Old 06-21-2016, 01:33 PM   #4229
AlanLGuy
Drives: Raven 6 speed Manual FRS
Originally Posted by DylanFRS View Post
Hyundai Genesis attendance is also dismal. Does that mean we need to find it a class it can win? No.
Sorry, this won't be popular on here but I lost my empathy for the BRZ after too many threads of "I'd rather die than be caught driving a Scion". Let's face it, at the end of the day there are enough FR-S's for every single BRZ owner in the SCCA to easily go trade into one. I have seen people drop $4k on a whim to get new wheels/tires for their BRZ before all of this TRD BS. I think if you can afford that, you can afford to make the nearly straight change from the BRZ to the FRS, IF being competitive at autocross is your top priority. If having the Subaru logo is that important to you, I can't imagine that you are really in the position to complain about the relatively small different between the two.
I run an FR-S, and it's a dedicated autoX car, but a lot of friends have a BRZ because it's simply a nicer car to daily drive and serve as a weekend warrior. The alcantara, heated seats and general fit and finish of the BRZ make it a better daily. I support the move to DS. Personally I think moving the BRZ and non-TRD FR-S makes the most sense (they are identical cars after all) I see the TRD FR-S as similar to the MSR Miata(though obviously the parts and availability are much higher)
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 06-21-2016, 02:11 PM   #4230
AlanLGuy
Originally Posted by totopo View Post
Why does every trim of the 86 deserve to be competitive? Why do you want to crap on a second class in order to have more 86's? At least there still are brz's in the mix. The 370z got bumped from cs because of all the 86 qq and now it's basically gone from solo2. and now that there's a better 86, you all want to dump on ds now too?
370z wasn't just beating the twins, it was beating the 350z, the NC Miata and the RX-8 all popular autocross cars. It unbalanced what was a nice competitive class. There's no reason the 370 couldn't be competitive in BS, but there are multiple other affordable, proven cars that are the easy button.
The thing that really killed the 370 in solo was the STR classification that also restricts tire/wheel size to narrower than the stock sport optioned car. NOBODY wants to go into a more prepared class and have to downsize on tire/wheel width.
The difference here is that DS is practically non-existent. Reg numbers have been dwindling locally and the class is practically non-existent at national events, injecting the BRZ and FRS will more than likely give new life to the class, while the ND Miata keeps CS fairly well subscribed.
Old 06-21-2016, 04:13 PM   #4231
simpleisbest
Senior Citizen
Drives: Scion FR-S
I hate seeing this misinformation!! No, the FR-S and BRZ are not identical, as spring rates are different (BRZ has stiffer Front).
MSR comparison is totally non-applicable. MSR was never really produced and very expensive. TRD parts can be had for less than $700 shipped and are actually a port installed option (Yes, there are actual workers at the Port of LA installing these) vs the MSR which was a non-existant trim.
Too many idiots cry conspiracy about the port options, when it are no different than any factory option, but applied to imported vehicles.
Maybe their isnt enough " 'MURICA " to get these idiots to understand?
I mean, does anyone complain about the Corvette Z51 package factory options? No.
Are there separate class for Z51 and non-Z51 Corvettes? No.
By using the same argument of splitting a car by factory line item options (not by trim), should the non-Z51 Corvette now be in C-Street??
If they do this for the twins, why shouldn't we see this for other cars?
People need to wake up and accept the fact that there will not be a proper home for all cars in Street Classes. That is the nature of the class and rules.
If you want parity and equality, go buy a CRX and go STS.
simpleisbest is offline   Reply With Quote
Old 06-21-2016, 04:25 PM   #4232
gtslow
Drives: 2015 Halo FR-S
Originally Posted by NJ10 View Post
^Pushy brz checking in.
As to those opposing the changes, do you have an alternate suggestion to balance it out? The brz attendance is dismal at best at a lot of national events. I'm still running mine because I'm a noob and there is a lot of driver skill that needs fixing before I can actually compete to stay midpack or close to trophies, but I wouldn't want to run an underdog in a competition if I was better. Driving both the FR-S and BRZ at prosolos, the FR-S felt much better and less pushy. That minimal camber gain, a stiffer rear bar definitely do help.
Write to support allowing TRD for the BRZ if you don't want them moved to DS.
