost. However mine is a Sprintex and running the OEM sensor, so called reading. Where the output is 1 is where it's going into positive pressure.
So it looks like at 40-50% of accelerator pedal is where boost starts.
Old 12-16-2017, 12:28 PM   #423
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is on mine, however I have what I guess most would deem as soft pedal mapping so I would expect a more standard map to be around 10% less.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-16-2017, 04:52 PM   #424
Irace86.2.0
10% seems low, as if highway driving would have enough pedal to be in boost. Is that what people are getting?
Old 12-16-2017, 05:21 PM   #425
toast
Drives: 14 BSP Edelbrock BRZ
10% less than the 40-50% since he has a soft pedal mapping...
toast is offline   Reply With Quote
Old 12-16-2017, 06:43 PM   #426
Irace86.2.0
Thanks, yea, so I’m still curious if people are seeing boost like are you guys getting 1-2psi at 70mph or is the bypass setup for max efficiency?
Old 12-19-2017, 02:37 PM   #427
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by johan View Post
Already been down that road. Add too much and the car won't move (literally the car died on me several times when pushing the gas pedal to leave my driveway because the motor couldn't compress the air to splode it) add too little and it's bog (because of soul crushing ignition retard from having 12psi of boost at 1800rpm) then POWER (when it recovers), spinning the tires from every stop light looking like an asshat.
It's reasonably dialed in now, but I still get some gremlins when trying to drive sedately. Sometimes I'm tired and I just want to leave a stop light like a normal human being.
It'd be so much easier if I just had something statically pulling boost out at low RPM. Then the car could be tuned normally. I had a setup like this on a previously supercharged car and it was really nice.
The slushbox isn't doing me any favors here.
Sounds like there is something majorly wrong with your hardware/tune. There is no way you can be in boost starting off from a start. And you shouldn't be having any driveability issues.
I am on the 70mm pulley and have stage 3 piper cams and have 0 driveability issues. Also there is no where near any kind of boost when putting around town. The bypass valve will be bleeding off any pressure at these low load conditions.
Old 12-19-2017, 03:09 PM   #428
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
I've had the same issues. Still trying to contact the group that tuned the vehicle. It predominantly happens in warmer weather.
I've also had P0171, P0172, C1201, C1231, and C1241 codes over the course of this. Also, the intercooler pump relay's fuse blew not too long ago which was a giant surprise.
Trefoil is offline   Reply With Quote
Old 12-22-2017, 03:13 AM   #429
sw20kosh
Wanted to share my track build. Very happy with this kit so far. Thanks @HarropOz
Harrop Kit at 15-16 psi on a CSG spec Blue Moon assembled motor with stage 3 Piper cams on e80 flex fuel.
Generating massive heat from the power, so needed dual oil coolers to keep temps down (2x 25row setrabs). Built ducting for all heat exchangers. Temps are looking good now!
Old 12-29-2017, 10:42 PM   #430
xwd
What compression ratio is that motor?
Old 12-29-2017, 11:41 PM   #431
Irace86.2.0
@HarropOz New Years Resolution: CARB EO for 2018
Old 12-31-2017, 01:48 PM   #432
sw20kosh
12:1
Old 01-04-2018, 11:57 PM   #433
byun
byun's Avatar
Drives: 2015 BRZ CWP
Looking forward to joining the owners club. The struggle of waiting is real...
byun is offline   Reply With Quote
Old 01-05-2018, 05:43 PM   #434
CxG
Drives: Pearl White '13 ZN6
so what happens when you run out of corn juice? with the compression ration you got is it still possible to safely run 93 octane?
CxG is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
