#4285 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
| The Following User Says Thank You to brandonblt2 For This Useful Post: | dpfarr (09-21-2021) |
#4286 |
Drives: Asphalt 2016 FR-S
Bought a kit from Summit a few weeks ago. Intake runner is damaged where it pairs to the block (the flange that holds the gasket). Summit is refusing to help because it was "open-box", though when buying it they assured it had only superficial damage, not functional damage. Now trying to source the part through Edelbrock but their customer service is a nightmare. Each call to tech support is 1 hour on hold and the one time I actually got them to answer, the guy told me that he couldn't look up the price/ordering info and that he would contact the people who could and get back to me. 1 month and several emails later, no response.
Does anyone have an extension for someone in the supercharger support department or any idea of how to get through to them? Thanks |
#4287 | |
Drives: BRZ ts
The idle is struggling unless I give it a constant bit of gas. No leaks on the lines or injectors. I’m going to look at atmospheric pressure vs map pressure and see if that might be the issue. |
#4288 | |
Drives: 2017 Toyota 86
See your PM. Summit should really be resolving this issue for you if they sold something not as advertised. |
| The Following 2 Users Say Thank You to Z06ZN6 For This Useful Post: | BrahmaBull1990 (09-21-2021), shaqin (09-21-2021) |
#4289 |
Summit basically said, "tough shit, you bought open box and assumed the risk. Contact Edelbrock for replacement parts". I will probably escalate to corporate soon but I wanted to at least see what the damage would be to replace. If it's a few hundred dollars I will save myself the hassle and just buy it. If it's like $400+ I will try and escalate to Summit. As of now neither company is being helpful so I'm a bit stuck between a rock and a hard place with a $6k paperweight.
#4290 |
So you were able to reinstall the oem pump or the new pump?
#4291 | |
| The Following User Says Thank You to Z06ZN6 For This Useful Post: | shaqin (09-22-2021) |
#4292 |
Drives: BRZ ts
I took out the basket and made sure the DW pump was tight, all the clips were on, no hoses pinched, etc. It started up.
If I have time after work my plan is check MAP readings, 2. revert tune, and then see what happens. The D box isn’t lit up and I’m hoping it’s not that, I don’t really want to buy one. Might take a little vacation and drive it to CSG to get a non D box flex fuel tune. Last edited by dpfarr; 09-21-2021 at 09:36 PM. |
| The Following User Says Thank You to dpfarr For This Useful Post: | brandonblt2 (09-22-2021) |
#4293 | |
Drives: 14 BSP Edelbrock BRZ
#4294 | |
That Guy
Drives: 2013 asphalt FRS MT
#4295 |
Here are the pics. Machine shop is definitely an option but I'm really hoping to understand the process/price for a new runner(s) before trying to fix this one. Not sure how I'd test whether the fix worked without installing and running.
I appreciate the messages from y'all with contact info. |
#4296 |
Drives: BRZ ts
I wouldn’t install that either. You should have considered shipping damage??
#4297 | |
That Guy
#4298 |
I'd be super pissed, but I suppose you could fund an aluminum welder to fix that. Take it to a machine shop after and have it decked.
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