No suggestion to fix it because I don't really think it is a problem. This has been said before, but I think the advantages one twin has over the other falls well within the range of statistical noise. When you have different cars competing in a single class like this there will always be a car or two that float to the top. It is unfortunate, but not everyone's chosen car and trim level is going to be the "lucky" one that turns out to be the fastest. Given the changes coming in the 2017's and a performance package which gives the BRZ an extra half inch of wheel width, there might be a big shift in the "twin to have".
gtslow is offline   Reply With Quote
Old 06-21-2016, 04:49 PM   #4233
AlanLGuy
*rolleyes*
I'm sorry, maybe I should have said there a no "meaningful" differences between the two.
As soon as you add an aftermarket shock the spring rate differences are irrelevant and handling can be tuned with shock settings, even if you don't do adjustable shocks, simply adding a bigger front bar on the FR-S or a stiffer rear bar on the BRZ gives it similar handling characteristics as the other.
With the street class allowances a FR-S or BRZ can be made to handle just like the only meaningful difference is the FR-S gets many more sway bar setup options and a stiffer spring and lower ride height and therefore has an advantage over the BRZ.
But if people were really srs bzns they'd have got the FR-S in the first place because it's lighter than the BRZ(which you forgot to mention by the way)
Old 06-21-2016, 04:54 PM   #4234
TrqlessWonder
Drives: 2014 FR-S
Here's the thing. With the proposal, we only *think* it'll be a fairer/more level place to play. As always with things like this, the proposal is not surgically-limited to just one or two cars. No, they are basically re-doing/taking back a lot of the stock>street switch.
So, now you get to take your chances against a lot of formerly-FS cars. I'm not sure that's going to prove a favorable trade-off.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 06-21-2016, 06:00 PM   #4235
strat61caster
strat61caster's Avatar
Originally Posted by AustinTX View Post
I stopped trying to AX my BRZ long ago, but I'm curious why you care so much about this. Typically, people that don't have the car don't care, and the people that have the car are the ones challenged to lobby for change. Seems like enough people are asking - why continue this effort to kill the campaign? BTW, I wrote a letter to simply divorce BRZ and FR-S. It is kinda silly to bring the 'non-TRD' FR-S down with the BRZ. They are already unique cars, so it would be easy to treat them as such and split them cleanly.
Besides, all this nonsense about the difference being less than typical driver noise tells me you have not yet felt the power of BRZ understeer
The move does not impact you, so why get in the way?
Splitting up the classes and introducing unnecessary complexity reduces field sizes and thus competition. I'd rather race midpack in a class of 20 than finish 2nd in a class of 4, seems kind of shitty to assume everyone is just there for a trophy. But maybe I've got the read of it wrong, I certainly don't know much outside my region. This isn't a change that 'improves BRZ competitiveness' imo, it's a change that reduces the size of CS and adds unnecessary complication.
People with BRZ's aren't turning up because they can't win? Bullshit. The people that care that much about winning have already eaten the cost of getting into a more competitive car (like you already have and you're unlikely to return even if the rules change correct?), the % of BRZ owners not showing up is the same as the % of FRS owners who don't show up, they simply aren't interested. People don't run SCCA because it's a quagmire of rules and nitpicky bullshit like this, adding more makes the situation worse, not better.
Yes, assuming it truly is unbalanced, allow an exception for the 86 variants (and only the 86 variants at this time) to share parts. You keep the CS field big and "level out" the playing field. The casuals will remain casuals, the bitchy guys will start complaining about how the '13 FR-S is lighter because they don't have a touchscreen headunit and alacantara and now they want to change that too and we should amend the amenities rules.
YTD, there have been 57408 FRS:27591 BRZ
~2:1
Like above, not many Hyundai's show up, should we make a Hyundai class so they can win? Of course not. BRZ attendance will always lag FRS attendance, basic economics. I looked it up, I could only find 4x Subaru dealers in Nebraska, I'd wager there are <100 BRZ's in the state, is it a wonder none showed up to the Lincoln tour? Meanwhile at a local event a few weeks back the CS class had 4x FRS and 4x BRZ, and btw the top 5 finishing order was ND, BRZ, FRS, FRS, E36 M3 with about 1s covering the difference.
Meanwhile another local club does classes based on a points system, Mini coopers up against M3's up against 1 series convertibles in varying stages of modification, 1st-5th in that class was covered by 0.1s.
Shit, wrote a small essay about a class I'm not competing in.
ineedyourdiddly
Old 06-21-2016, 06:56 PM   #4236
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
What are you quantifying this statistical noise by?
Sure, some trims might not be the ones to have to win classes. And now the ND is the car to have in CS, rendering maybe the whole 86 platform useless soon. But, the other cars in CS have a fighting chance in some courses because of some disadvantages the 86 has or some advantages they have. (a course that tops out at 58 may help us and hurt the ND, etc.) But in every course, the FR-S will be better than a BRZ because of constant added benefit.
When other trim levels have been bumped/dropped for other cars, why do you think this trim change is insignificant? Would you be willing to drive a non-TRD FR-S to compete against TRD examples to understand the deficiencies?
The BRZ is a decently popular car and great to introduce people to autocross locally and NATIONALLY(where attendance has taken a hit). What is the flipside of an providing an exception/solution to balance it out and get more attendance at national events?
Personally, I did my first two ProSolos this year, second year autocrossing overall. I drove my brz in the first one and a friend's FR-S in the second one. My position was DFL in both, but I felt I drove much better in the FR-S and had better position by raw times and actually got the car to rotate instead of pushing like a motherf***er like my brz does. F**K the springs, all I want is the rear bar for now.
~2:1
At the Lincoln Champ tour,
1 car from Nebraska showed up - it was a '16 miata.
the distribution was - 10 FR-S, 6 Miatas(NC&ND), 1 M3, 2 350z, 1 rx-8 and 2 unmentioned
How many BRZs? NONE!
So, 0/22 were brz, 10/22 were fr-s
last year, 2/21 were brz, 9/21 were fr-s
the year before that, 4/16 were BRZ and 3/16 were fr-s
see the pattern? one has been in decline while the other has been in an increase(however small). I picked an event YOU mentioned and showed the trend.
The rate of change isn't even correlated to the 2:1 ratio of sales you mention. It's NOT EVEN CLOSE.
local events WILL have BRZs coming out, because they're convenient. But will the same people make a trip out driving 5-11 hours and staying at a hotel just because they can compete with a weaker car? Probably not.
All I'm saying is that small exception will bring in a lot more participation to the class. If this is not the way SCCA works, pardon me, I'm new.
I don't think anyone's complaining about the heavier car, they're merely stating the exception would not accidentally tip the scales in favor of the BRZ and to keep their tin foil hats back where they came from.
EDIT : I'm not srsbznz enough YET to really worry about the classing. I'll work on improving my driving till it becomes less of a factor for me not being competitive vs. the mods. Would I attend more national events with the brz? Probably not, unless it's close like Toledo! I can get my taste of national competition by having my ass kicked by Sean and Oscar regularly.
meh.
NJ10 is offline   Reply With Quote
Old 06-21-2016, 07:23 PM   #4237
strat61caster
Well yeah, that's why I wondered how many BRZ's are actually driving around America's heartland. You can blame the low turnout on the ruleset just as I can blame it on the fact that if only 1% of 86's go competitively autocrossing, 1,000 FRS = 10x autocrossing, 100 BRZ = 1x autocrossing.
2015 Nationals in Lincoln CS:
24 FRS
11 BRZ
The difference was well known by then, and yet they showed up in reasonable numbers. Will fewer show up this year? Time will tell, your biggest ammo is that there currently aren't any BRZ's registered for this year's nationals.
If the ND trounces the FRS this year will that mean no FRS show up next year and we should reclass that too?
A lot more participation? By your own evidence a grand total of 4 cars stopped showing up to Lincoln for the big tour, you'd get 4 cars showing up in DS at the absolute best case scenario via reclassing and they'd show up at CS instead if they could use the TRD parts.
I'll leave it at this: Based on past experiences, I am strongly against unnecessary class shuffling, complexity, and small classes, because it leads to less people competing with each other resulting lower turnout.
I completely agree with your edit and imo it is the truth for the vast majority of BRZ owners who are interested in autocross: the hypothetical 0.X second difference between the two cars is not what stops them from showing up to more events.
ineedyourdiddly
Old 06-21-2016, 07:35 PM   #4238
NJ10
Stiggasaurus Rex
NJ10's Avatar
Well, the 4 cars could grow with whatever rate the fr-s grew over those 2 years, but yeah, I want to know what Ogburn, Grogan, the Potockis, Oscar, Alan and other really good fr-s drivers would've done if they'd have got the brz when they bought the car. They're good enough nationally for the TRD allowances to make an impact.
Would they just bite the bullet and trade cars? Would they write to SCCA for allowances? or class changes?
I know it's hypothetical, but what would you do? Just trying to get perspective.
to you too!!
meh.
Old 06-21-2016, 08:21 PM   #4239
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I'm really starting to wonder how much of this lack of BRZ attendance is due to the hooting and hollering on this forum versus the actual performance of the car at events. If I had a BRZ and hadn't autocrossed it before I sure as hell wouldn't come out if I had all these people telling me I'd lose to every FR-S because they have an advantage I'll never be able to match.
Everyone tells me that I can't beat a turbo MR-2 at a pro because they gain so much time on the launch but I still go to them. Maybe I should stop attending pros in CS now because I can't launch as fast as the other cars. You know what... I'm going to write a letter to the board asking that the FR-S be re-classed for Pros because it's not competitive. Of course, I'll wait until they move the BRZ first so that they then have to move the BRZ a second time when they complain about the FR-S getting moved back in with them.
Seriously though. How about someone out there go and get an auto-x course setup, get a fully prepped CS BRZ and CS FR-S, get the same damn driver, and have them drive the course 10 times each (alternating between runs) with each car? Let's compare the data and see what the difference really is. Also don't forget to let the driver run the course 3 times with a completely different car prior to that so we can rule out course knowledge bias as well.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 06-21-2016, 08:38 PM   #4240
strat61caster
to you too!!
I'd keep competing in the BRZ (although I would not have bought it even if that was the plan because of the weight difference, google it: 6 lbs on the '15), I bet all those quick guys bought on that information alone. They just got lucky with the TRD springs coming out, it could have easily been that Scion would not sell TRD parts or since TRD parts are 'Toyota' and not 'Scion' they're disallowed meanwhile the STI springs came out giving the BRZ an edge.
If I truly felt that the TRD springs and sways created an unfair advantage between the two cars (probably by doing what @Locust suggests with a competitor if I could find a buddy and swapping cars at a casual event) I'd probably run the TRD parts locally with a gentleman's agreement with my competitors and write a letter with the suggestion I mentioned: let the BRZ use the same parts as the FRS. Everywhere I've looked CS fields are bigger and tighter in competition than DS, I'd want to stay in CS.
Edit: Again, assuming I felt the BRZ was truly disadvantaged and my goal was really to win Nationals in my own car, I'd sell the car. Realistically I'd be waiting on tenterhooks for the ruling or finding someone with an FRS and an open co-driver's seat.
ineedyourdiddly
Old 06-22-2016, 02:17 AM   #4241
renfield90
The Stig's German cousin
Just look at nats results bro. The fastest BRZ was driven by a multi-time jacket winner, and was not well placed.
Also DS participation is soft. We'd be doing them a favor. Additionally I suspect the TRD-sprung FRS will get buried by the ND at nats - seriously, go drive an ND, they are stupid easy to turn quick times in - and also by the updated 2017 model, plus whatever the SEB decides to shuffle down from BS.
In a year you're going to be very happy to put your stock springs back on and go WRX hunting. Unless you're all silly enough to write your letter against it, in which case, have fun fighting Caymans/Boxsters and 2017 twins with faster gearing/potentially no torque dip. Spring swapping is technically legal for us, but not in the spirit of street class rules. Don't expect your car to stay competitive for too much longer; the SEB can't outlaw those springs without massively breaking a lot of things, so they like to bury stuff like that instead (see: MX-5 MSR, Solstice Z0K, Boss 302 Laguna Seca, and others).
Old 06-22-2016, 08:05 AM   #4242
Biggins
Drives: Yes
I was one of those who wrote a letter last year after running my non-TRD FR-S. I was still able to trophy last year at Toledo against TRD FRS's and BRZs. I codrove a TRD car at Nationals last year. I've been running CS for 4 years now but only half of this year on TRD stuff, but I am convinced that the advantages of the TRD stuff only comes into play at the important concrete lots with the best drivers. I think tire and shock choice are a bigger factor. At most of my local lots, I don't even believe there is any difference between the BRZ and FR-S (driven both back-to-back multiple times).
I originally chose the FR-S because it was lighter and cheaper than the BRZ. Whatever the ruling may be for a split or remaining in CS, I will be fine with it and adjust. Maybe I'll buy a BRZ for DS (or put my springs back on), maybe a 986S for CS, maybe a Fiata, but the street classes are bound to change when a newer and faster car comes into the class. I've been pretty bummed this year getting massacred by the local ND which is regularly raw timing STX and most of STR. I felt a little better after seeing it dominate at Wilmington Pro and last weekend's DC Tour (let's not look at its gap to me), but I'm going to give it a go one more time in Lincoln this year in my car.
We'll see how the season pans out... as long as I'm still having fun, I'm good. I'll still be out there in CS, DS, or wherever they put it. If it's not the car to have, perhaps it's time to move to the next car and use my FR-S as just a fun car to own.
Biggins is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
